USB 3.0 not going past the speed of USB 2.0
Hi, i noticed my External HDD’s are very slow when i try to transfer files between them: like 30Mb per second. They obviously are 3.0 devices, and in windows they read/wtite at 110Mb per second.
here the output of lsusb -t
[mosco@matebook ~]$ lsusb -t
/:  Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 480M
    |__ Port 001: Dev 002, If 0, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 001: Dev 002, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 002: Dev 003, If 0, Class=Hub, Driver=hub/5p, 480M
        |__ Port 002: Dev 005, If 0, Class=Vendor Specific Class, Driver=r8152, 480M
        |__ Port 003: Dev 008, If 0, Class=Mass Storage, Driver=usb-storage, 480M
        |__ Port 005: Dev 006, If 0, Class=Billboard, Driver=[none], 480M
    |__ Port 004: Dev 004, If 0, Class=Communications, Driver=[none], 12M
    |__ Port 004: Dev 004, If 1, Class=CDC Data, Driver=[none], 12M
/:  Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/:  Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
    |__ Port 001: Dev 002, If 0, Class=Wireless, Driver=btusb, 12M
    |__ Port 001: Dev 002, If 1, Class=Wireless, Driver=btusb, 12M
    |__ Port 002: Dev 003, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 002: Dev 003, If 1, Class=Video, Driver=uvcvideo, 480M
/:  Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 10000M
Could someone help me?
Thanks
Try plugging the external disk after booting the computer. This could help that USB 3.0 features are enabled.
Mass Storage device appears to be plugged in to an external hub on Bus 001
I suggest try using USB Bus 002 without a hub
Hi guys, thanks both for the answers!
My laptop is a Huawei Matebook with only 2 usb-c ports. Now i tried to plug one of my usb HDD to the right port without any hub and now it read/writes as is espected to be!
The Hub i used is the official matedock 3, i thought it is usb 3.0…
https://www.amazon.it/HUAWEI-Mate-Dock-HDMI-Bianco/dp/B087CPH45H
[EDIT] It is USB 3.0, but i need to plug in the port on the right side. (but in the right side it does not output the video… ) ooook!!
I suggest you post lsusb -t to show “working” USB connections for the viewers at home
Laptop and/or dock might not be able to deliver enough power for a USB display
Does the USB display device have it’s own power supply or a USB power connection?
Upgrade to a powered dock might help for using multiple USB devices
The dock can be powered. I use it on the left port because it can “pass trough” the power and charge the laptop. But i recently discovered it runs at usb 2.0
The right port has the video output, but it’s not able to charge the laptop.
However it has enough Power for two usb HDD’s
