USB and Network ocassional disconnection
I’ve encountered an issue where when I try to connect a USB HDD it doesn’t seem to be recognized. After that I tried connecting another USB device and then my wired network stopped working and my keyboard disconnected. Fortunately I still was able to use my mouse so I rebooted my computer and all devices seem to be working now. Even the storage drives I was trying to connect earlier.
The full inxi output is as follows:
  Kernel: 6.13.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=eb6bca57-10a8-411f-8fed-4ab5687a043b rw quiet splash
    resume=UUID=496d3daa-0c0a-43e1-9641-e1fe92c70c1d udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
    UEFI: American Megatrends v: 2006 date: 03/19/2021
  System RAM: total: 16 GiB available: 15.5 GiB used: 3.08 GiB (19.8%)
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KHX3200C16D4/8GX serial: <filter>
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1752 min/max: 550/4851 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1752 2: 1752 3: 1752
    4: 1752 5: 1752 6: 1752 7: 1752 8: 1752 9: 1752 10: 1752 11: 1752 12: 1752
    13: 1752 14: 1752 15: 1752 16: 1752 bogomips: 121600
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
    XT/6750 XT / 6800M/6850M XT] vendor: Tul / PowerColor Red Devil
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,DP-2 empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 09:00.0
    chip-ID: 1002:73df class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 5120x1440 display-ID: 0
  Monitor-1: DP-1 pos: primary,left model: MG700 serial: <filter>
    built: 2020 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 108 gamma: 1.2
    chroma: red: x: 0.678 y: 0.310 green: x: 0.200 y: 0.690 blue: x: 0.149
    y: 0.051 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 77 2: parse_edid:
    unhandled CEA mode 78
  Monitor-2: DP-2 pos: right model: MG700 serial: <filter> built: 2020 res:
    mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 108 gamma: 1.2 chroma: red:
    x: 0.678 y: 0.310 green: x: 0.200 y: 0.690 blue: x: 0.149 y: 0.051 white:
    x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
    navi22 LLVM 19.1.7 DRM 3.61 6.13.5-2-MANJARO) device-ID: 1002:73df
    memory: 11.72 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: N/A device-ID: 1002:73df
    surfaces: xcb,xlib,wayland
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 09:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: C-Media USB Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-4:4 chip-ID: 0d8c:0012 class-ID: 0300
  API: ALSA v: k6.13.5-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 6.41 TiB used: 4.72 TiB (73.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 38.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04ABB400
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 9203 scheme: GPT
  ID-1: / raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
    used: 37.13 GiB (19.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: eb6bca57-10a8-411f-8fed-4ab5687a043b
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: F51A-1007
  ID-3: /home raw-size: 1.66 TiB size: 1.63 TiB (98.37%)
    used: 1.05 TiB (64.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 1489f9ee-04e5-4cc0-9041-ed7bbc0ddd47
  ID-4: /run/media/chris/ADATA HD710 PRO raw-size: 3.64 TiB
    size: 3.64 TiB (100.00%) used: 3.64 TiB (99.9%) fs: ntfs dev: /dev/sdb2
    maj-min: 8:18 label: ADATA HD710 PRO uuid: 960C47E00C47B9CF
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 496d3daa-0c0a-43e1-9641-e1fe92c70c1d
  ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: N/A
    uuid: 65c3fece-0e1f-4387-96d0-311a1a1c65e1
  ID-2: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Device-1: 1-6:2 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-9:4 info: Keychron V10 Max type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:09a0 class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 2-4:2 info: A-DATA HD710 PRO type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 125f:a75a class-ID: 0806
    serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
    serial: <filter>
  Hub-5: 3-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-6: 3-3.4:5 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 3-4:4 info: C-Media USB Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 4-3:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-9: 4-3.4:3 info: Genesys Logic Hub ports: 4 rev: 3.2
  System Temperatures: cpu: 37.9 C mobo: N/A gpu: amdgpu temp: 54.0 C
    mem: 50.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 1546 pm: pacman pkgs: 1503 libs: 457 tools: pamac pm: flatpak
    pkgs: 43
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    9: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    10: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://mirrors2.manjaro.org/stable/$repo/$arch
    13: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    14: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    15: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    18: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    20: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    24: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    26: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    27: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    28: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    29: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    30: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    31: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    32: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    33: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    34: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    35: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    36: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    37: https://manjaro.ynh.ovh/stable/$repo/$arch
    38: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    39: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    40: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    41: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://mirror.init7.net/manjaro/stable/$repo/$arch
    43: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    44: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    45: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    46: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    47: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    48: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    50: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    51: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    52: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    53: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    54: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    55: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    56: https://mirror.23m.com/manjaro/stable/$repo/$arch
    57: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    58: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    59: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    60: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    61: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    62: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    63: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    64: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    65: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    66: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    67: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    68: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    69: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    70: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    71: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    72: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    73: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    75: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    76: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    77: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    78: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    79: http://manjaro.grena.ge/stable/$repo/$arch
    80: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    81: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    82: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    83: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    84: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    85: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    86: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    87: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    88: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    89: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    90: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    91: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    92: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    93: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    94: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    95: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    96: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    97: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    98: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    99: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    100: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 363
  1: cpu: 18.3% command: firefox pid: 1695 mem: 508.8 MiB (3.2%)
  2: cpu: 13.3% command: ./jetbrains-toolbox pid: 1440 mem: 306.2 MiB (1.9%)
  3: cpu: 11.5% command: firefox pid: 2019 mem: 386.6 MiB (2.4%)
  4: cpu: 4.3% command: kwin_wayland pid: 887 mem: 228.3 MiB (1.4%)
  5: cpu: 4.3% command: firefox pid: 1904 mem: 272.1 MiB (1.7%)
  Memory top: 5 of 363
  1: mem: 508.8 MiB (3.2%) command: firefox pid: 1695 cpu: 18.3%
  2: mem: 433.0 MiB (2.7%) command: plasmashell pid: 1145 cpu: 3.6%
  3: mem: 386.6 MiB (2.4%) command: firefox pid: 2019 cpu: 11.5%
  4: mem: 306.2 MiB (1.9%) command: ./jetbrains-toolbox pid: 1440 cpu: 13.3%
  5: mem: 289.5 MiB (1.8%) command: firefox pid: 2025 cpu: 4.0%
  Processes: 363 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
