I have an Asus notebook with hybrid display vga (intel+nvidia, and I don’t care if I can’t use both cards) with that setup:
I want to use the notebook HDMI output with my main monitor (28" samsung which is a 4k monitor but I’m using with the resolution: 2560 x 1440) and the second monitor with this USB-C dock with HDMI output, which is a LG, 23" FullHD 1920x1080). I’m not using the notebook screen, but it works fine if I want.
The USB-C dock is that one: https://baseus.com.bd/product/baseus-metal-gleam-series-6-in-1-multifunctional-type-c-hub-docking-station-gray-cahub-cw0g/
I tried to follow the instructions here: DisplayLink - ArchWiki with some tips from others websites without luck.
In the end I got a black screen that I was able to solve with timeshift backup.
Currently I just use my 28" samsung connected on the notebook HDMI output.
dmesg after connected the USB-C Dock.
[ 1054.038950] usb 1-2: new high-speed USB device number 9 using xhci_hcd
[ 1054.179504] usb 1-2: New USB device found, idVendor=1a40, idProduct=0801, bcdDevice= 1.00
[ 1054.179518] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1054.179523] usb 1-2: Product: USB 2.0 Hub
[ 1054.180728] hub 1-2:1.0: USB hub found
[ 1054.180784] hub 1-2:1.0: 4 ports detected
[ 1054.302368] usb 2-2: new SuperSpeed USB device number 4 using xhci_hcd
[ 1054.326422] usb 2-2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[ 1054.326437] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1054.326442] usb 2-2: Product: USB3.1 Hub
[ 1054.326446] usb 2-2: Manufacturer: GenesysLogic
[ 1054.329165] hub 2-2:1.0: USB hub found
[ 1054.329982] hub 2-2:1.0: 4 ports detected
[ 1054.458964] usb 1-2.2: new high-speed USB device number 10 using xhci_hcd
[ 1054.555454] usb 1-2.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 1054.555468] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1054.555474] usb 1-2.2: Product: USB2.1 Hub
[ 1054.555479] usb 1-2.2: Manufacturer: GenesysLogic
[ 1054.557181] hub 1-2.2:1.0: USB hub found
[ 1054.557516] hub 1-2.2:1.0: 4 ports detected
[ 1054.632478] usb 2-2.2: new SuperSpeed USB device number 5 using xhci_hcd
[ 1054.650815] usb 2-2.2: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
[ 1054.650830] usb 2-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 1054.650836] usb 2-2.2: Product: USB 10/100/1000 LAN
[ 1054.650840] usb 2-2.2: Manufacturer: Realtek
[ 1054.650844] usb 2-2.2: SerialNumber: 000001
[ 1054.733394] usb 2-2.2: reset SuperSpeed USB device number 5 using xhci_hcd
[ 1054.775766] r8152 2-2.2:1.0: load rtl8153a-4 v2 02/07/20 successfully
[ 1054.803765] r8152 2-2.2:1.0 eth0: v1.12.12
[ 1055.818938] usb 1-2.1: new full-speed USB device number 11 using xhci_hcd
[ 1055.951037] usb 1-2.1: not running at top speed; connect to a high speed hub
[ 1055.989512] usb 1-2.1: New USB device found, idVendor=25a4, idProduct=9311, bcdDevice= 2.01
[ 1055.989526] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1055.989531] usb 1-2.1: Product: USB C Video Adaptor
[ 1055.989536] usb 1-2.1: Manufacturer: USB C
[ 1055.989540] usb 1-2.1: SerialNumber: 000000000001
[ 1056.067258] r8152 2-2.2:1.0 enp0s20f0u2u2: renamed from eth0
[ 1058.257044] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 1058.257076] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1058.257084] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[ 1058.257096] pcieport 0000:00:1c.5: [ 0] RxErr (First)
lsusb before and after connected the Dock
~ lsusb ✔
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 008: ID 8087:0a2a Intel Corp. Bluetooth wireless interface
Bus 001 Device 006: ID 13d3:5a07 IMC Networks VGA UVC WebCam
Bus 001 Device 004: ID 1ea7:0907 SHARKOON Technologies GmbH Keyboard
Bus 001 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
~ lsusb ✔
Bus 002 Device 009: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 002 Device 008: ID 05e3:0626 Genesys Logic, Inc. Hub
Bus 001 Device 016: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 017: ID 25a4:9311 USB C USB C Video Adaptor
Bus 001 Device 015: ID 1a40:0801 Terminus Technology Inc. USB 2.0 Hub
~ xrandr --listproviders ✔
Providers: number : 2
Provider 0: id: 0x43 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 2 associated providers: 0 name:modesetting
Provider 1: id: 0x256 cap: 0x0 crtcs: 0 outputs: 0 associated providers: 0 name:NVIDIA-G0
