Yes, I know it’s not officially supported, but I’ve heard the latest drivers fix a lot of issues, so I thought I’d see I’d give Sway another go. I was ready for some artifacts and crashes, but I didn’t expect that it would actually refuse to launch…
Anyway, here’s my setup:
- Nvidia RTX 2060
- No other GPU AFAICT.
- Manjaro Sway edition, relatively unmolested (I’ve installed a few packages, and I’ve swapped the drivers around a couple of times).
- All the packages are up to date with stable.
What I’ve done:
- Install Manjaro Sway from LiveUSB. My first warning sign should have been that it failed to start GUI with nonfree drivers… Anyway, I’ve installed it with free drivers.
- Switch to non-free drivers (video-nvidia) using mhwd, reboot.
- Notice that with non-free drivers the resolution seems to be lower (as in, the font is larger, since I can’t see anything but text at this point)
- Try and fail to start Sway (unsupported GPU) session from the login manager.
- Try and fail to start sway --unsupported-gpu --debug --verbose from the command line:
00:00:00.000 [INFO] [sway/main.c:338] Sway version 1.8.1
00:00:00.000 [INFO] [sway/main.c:339] wlroots version 0.16.2
00:00:00.010 [INFO] [sway/main.c:120] Linux Crowley 6.1.68-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Dec 14 00:46:56 UTC 2023 x86_64 GNU/Linux
00:00:00.011 [INFO] [sway/main.c:136] Contents of /etc/lsb-release:
00:00:00.011 [INFO] [sway/main.c:120] DISTRIB_ID="ManjaroLinux"
00:00:00.011 [INFO] [sway/main.c:120] DISTRIB_RELEASE="22.1.2"
00:00:00.011 [INFO] [sway/main.c:120] DISTRIB_CODENAME="Talos"
00:00:00.011 [INFO] [sway/main.c:120] DISTRIB_DESCRIPTION="Manjaro Linux"
00:00:00.011 [INFO] [sway/main.c:136] Contents of /etc/os-release:
00:00:00.011 [INFO] [sway/main.c:120] NAME="Manjaro Linux"
00:00:00.011 [INFO] [sway/main.c:120] PRETTY_NAME="Manjaro Linux"
00:00:00.011 [INFO] [sway/main.c:120] ID=manjaro
00:00:00.011 [INFO] [sway/main.c:120] ID_LIKE=arch
00:00:00.011 [INFO] [sway/main.c:120] BUILD_ID=rolling
00:00:00.011 [INFO] [sway/main.c:120] ANSI_COLOR="32;1;24;144;200"
00:00:00.011 [INFO] [sway/main.c:120] HOME_URL="https://manjaro.org/"
00:00:00.011 [INFO] [sway/main.c:120] DOCUMENTATION_URL="https://wiki.manjaro.org/"
00:00:00.011 [INFO] [sway/main.c:120] SUPPORT_URL="https://forum.manjaro.org/"
00:00:00.011 [INFO] [sway/main.c:120] BUG_REPORT_URL="https://docs.manjaro.org/reporting-bugs/"
00:00:00.011 [INFO] [sway/main.c:120] PRIVACY_POLICY_URL="https://manjaro.org/privacy-policy/"
00:00:00.011 [INFO] [sway/main.c:120] LOGO=manjarolinux
00:00:00.011 [INFO] [sway/main.c:108] LD_LIBRARY_PATH=
00:00:00.011 [INFO] [sway/main.c:108] LD_PRELOAD=
00:00:00.011 [INFO] [sway/main.c:108] PATH=/home/nigredo/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
00:00:00.011 [INFO] [sway/main.c:108] SWAYSOCK=
00:00:00.011 [ERROR] [sway/main.c:62] !!! Proprietary Nvidia drivers are in use !!!
00:00:00.011 [INFO] [sway/main.c:376] Starting sway version 1.8.1
00:00:00.011 [DEBUG] [sway/server.c:67] Initializing Wayland server
00:00:00.030 [INFO] [wlr] [libseat] [libseat/libseat.c:62] Seat opened with backend 'logind'
00:00:00.031 [INFO] [wlr] [backend/session/session.c:109] Successfully loaded libseat session
00:00:00.032 [DEBUG] [wlr] [backend/session/session.c:384] Ignoring '/dev/dri/card0': not a KMS device
00:00:00.033 [ERROR] [wlr] [backend/backend.c:217] Found 0 GPUs, cannot create backend
00:00:00.033 [ERROR] [wlr] [backend/backend.c:390] Failed to open any DRM device
00:00:00.035 [ERROR] [sway/server.c:73] Unable to create backend
- Try and fail to start it with WLR_DRM_DEVICES=/dev/dri/card0. The only difference is:
[ERROR] [wlr] [backend/session/session.c:410] Unable to open /dev/dri/card0 as DRM device
Some other things I’ve tried:
- Remove the free drivers (in case there is a conflict), reboot, try to launch Sway. No change.
- Change drivers using Manjaro Settings instead of mhwd (although that should be the same thing), reboot, try to launch Sway. No change.
- Try and tweak mkinitcpio.conf following suggestions from the Arch wiki. Rebuild the image, reboot. No change. I changed it back, and rebuilt the image again.
Just in case, I’m attaching a part of my journalctl output that seemed relevant:
Dec 17 16:08:10 Crowley kernel: nvidia: loading out-of-tree module taints kernel.
Dec 17 16:08:10 Crowley kernel: nvidia: module license 'NVIDIA' taints kernel.
Dec 17 16:08:10 Crowley kernel: Disabling lock debugging due to kernel taint
Dec 17 16:08:10 Crowley kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Dec 17 16:08:11 Crowley kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 237
Dec 17 16:08:11 Crowley kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Dec 17 16:08:11 Crowley kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
Dec 17 16:08:11 Crowley kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
Dec 17 16:08:11 Crowley kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
Dec 17 16:08:11 Crowley kernel: ucsi_ccg: probe of 0-0008 failed with error -110
Dec 17 16:08:11 Crowley kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
Dec 17 16:08:11 Crowley systemd-modules-load[266]: Inserted module 'nvidia'
Dec 17 16:08:11 Crowley kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 545.29.06 Thu Nov 16 01:47:29 UTC 2023
Dec 17 16:08:11 Crowley systemd-modules-load[266]: Inserted module 'nvidia_drm'
Dec 17 16:08:11 Crowley kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Dec 17 16:08:11 Crowley kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
Dec 17 16:08:12 Crowley kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dec 17 16:08:12 Crowley systemd-modules-load[266]: Inserted module 'nvidia_uvm'
Dec 17 16:08:12 Crowley kernel: nvidia-uvm: Loaded the UVM driver, major device number 235.
I’m not really familiar with this level of configuration and with Manjaro/Arch in general, so I’d appreciate any suggestions to be as concrete as possible (e.g. “run this command to rebuild the kernel” over just “rebuild the kernel”). Also, I apologize in advance in case this turns out to be something trivial and/or covered by existing sources.
