USB boot grub freezes
Hello there,
After I downloaded latest manjaro version(17.0.1), I created a bootable usb with “dd” but I have some problems with it. It freezes on boot-up process actually it freezes at the beginning of grub. It tries to load grub but then suddenly stuck there. It says “Grub loading” then “Welcome to Grub” then nothing. I tried different ways like changing the usb drive, using different burning software “etcher” but it still has same problem. Any idea about this ? btw, i checked sha1sum and download same iso again.
Are you using windows to create the USB?
If so try isotousb download from isotousb.com
No i created on Linux
Sorry - you did try dd - said in the first line. So I assume you also use sync to ensure data is written before removal?
Some times an usb-stick has to be destroyed to behave
sudo dd if=/dev/zero of=/dev/sdX bs=1M count=10
I have manjaro-tools installed and I buildiso -p isoprofile and they have only failed me once building kibojoe profile for i686 - the official profiles I have no problems with.
You could try boot the iso in a virtualbox - to see if it is hardware or iso-related issue.
Edit
I discovered that a faulty drive can cause the iso to malfunction. I had a drive that suddenly generated bad sectors - the smart system relocated readable data but that was/is not quite enough when talking large ISO files.
Yes.
I tried it in a vbox there was no problem with iso it perfectly installed. I think I have hardware issues.
I tried different distro iso burned with dd and it perfectly worked. I suppose that my usb drive is fine but I do not want to install old version of manjaro and install it then update the latest version. It is too much work.
You can build your own ISO.
sudo pacman -S manjaro-tools
Then you build your preferred edition with
buildiso -p {kde|gnome|xfce} [-b {stable|testing|unstable}]
the resulting ISO is even more up-to-date than the one you download
In the default configuration you iso ends up in
/var/cache/manjaro-tools/iso/manjaro/{edition}/gellivara
A more indepth description you find at Github
