As the title suggests, I have a Dell xps 13 7390 whose USB-C port is connected to a power bank which features two hdmi ports. One of those hdmi ports is connected to my external monitor. Suffice it to say that whenever I am presented with the login screen, the external monitor activates with no problems whatsoever. However, as soon as I log in, the external monitor switches off and loses signal. There are other things that trigger this issue whilst being logged in:
Switching output (on my monitor from say HDMI 1 to HDMI 2)
Disconnecting the USB-C powerbank or the HDMI to connect either to another device
The current workround I have is to delete the .local/share/kscreen directory, log out then log back in. But I don’t want to keep doing that as it is cumbersome and I end up having to reconfigure my monitor layout.
Can anyone help me get to the root cause of this issue? Thanks.
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
The xrandr output we already have thanks to @mbb and it seems like your monitor gets disconnected so I’m suspecting a module / screen config issue, so:
the contents of the files in:
ls /etc/X11/mhwd.d/
(We don’t need .backup files)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
I ran xrandr --output VIRTUAL1 --auto and that disconnected my external monitor, resulting in no signal. It has also disabled KDE’s compositor which I have to re-enable with ALT+SHIFT+F12. The laptop’s own monitor continues to work though.
I ran xrandr again though and got this:
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 290mm x 160mm
1920x1080 60.03*+ 48.03
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
DP2-1 disconnected (normal left inverted right x axis y axis)
DP2-2 disconnected (normal left inverted right x axis y axis)
DP2-3 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
1920x1080 (0x1b7) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1b8) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x1b9) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1600x1200 (0x1ba) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1680x1050 (0x1bb) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1280x1024 (0x1bc) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1bd) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x1be) 88.750MHz +HSync -VSync
h: width 1440 start 1488 end 1520 total 1600 skew 0 clock 55.47KHz
v: height 900 start 903 end 909 total 926 clock 59.90Hz
1280x960 (0x1bf) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1366x768 (0x1c0) 85.500MHz +HSync +VSync
h: width 1366 start 1436 end 1579 total 1792 skew 0 clock 47.71KHz
v: height 768 start 771 end 774 total 798 clock 59.79Hz
1152x864 (0x1c1) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x1c2) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1c3) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x1c4) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x1c5) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1c6) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x1c7) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
832x624 (0x1c8) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
800x600 (0x1c9) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x1ca) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1cb) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1cc) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
720x576 (0x1cd) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1ce) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x1cf) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d0) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d1) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0x1d2) 30.240MHz -HSync -VSync
h: width 640 start 704 end 768 total 864 skew 0 clock 35.00KHz
v: height 480 start 483 end 486 total 525 clock 66.67Hz
640x480 (0x1d3) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x1d4) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x400 (0x1d5) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
I can’t get the monitor to regain signal and display when connected. Here’s what xrandr is outputting though:
DP2-1 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 50.00 59.94
1600x1200 60.00
1680x1050 59.88
1280x1024 75.02 60.02
1440x900 59.90
1280x960 60.00
1366x768 59.79
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
I managed to get the monitor connected by replugging the HDMI cable to the other HDMI port, and replugging the USB-C to the second USB-C port next to the previous. The monitor connects but this time the desktop layout/background were reset. Here are the results of running xrandr afterwards:
Screen 0: minimum 8 x 8, current 1921 x 2160, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+1080 (normal left inverted right x axis y axis) 290mm x 160mm
DP1-1 disconnected (normal left inverted right x axis y axis)
DP1-2 connected 1920x1080+1+0 (normal left inverted right x axis y axis) 530mm x 300mm
1920x1080 60.00*+ 50.00 59.94
1600x1200 60.00
1680x1050 59.88
1440x900 59.90
1280x960 60.00
1366x768 59.79
1152x864 75.00
832x624 74.55
720x576 50.00
720x480 60.00 59.94
720x400 70.08
DP1-3 disconnected (normal left inverted right x axis y axis)
EDIT: when DP2-1 appears, you should be able to turn the monitor on with xrandr --output DP2-1 --auto --left-of eDP1, for example, where --left-of can change according to your preference. See xrandr --help for more info.
It’s strange because before altering the cables I restarted my laptop and the login screen rendered the monitor and the laptop perfectly with no blackouts; nay if I login the external monitor loses signal with only the laptop remaining. The compositor is disabled upon login.
Fabby, I don’t think the issue has been resolved. I don’t think there are issues with the ports here. The previous cable layout displayed a rendered login screen on the monitor but a disabled external monitor upon login. I fiddled around with the cables again during login and this time I lost connection to the external monitor. It was only when I replugged the USB-C then disconnected/reconnected the HDMI cable at the same port that I got my external monitor reconnected. I don’t think this is a hardware issue.
