Trying for several days now to get dual boot to work with windows 11. Had it working with windows 10 but decided to reinstall both OS.currently running of live usb.
cat /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT=""
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to enable Hidden Menu, and optionally hide the timeout count
#GRUB_HIDDEN_TIMEOUT=5
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
--- grub.default 2021-11-26 15:55:23.058073000 -0700
+++ grub.yours 2021-11-26 15:59:02.326512652 -0700
@@ -1,22 +1,19 @@
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
-GRUB_TIMEOUT_STYLE=hidden
-GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
+GRUB_CMDLINE_LINUX_DEFAULT=""
-# Uncomment to disable submenus in boot menu
-#GRUB_DISABLE_SUBMENU=y
-# Uncomment to enable booting from LUKS encrypted devices
-#GRUB_ENABLE_CRYPTODISK=y
+# Uncomment to enable Hidden Menu, and optionally hide the timeout count
+#GRUB_HIDDEN_TIMEOUT=5
+#GRUB_HIDDEN_TIMEOUT_QUIET=true
@@ -26,23 +23,20 @@
-# you can see them in real GRUB with the command 'videoinfo'
+# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
-# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
-# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
+# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
+# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
-# Uncomment this option to enable os-prober execution in the grub-mkconfig command
-#GRUB_DISABLE_OS_PROBER=false
-# Uncomment and set to the desired menu colors. Used by normal and wallpaper
+# Uncomment and set to the desired menu colors. Used by normal and wallpaper
@@ -53,10 +47,3 @@
-# Uncomment to ensure that the root filesystem is mounted read-only so that
-# systemd-fsck can run the check automatically. We use 'fsck' by default, which
-# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
-# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
-# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
-#GRUB_ROOT_FS_RO=true
There is no need to download the new iso. Just update your installation, preferably through pamac and you are good to go (perks of being a rolling release distro ).
New grub file,
I changed the time out and time_out_style to menu.
Now if I can ever dual boot it would be great.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=menu
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_GFXMODE=auto
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
I have done all but shut off fast start in windows. Will look into that. I only see windows in the boot menu without using a live usb to get into the boot menu if that makes sense.
Any output you need to see?
Just found out Fast Start in windows 11 only effects a restart and has no effect on power off.
cat /etc/default/grub ✔
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_GFXMODE=auto
