Hi,
I 'm a Linux user for over 15 years, and have been using Manjaro for at least three years.
I had been using Davinci Resolve Professional for over a year with no problems, until two days ago when, for no apparent reason, the program stopped working.
I’ve already tried everything, from reinstalling drivers, downloading and reinstalling Davinci Resolve, deleting all configuration files, changing kernels and finally doing a clean install. None of this has worked.
This is my hardware setup:
Processor: AMD Ryzen™ 7 3800X × 16
Graphics: AMD Radeon™ RX 570 Series
32 GB RAM
amdgpu-pro-oglp 22.40_1518373-1
rocm-opencl-runtime 5.4.3
Honestly, I have no idea what could have happened. I’ve tried installing the driver directly from the AMD site, but it’s quite a confusing process.
I hope someone can give me some guidance to resolve this situation.
The issue is likely related to mesa no longer providing the non-free codecs.
You will have to follow instructions like this
Unfortunately didn’t work.
please post the full output of
first.
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9195a160-2698-4e87-aa0a-ec54bcd7b8bf rw quiet splash apparmor=1
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1820
date: 09/12/2019
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
status: discharging
RAM: total: 31.28 GiB used: 6.8 GiB (21.7%)
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2366 high: 3618 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2140 2: 3581
3: 3618 4: 2200 5: 2195 6: 2196 7: 2195 8: 2195 9: 2311 10: 2045 11: 2217
12: 2200 13: 2196 14: 2197 15: 2195 16: 2190 bogomips: 124620
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 09:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 49.0 C
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: modesetting unloaded: radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DVI-D-1 pos: right model: HP 21kd serial: <filter> built: 2018
res: 1920x1080 hz: 60 dpi: 106 gamma: 1.2 size: 458x258mm (18.03x10.16")
diag: 526mm (20.7") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: BenQ GL2450
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.12-1-MANJARO) direct-render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel bus-ID: 3-2:3 v: kernel
chip-ID: 1397:0508 pcie: class-ID: fe01 gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: BEHRINGER GmbH UMC204HD 192k type: USB driver: snd-usb-audio
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.65 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.19 TiB used: 1000.07 GiB (30.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: XPG GAMMIX S11 Pro
lanes: 4 type: SSD serial: <filter> rev: 42A4SANA temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT960BX500SSD1
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R022
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SUV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 11.K scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S371920G
size: 1.75 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1103
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 26.48 GiB (45.1%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 9195a160-2698-4e87-aa0a-ec54bcd7b8bf
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 2476-D9EF
ID-3: /home raw-size: 407.93 GiB size: 400.46 GiB (98.17%)
used: 10.85 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 47db3034-3220-43b6-9051-460c3a027207
ID-4: /mnt/Disco 1 raw-size: 894.25 GiB size: 879.14 GiB (98.31%)
used: 373.54 GiB (42.5%) fs: ext4 dev: /dev/sda maj-min: 8:0 label: Disco 1
uuid: db4e4219-5bbf-4ec4-bf2e-252bbf703f7c
ID-5: /mnt/Disco 2 raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 67.37 GiB (61.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Disco 2
uuid: c5a77a4f-5ad5-4a5a-8682-23e15682a793
ID-6: /mnt/Disco 3 raw-size: 1.75 TiB size: 1.72 TiB (98.37%)
used: 521.82 GiB (29.7%) fs: ext4 dev: /dev/sdc maj-min: 8:32 label: Disco 3
uuid: 9fdf22f5-bf4f-48fa-bd39-4618d995deaf
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 98584120-1735-41c3-b5b3-fa7452ca4980
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-2:2 info: BY Tech Usb Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 258a:0016 class-ID: 0300
Device-2: 1-3:3 info: XP-Pen STAR 06 type: Mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 70mA chip-ID: 28bd:0078
class-ID: 0300
Device-3: 1-4:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Blackmagic design DaVinci Resolve Speed Editor
type: HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1edb:da0e class-ID: 0300 serial: <filter>
Device-2: 3-2:3 info: BEHRINGER GmbH UMC204HD 192k type: Audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 1397:0508 class-ID: fe01
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 59.2 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1127
Processes: 405 Uptime: 40m wakeups: 4 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1605 pm: dpkg
pkgs: 1 pm: pacman pkgs: 1604 libs: 374 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.25
this might be helpful:
https://wiki.archlinux.org/title/DaVinci_Resolve
is the opencl-mesa driver installed ?
No, I uninstalled it.
In fact, the program was running. Suddenly doesn’t open and mark a segmentation fault.
