USB-Dongle after screenlock doesn't work
Yesterday I had to reinstall Manjaro Plasma.
A serious problem is bothering me.
After a screen lock, the USB dongle for keyboard and mouse no longer works. I have to turn off the computer and restart it.
Is it the screen lock or a standby? I am no plasma user, on the xfce edition tlp is the default power manager, and one can tell the usb devices to stay on at standby. But i think plasma uses powerdevil.
Anyways, the power management settings would be the first thing to check. And lock screen settings.
screenlock is switched off, In energy saving mode, standby is set after 15 minutes.
you could try turning usb powersaving off. Or update your bios.
btw. is this an issue only after reinstalling your OS ? Then it could be that you ended up on different kernel version, so maybe try switching to what you were using before?
i switched off standby In energy saving mode
Thanks for your replies
