Manjaro Nibia 20.2.1 (64-bit, Xfce 4.16)
Lenovo ThinkCentre M58 6303W2N (Audio Intel Q45, 8 USB ports: 2 x front, 6 x rear)
Dericam W3 1080p Webcam
My webcam takes pictures and record videos but its microphone works randomly (1 - no sound at all, 2 - static beeping, 3 - perfect sound). It does not depend on me changing the settings, but it is quite random and depends on USB port. Unfortunately, the working USB ports (one in front and one in the back) do not work all the time.
[lenovo@lenovo-6303w2n ~]$ alsamixer
[lenovo@lenovo-6303w2n ~]$ amixer --card=1
Simple mixer control ‘Mic’,0
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 256
Front Left: Capture 256 [100%] [0.00dB] [on]
Front Right: Capture 256 [100%] [0.00dB] [on]
[lenovo@lenovo-6303w2n ~]$ amixer --card=0
Simple mixer control ‘Master’,0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 39
Mono: Playback 39 [100%] [0.00dB] [on]
Simple mixer control ‘Headphone’,0
Capabilities: pswitch
Mono:
Front Left: Playback [off]
Front Right: Playback [off]
Simple mixer control ‘Headphone+LO’,0
Mono:
Front Left: Playback 39 [100%] [0.00dB]
Front Right: Playback 39 [100%] [0.00dB]
Simple mixer control ‘Speaker’,0
Limits: Playback 0 - 31
Mono: Playback 0 [0%] [-46.50dB] [off]
Simple mixer control ‘PCM’,0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control ‘Front’,0
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control ‘Front Mic’,0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 31 [100%] [12.00dB] [off]
Front Right: Playback 31 [100%] [12.00dB] [off]
Simple mixer control ‘Front Mic Boost’,0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control ‘Surround’,0
Mono:
Front Left: Playback 39 [100%] [0.00dB] [on]
Front Right: Playback 39 [100%] [0.00dB] [on]
Simple mixer control ‘Center’,0
Simple mixer control ‘LFE’,0
Simple mixer control ‘Line’,0
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control ‘Line Boost’,0
Limits: 0 - 3
Simple mixer control ‘CD’,0
Mono:
Simple mixer control ‘Beep’,0
Limits: Playback 0 - 15
Mono: Playback 13 [87%] [-6.00dB] [off]
Simple mixer control ‘Capture’,0
Limits: Capture 0 - 54
Front Left: Capture 54 [100%] [22.50dB] [on]
Front Right: Capture 54 [100%] [22.50dB] [on]
Simple mixer control ‘Capture’,1
Front Left: Capture 54 [100%] [22.50dB] [off]
Front Right: Capture 54 [100%] [22.50dB] [off]
Simple mixer control ‘Auto-Mute Mode’,0
Capabilities: enum
Items: ‘Disabled’ ‘Speaker Only’ ‘Line Out+Speaker’
Item0: ‘Disabled’
Simple mixer control ‘Channel Mode’,0
Capabilities: enum
Items: ‘2ch’ ‘4ch’ ‘6ch’
Item0: ‘2ch’
Simple mixer control ‘Digital’,0
Limits: Capture 0 - 120
Front Left: Capture 120 [100%] [30.00dB]
Front Right: Capture 120 [100%] [30.00dB]
Simple mixer control ‘Independent HP’,0
Capabilities: enum
Items: ‘Disabled’ ‘Enabled’
Item0: ‘Disabled’
Simple mixer control ‘Input Source’,0
Capabilities: cenum
Items: ‘Front Mic’ ‘Rear Mic’ ‘Line’ ‘CD’ ‘Stereo Mix’
Item0: ‘Rear Mic’
Simple mixer control ‘Input Source’,1
Capabilities: cenum
Item0: ‘Front Mic’
Simple mixer control ‘Loopback Mixing’,0
Capabilities: enum
Item0: ‘Disabled’
Simple mixer control ‘Rear Mic’,0
Mono:
Simple mixer control ‘Rear Mic Boost’,0
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
[lenovo@lenovo-6303w2n ~]$ pacmd dump
Configuration dump generated at Sat Feb 6 14:18:43 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id=“0” name=“pci-0000_00_1b.0” card_name=“alsa_card.pci-0000_00_1b.0” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-alsa-card device_id=“1” name=“usb-HD_Webcam_USB_HD_Webcam_USB_HD_Webcam_USB-02” card_name=“alsa_card.usb-HD_Webcam_USB_HD_Webcam_USB_HD_Webcam_USB-02” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0.0 xauthority=/home/lenovo/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/lenovo/.Xauthority session_manager=local/lenovo-6303w2n:@/tmp/.ICE-unix/829,unix/lenovo-6303w2n:/tmp/.ICE-unix/829
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1b.0.analog-stereo 0x10000
set-sink-mute alsa_output.pci-0000_00_1b.0.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1b.0.analog-stereo yes
set-source-volume alsa_input.usb-HD_Webcam_USB_HD_Webcam_USB_HD_Webcam_USB-02.analog-stereo 0x18675
set-source-mute alsa_input.usb-HD_Webcam_USB_HD_Webcam_USB_HD_Webcam_USB-02.analog-stereo no
suspend-source alsa_input.usb-HD_Webcam_USB_HD_Webcam_USB_HD_Webcam_USB-02.analog-stereo yes
set-source-volume alsa_output.pci-0000_00_1b.0.analog-stereo.monitor 0x8020
set-source-mute alsa_output.pci-0000_00_1b.0.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor yes
set-card-profile alsa_card.pci-0000_00_1b.0 output:analog-stereo
set-card-profile alsa_card.usb-HD_Webcam_USB_HD_Webcam_USB_HD_Webcam_USB-02 input:analog-stereo
set-default-sink alsa_output.pci-0000_00_1b.0.analog-stereo
set-default-source alsa_input.usb-HD_Webcam_USB_HD_Webcam_USB_HD_Webcam_USB-02.analog-stereo
EOF
