USB Microphone issue when keyboard is pressed
Hi everyone, I just bought a USB Microphone (FiFine t683) and it’s working great except that when I use it while using the keyboard. To demonstrate, I created a recording here Screencastify
I’m using pipewire and I have been searching the forum and even in arch wiki and issues but I couldn’t find a similar issue. Please let me know if I miss something here. Thanks a lot!
UPDATE:
I’m using a laptop and the issue occurs when I press the external usb keyboard as well as pressing the builtin keyboard from the laptop
Here’s my lsub:
[I] ❯ lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 002: ID 05e3:0612 Genesys Logic, Inc. Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 007: ID 25a7:fa7c Areson Technology Corp Xlite Mini Wireless
Bus 003 Device 006: ID 0bda:b002 Realtek Semiconductor Corp. Bluetooth Radio
Bus 003 Device 004: ID 1c7a:0603 LighTuning Technology Inc. ES603 Swipe Fingerprint Sensor
Bus 003 Device 011: ID 4b57:574c KiwiKey Wanderland
Bus 003 Device 005: ID 3142:0031 FIFINE 683 Microphone FIFINE 683 Microphone
Bus 003 Device 003: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 009: ID 5986:055c Acer, Inc BisonCam, NB Pro
Bus 003 Device 002: ID 2357:0138 TP-Link 802.11ac NIC
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Below is the output of my inxi:
  Kernel: 5.15.82-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=d6a069c3-c57b-4637-a422-dd82714d7a63 rw quiet
    udev.log_priority=3
  Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Notebook product: P15SM-A/SM1-A v: N/A
    serial: <superuser required>
  Mobo: Notebook model: P15SM-A/SM1-A serial: <superuser required>
    UEFI: American Megatrends v: 4.6.5 date: 03/27/2014
  ID-1: BAT0 charge: 2.8 Wh (22.6%) condition: 12.4/77.0 Wh (16.2%) volts: 15.5
    min: 14.8 model: Notebook BAT type: Li-ion serial: <filter> status: charging
  RAM: total: 15.54 GiB used: 4.11 GiB (26.5%)
  Info: model: Intel Core i7-4810MQ bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2794 high: 2797 min/max: 800/3800 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2794 2: 2794 3: 2797
    4: 2794 5: 2794 6: 2794 7: 2794 8: 2796 bogomips: 44718
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    prctl and seccomp
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 4th Gen Core Processor Integrated Graphics
    vendor: CLEVO/KAPOK driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm
    built: 2010 ports: active: DP-2,eDP-1 empty: DP-1, HDMI-A-1, HDMI-A-2,
    HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
  Device-2: NVIDIA GK104M [GeForce GTX 870M] vendor: CLEVO/KAPOK driver: N/A
    alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
    status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
    process: TSMC 28nm built: 2012-18 pcie: speed: Unknown lanes: 63 link-max:
    gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1199 class-ID: 0300
  Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 3-10:9
    chip-ID: 5986:055c class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.83x15.00")
    s-diag: 1468mm (57.81")
  Monitor-1: DP-2 mapped: DP2 pos: left model: Asus ROG PG348Q
    serial: <filter> built: 2018 res: 3440x1440 hz: 100 dpi: 109 gamma: 1.2
    size: 800x340mm (31.5x13.39") diag: 865mm (34.1") modes: max: 3440x1440
    min: 640x480
  Monitor-2: eDP-1 mapped: eDP1 pos: primary,right model: AU Optronics 0x10ed
    built: 2011 res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2
    size: 340x190mm (13.39x7.48") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: CLEVO/KAPOK driver: N/A bus-ID: 3-2.1:5 alternate: snd_hda_intel
    bus-ID: 00:03.0 chip-ID: 3142:0031 class-ID: 0102 chip-ID: 8086:0c0c
    class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: CLEVO/KAPOK driver: N/A alternate: snd_hda_intel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  Device-3: NVIDIA GK104 HDMI Audio driver: N/A alternate: snd_hda_intel
    pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
    bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
  Device-4: FIFINE 683 Microphone type: USB driver: snd-usb-audio
  Sound API: ALSA v: k5.15.82-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 16.1 running: no
  Sound Server-3: PipeWire v: 0.3.61 running: yes
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 05:00.2 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0f2 state: down mac: <filter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter driver: N/A
    modules: rtl8723be pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000
    bus-ID: 06:00.0 chip-ID: 10ec:b723 class-ID: 0280
  Device-3: TP-Link 802.11ac NIC type: USB driver: rtl88x2bu bus-ID: 3-1:2
    chip-ID: 2357:0138 class-ID: 0000 serial: <filter>
  IF: wlp0s20u1 state: up mac: <filter>
  IF-ID-1: br-097ed85e191b state: down mac: <filter>
  IF-ID-2: br-0e44613e1a5a state: down mac: <filter>
  Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-3: br-50551c24b7db state: down mac: <filter>
    all]
  IF-ID-4: br-9ff48f289964 state: down mac: <filter>
    all]
  IF-ID-5: br-f7100ad8269b state: down mac: <filter>
    all]
  IF-ID-6: docker0 state: down mac: <filter>
    all]
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 3-4:6 chip-ID: 0bda:b002 class-ID: e001 serial: <filter>
  Local Storage: total: 1.14 TiB used: 730.93 GiB (62.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
    type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT256M550SSD1
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: MU01 scheme: GPT
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208FB rev: TC00
    dev-links: cdrom
  ID-1: / raw-size: 151.61 GiB size: 148.92 GiB (98.23%) used: 124 GiB (83.3%)
    fs: ext4 dev: /dev/sdb6 maj-min: 8:22 label: N/A
    uuid: d6a069c3-c57b-4637-a422-dd82714d7a63
  ID-2: /boot/efi raw-size: 260 MiB size: 259.5 MiB (99.80%)
    used: 28.7 MiB (11.0%) fs: vfat dev: /dev/sdb3 maj-min: 8:19 label: SYSTEM
    uuid: 416C-EC60
  ID-3: /home/<filter>/Pasmo raw-size: 931.39 GiB size: 931.39 GiB (100.00%)
    used: 606.9 GiB (65.2%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Pasmo
    uuid: 76E035E3E035AA6F
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
  ID-3: /dev/sdb2 maj-min: 8:18 size: 300 MiB fs: ntfs
    label: Windows RE tools uuid: 043D85A0B9C0D8F5
  ID-4: /dev/sdb4 maj-min: 8:20 size: 85.65 GiB fs: ntfs label: Windows
    uuid: 0C790EBD9D9FCDA4
  ID-5: /dev/sdb5 maj-min: 8:21 size: 549 MiB fs: ntfs label: N/A
    uuid: ACB2469FB2466DC0
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 3-1:2 info: TP-Link 802.11ac NIC type: Network driver: rtl88x2bu
    interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 2357:0138
  Hub-6: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 3-2.1:5 info: FIFINE 683 Microphone type: Audio
    driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 100mA
  Device-2: 3-2.4:11 info: KiwiKey Wanderland type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 4b57:574c class-ID: 0300
  Device-3: 3-3:4 info: LighTuning ES603 Swipe Fingerprint Sensor
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 1c7a:0603 class-ID: 0000
  Device-4: 3-4:6 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b002
  Device-5: 3-6:7 info: Areson Corp Xlite Mini Wireless type: Mouse,Keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA
    chip-ID: 25a7:fa7c class-ID: 0301
  Device-6: 3-10:9 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:055c
  Hub-7: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-8: 4-2:2 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 05e3:0612 class-ID: 0900
  System Temperatures: cpu: 55.0 C mobo: N/A
  Processes: 270 Uptime: 56m wakeups: 1 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1667 libs: 386 tools: pamac Shell: Zsh v: 5.9 running-in: tmux:
  inxi: 3.3.23
