USB-C Monitor Connection not working
Hello! I recently decided to change from Manjaro KDE to Manjaro GNOME and I’m attempting to use an external monitor to extend my display. My computer detects the connection, however it doesn’t appear in the display tab on settings. Below my inxi output:
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=e9916a00-a876-47a0-98c0-839554ba0645 rw quiet splash apparmor=1
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
  Type: Convertible System: ASUSTeK product: Q525UAR v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: Q525UAR v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: Q525UAR.309 date: 09/28/2018
  ID-1: BAT0 charge: 2.2 Wh (9.1%) condition: 24.3/52.6 Wh (46.3%) volts: 11.6
    min: 11.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: charging cycles: 235
  Device-1: hid-0018:04F3:2702.0001-battery model: ELAN2702:00 04F3:2702
    serial: N/A charge: N/A status: N/A
  Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF2
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1852 high: 2164 min/max: 400/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2069 2: 2000 3: 1514
    4: 2000 5: 1530 6: 2000 7: 1540 8: 2164 bogomips: 32012
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
    class-ID: 0300
  Device-2: USB C Video Adaptor driver: N/A type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3.3.3:10 chip-ID: 25a4:9311 class-ID: 1100
    serial: <filter>
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:5 chip-ID: 13d3:5694
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel UHD Graphics 620 (KBL
    GT2) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.3:4
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u3u3 state: down mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: cdc_ncm
    type: USB rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4.4:7
    chip-ID: 0bda:8153 class-ID: 0a00 serial: <filter>
  IF: eth1 state: down mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:8 chip-ID: 8087:0a2b
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 56.47 GiB (3.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM3 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 56.46 GiB (3.1%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 43.0 C pch: 41.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 264 Uptime: 9m wakeups: 3 Memory: available: 15.51 GiB
  used: 3.31 GiB (21.3%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1366
  pm: pacman pkgs: 1360 libs: 362 tools: gnome-software,pamac pm: flatpak
  pkgs: 6 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
also my lsusb output:
Bus 002 Device 013: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 002 Device 012: ID 0bda:0409 Realtek Semiconductor Corp. USB3.2 Hub
Bus 002 Device 011: ID 0bda:0409 Realtek Semiconductor Corp. USB3.2 Hub
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp. Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 011: ID 04f3:0903 Elan Microelectronics Corp. ELAN:Fingerprint
Bus 001 Device 008: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 005: ID 13d3:5694 IMC Networks USB2.0 HD UVC WebCam
Bus 001 Device 021: ID 0bda:1100 Realtek Semiconductor Corp. HID Device
Bus 001 Device 022: ID 0bda:54bb Realtek Semiconductor Corp. BillBoard Device -> Thid one
Bus 001 Device 020: ID 0bda:5409 Realtek Semiconductor Corp. USB2.1 Hub
Bus 001 Device 019: ID 0bda:5409 Realtek Semiconductor Corp. USB2.1 Hub
Bus 001 Device 007: ID 04b3:310b IBM Corp. Red Wheel Mouse
Bus 001 Device 004: ID 05ac:024f Apple, Inc. Aluminium Keyboard (ANSI)
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
How should I proceed with this? Are there any default drivers I should have for this monitor?