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=d4948077-1761-4004-81d9-bc63efeb92f6 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=51e944f6-39af-4a27-81e1-c0e832af5ab6 udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: ASUSTeK product: X510URR v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X510URR v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X510URR.307 date: 03/13/2018
ID-1: BAT0 charge: 26.6 Wh (100.0%) condition: 26.6/42.1 Wh (63.2%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 35
RAM: total: 15.52 GiB used: 5.95 GiB (38.4%)
RAM Report:
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 32012
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 930MX] vendor: ASUSTeK driver: nvidia
v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:134e class-ID: 0302
Device-3: USB C USB C Video Adaptor type: USB driver: N/A bus-ID: 1-2.1:17
chip-ID: 25a4:9311 class-ID: 1100 serial: <filter>
Device-4: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:6 chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :1
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: HDMI-1 res: 2560x1440 hz: 60 dpi: 103
size: 632x360mm (24.9x14.2") diag: 727mm (28.6")
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:095a class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-2.2:9 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u2u2 state: down mac: <filter>
bus-ID: 1-8:8 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 456.46 GiB used: 29.5 GiB (6.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R013 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS250G2B0B-00YS70 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 30WD
scheme: GPT
ID-1: / raw-size: 108.4 GiB size: 108.4 GiB (100.00%) used: 21.7 GiB (20.0%)
fs: btrfs dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: d4948077-1761-4004-81d9-bc63efeb92f6
ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
used: 568 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 7AED-2BCE
ID-3: /home raw-size: 108.4 GiB size: 108.4 GiB (100.00%)
used: 7.8 GiB (7.2%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20 label: N/A
uuid: be417a0c-ee4a-4dd8-8ab7-792a9aa50e27
ID-4: /var/cache raw-size: 108.4 GiB size: 108.4 GiB (100.00%)
used: 21.7 GiB (20.0%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19 label: N/A
ID-5: /var/log raw-size: 108.4 GiB size: 108.4 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.7 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 51e944f6-39af-4a27-81e1-c0e832af5ab6
ID-1: /dev/sda1 maj-min: 8:1 size: 16 GiB fs: swap label: N/A
uuid: 4f5da1e8-00c1-492d-99c8-29c3252be89f
ID-2: /dev/sda2 maj-min: 8:2 size: 100 GiB fs: ext4 label: N/A
uuid: f001bf6c-1a89-40aa-a28e-fa6baa5c3f2f
ID-3: /dev/sda3 maj-min: 8:3 size: 107.08 GiB fs: ext4 label: N/A
uuid: 41795c6a-6991-4468-adf4-474044a18588
ID-4: /dev/sda4 maj-min: 8:4 size: 500 MiB fs: vfat label: N/A
uuid: 8219-5AB3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Hub-2: 1-2:15 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 1-2.1:17 info: USB C USB C Video Adaptor type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 25a4:9311
Hub-3: 1-2.2:16 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3:4 info: SHARKOON Keyboard type: Keyboard,HID
driver: semitek,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 1ea7:0907 class-ID: 0300 serial: <filter>
Device-2: 1-6:6 info: IMC Networks VGA UVC WebCam type: Video
Device-3: 1-8:8 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-4: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-2:8 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Device-1: 2-2.2:9 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 47.0 C pch: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3100
Processes: 349 Uptime: 40m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1245 lib: 306
flatpak: 0 Shell: Zsh v: 5.8 running-in: tabby inxi: 3.3.12
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 16384 x 16384
eDP-1 connected (normal left inverted right x axis y axis)
1920x1080 59.98 + 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 632mm x 360mm
3840x2160 30.00 29.97
2560x1440 59.95*
1920x1080 60.00 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
I recently did a full manjaro clean install, it’s running X11, I checked it.
I also have a desktop that I can use to install the distro and do every type of test that can potentially break my system just to prevent it to happens on my notebook.
Any help will be appreciated.
