[fennectech@Jasper /run/media/fennectech]$ ls -la
total 7
drwxr-x---+ 3 fennectech root 60 Mar 28 13:42 .
drwxr-xr-x 3 root root 60 Mar 23 19:55 ..
drwxr-xr-x 2 fennectech storage 7168 Dec 31 1969 092A-15F7
{13:42} Mon Mar 28
total 7
drwxr-x---+ 3 fennectech root 60 Mar 28 13:43 .
drwxr-xr-x 2 root root 7168 Dec 31 1969 disk
First disk formated with mkfs.vfat has proper permissions
second disk formatted in DOS does not have propper permissions both disks are formatted with fat12 so there is no permissions actually going on
/org/freedesktop/UDisks2/block_devices/sdd:
org.freedesktop.UDisks2.Block:
Configuration: []
CryptoBackingDevice: '/'
Device: /dev/sdd
DeviceNumber: 2096
Drive: '/org/freedesktop/UDisks2/drives/MITSUMI_MITSUMI_USB_FDD_MITSUMI_MITSUMI_USB_FDD'
HintAuto: true
HintIconName:
HintIgnore: false
HintName:
HintPartitionable: true
HintSymbolicIconName:
HintSystem: false
IdLabel:
IdType: vfat
IdUUID: 092A-15F7
IdUsage: filesystem
IdVersion: FAT12
MDRaid: '/'
MDRaidMember: '/'
PreferredDevice: /dev/sdd
ReadOnly: false
Symlinks: /dev/disk/by-id/usb-MITSUMI_MITSUMI_USB_FDD
/dev/disk/by-path/pci-0000:00:14.0-usb-0:11:1.0-scsi-0:0:0:0
/dev/disk/by-uuid/092A-15F7
UserspaceMountOptions: uhelper=udisks2
org.freedesktop.UDisks2.Filesystem:
MountPoints: /run/media/fennectech/disk
/o
Udisksctl dump of DOS formatted diskette
Configuration: []
Device: /dev/sdd
DeviceNumber: 2096
HintAuto: true
HintIconName:
HintIgnore: false
HintName:
HintSystem: false
IdLabel:
IdType: vfat
IdUUID: 0F60-4917
IdUsage: filesystem
IdVersion: FAT12
MDRaid: '/'
MDRaidMember: '/'
ReadOnly: false
/dev/disk/by-uuid/0F60-4917
MountPoints: /run/media/fennectech/0F60-4917
Udiskctl dump of MKFS formatted diskette
[fennectech@Jasper /run/media/fennectech]$ sudo fsck /dev/sdd -v
fsck from util-linux 2.37.4
fsck.fat 4.2 (2021-01-31)
Checking we can access the last sector of the filesystem
Boot sector contents:
System ID "MSWIN4.1"
Media byte 0xf0 (5.25" or 3.5" HD floppy)
512 bytes per logical sector
512 bytes per cluster
1 reserved sector
First FAT starts at byte 512 (sector 1)
2 FATs, 12 bit entries
4608 bytes per FAT (= 9 sectors)
Root directory starts at byte 9728 (sector 19)
224 root directory entries
Data area starts at byte 16896 (sector 33)
2847 data clusters (1457664 bytes)
18 sectors/track, 2 heads
0 hidden sectors
2880 sectors total
Checking for unused clusters.
/dev/sdd: 0 files, 0/2847 clusters
Fsck of DOS formatted floppy
System ID "mkfs.fat"
1 reserved sector
0 hidden sectors
2880 sectors total
FSCK of MKFS formatted floppy
FSCKing the diskette seems to fix this
1 reserved sector
0 hidden sectors
2880 sectors total
output of FSCKd dos formatted floppy
1 reserved sector
0 hidden sectors
2880 sectors total
could it be that the disks have no label from dos?
its not FS label
