Hi there,
Using Manjaro-i3wm and I have 2 issues with a USB-C Headset.
Cannot send Audio to the Earphones
I can see that the device is detected and it shows in Alsamixer, but I cannot get the audio via the earphones.
dmesg output
[ 4716.633019] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 4716.633023] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4716.633027] usb usb3: Product: xHCI Host Controller
[ 4716.633030] usb usb3: Manufacturer: Linux 5.8.6-1-MANJARO xhci-hcd
[ 4716.633033] usb usb3: SerialNumber: 0000:3a:00.0
[ 4716.633419] hub 3-0:1.0: USB hub found
[ 4716.633451] hub 3-0:1.0: 2 ports detected
[ 4716.635351] xhci_hcd 0000:3a:00.0: xHCI Host Controller
[ 4716.635364] xhci_hcd 0000:3a:00.0: new USB bus registered, assigned bus number 4
[ 4716.635375] xhci_hcd 0000:3a:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 4716.635513] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 4716.635519] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4716.635524] usb usb4: Product: xHCI Host Controller
[ 4716.635529] usb usb4: Manufacturer: Linux 5.8.6-1-MANJARO xhci-hcd
[ 4716.635534] usb usb4: SerialNumber: 0000:3a:00.0
[ 4716.635967] hub 4-0:1.0: USB hub found
[ 4716.635996] hub 4-0:1.0: 2 ports detected
[ 4716.963508] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[ 4717.105252] usb 3-1: New USB device found, idVendor=12d1, idProduct=3a07, bcdDevice= 0.28
[ 4717.105269] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4717.105274] usb 3-1: Product: HUAWEI USB-C HEADSET
[ 4717.105281] usb 3-1: Manufacturer: bestechnic
[ 4717.105285] usb 3-1: SerialNumber: 0296A100000000000000000000000
[ 4717.117852] input: bestechnic HUAWEI USB-C HEADSET as /devices/pci0000:00/0000:00:1c.4/0000:04:00.0/0000:05:02.0/0000:3a:00.0/usb3/3-1/3-1:1.3/0003:12D1:3A07.0008/input/input32
[ 4717.174017] hid-generic 0003:12D1:3A07.0008: input,hidraw0: USB HID v1.11 Device [bestechnic HUAWEI USB-C HEADSET] on usb-0000:3a:00.0-1/input
inxi -Fxxz
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: i3 4.18.2 dm: LightDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP ZBook 15 G3 v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 80D5 v: KBC Version 10.73
serial: <filter> UEFI: HP v: N81 Ver. 01.23
date: 01/30/2018
ID-1: BAT0 charge: 33.6 Wh
condition: 80.0/80.0 Wh (100%) volts: 11.1/11.4
model: Hewlett-Packard Primary serial: <filter>
status: Discharging
Topology: Quad Core model: Intel Core i7-6820HQ
bits: 64 type: MT MCP arch: Skylake-S rev: 3
L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2
ssse3 vmx
bogomips: 43214
Speed: 800 MHz min/max: 800/3600 MHz Core speeds (MHz):
1: 800 2: 800 3: 800 4: 800 5: 800 6: 801 7: 800 8: 800
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:191b
Device-2: Lite-On HP HD Camera type: USB
driver: uvcvideo bus ID: 1-7:2 chip ID: 04ca:7053
Display: x11 server: X.Org 1.20.8 driver: intel
unloaded: modesetting alternate: fbdev,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: Huawei HUAWEI USB-C HEADSET type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2
chip ID: 12d1:3a07
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Intel Ethernet I219-LM
vendor: Hewlett-Packard driver: e1000e v: 3.2.6-k
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15b7
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel
port: efa0 bus ID: 02:00.0 chip ID: 8086:24f3
Local Storage: total: 1.38 TiB used: 43.49 GiB (3.1%)
ID-1: /dev/nvme0n1 vendor: Samsung
model: MZVKW512HMJP-000H1 size: 476.94 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter>
ID-2: /dev/sda vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 468.16 GiB used: 43.49 GiB (9.3%)
fs: ext4 dev: /dev/dm-0
System Temperatures: cpu: 42.5 C mobo: 0.0 C
Processes: 224 Uptime: 1h 26m Memory: 31.25 GiB
used: 2.06 GiB (6.6%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 Packages: pacman: 1098 Shell: fish v: 3.1.2
running in: urxvtd inxi: 3.1.05
It is also available in alsamixer and I if i use the Volume controls on the headset the volume is going up and down for the device. (in alsamixer)
Any thoughts, I’m going to assume it is something so simple, I’ll need to hang my head in shame, but I’ve been reading the Arch wiki on alsa also and cannot find what I need.
The second issue, is that teh MIC on the USB headset does not appear to be available, if there is a quick answer to that great, if not I’ll keep digging.
Thanks in advance, if I’ve missed any information that would be helpful let me know.
Kindest Regards
Chris
