Let me summarize it shortly, so that I do understand it correctly:
Manjaro will be using the Mesa package without the codecs because Manjaro GmbH & Co KG has decided as such? And this decision is done because of (possible) patent infringements which will only affect US based companies (and therefore does not apply to a german GmbH)? And the only two solutions are “waste CPU time and don’t use your 1000times more efficient GPU” or “use AUR” (which is strictly not advised by Manjaro guidelines, which makes sense as AUR is expecting newest versions of depended packages which may be too old due to Manjaros slow rolling release, compared to Arch)?
Any error in this summary?
Strangely intel vaapi drivers are still in repo. Are they not trendy enough to be removed too?
Plus Nvidia is not open-source too, as I know ![]()
Do you mean @BaronKarza in Manjaro forum?
Idk who the person, but what else was expected from users who wanted to have hardware acceleration? So either stick with manjaro and try hacky inelegant solutions or just switch to a distro that supports hardware acceleration with its default packaged mesa.
It doesn’t pain me that manjaro removed support for patented codecs, but that they didn’t provide an alternative to existing users who are affected by the removal. Mesa-git from AUR is not a solution. Manually compiling mesa package is not a good solution. These are okay for small minor utilities, not a relatively big and important system package like mesa.
I am myself considering moving to arch on my amd machines (since intel ones still have VAAPI for some reason supported from packages on repo) by next week unless manjaro provides an alternate mesa package with patented codecs that users manually install from repos. I can’t see any reason to continue using a distro that requires me to turn to hacky solutions for basic functionality.
I checked VAAPI:
$ vainfo
Trying display: wayland
vainfo: VA-API version: 1.16 (libva 2.16.0)
vainfo: Driver version: Mesa Gallium driver 22.2.4 for AMD Radeon RX 5700 (navi10, LLVM 14.0.6, DRM 3.48, 6.0.11-1-MANJARO)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
It shows no H264 and no H265 support.
Video decoding
I checked mpv media player and twitch video stream on Firefox, they use ffmpeg, H.264 video decoding worked fine with AMD GPU hardware acceleration, CPU total usage is lower than 10% like before, nothing difference.
Video encoding
But I tried to test video encoding benchmark using ffmpeg with VAAPI
ffmpeg -hwaccel vaapi -i <YOUR_VIDEO_FILE.mp4> -f null - -benchmark
AMD CPU total usage is higher than 60%. It seem video encoding is affected when using AMD GPU and mesa. Intel iCPU has no issue.
It means that the video itself was not high enough bitrate to tax your CPU. You do not have AMD GPU hardware acceleration for H.264. Congrats on having a good CPU though
Btw, if you want to test encode or decode, download some utility like nvtop. Enable the decode and encode charts from its config
That is awesome app, thank you!
If someone is interested in just using manjaro’s builds of mesa but with support for patented codecs, they can use this simple script
#!/bin/bash
cd /tmp/
git clone https://gitlab.manjaro.org/packages/extra/mesa.git
cd /tmp/mesa/
sed -i '/-D microsoft-clc=disabled \\/a \ -D video-codecs=vc1dec,h264dec,h264enc,h265dec,h265enc \\' PKGBUILD
makepkg -si
cd /tmp/
rm -Rf mesa
I have no idea what the best way to automate it would be. Would be nice if someone could advise me on that front. If this script could be automated with manjaro’s mesa updates, I would not bother switching to arch (compiling does not take much time when all the files are stored in ram).
Also, probably add all the gpg keys in the PKGBUILD before running it.
Now at work, but later I will try
(this post is complete edited, former link was 404 today)
…edited the packagebuild (and this time no new checksum, no gpg-keys that ended in restore with timeshift) .
reboot successful
Source:
Timeshift is my friend, but still this is suboptimal.
vainfo
Trying display: x11
vainfo: Driver version: Mesa Gallium driver 22.2.4 for AMD Radeon Graphics (rembrandt, LLVM 14.0.6, DRM 3.48, 6.0.11-1-MANJARO)
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileAV1Profile0 : VAEntrypointVLD
…so, now lets test if this really works.
I was being cheeky…
But, yeah, given @milkytwix’s summary I’m with @BaronKarza on this.
I didn’t pay for Manjaro so, I have no justification to ask the maintainers to take a (however remote) legal risk just so that I can save 20 minutes or so - a month - compiling a single package.
However, if I was inclined to compile my own packages… I’d run Gentoo.
for the time being you can avoid recompilation and resort to this;
Why would you only opt to install mesa from the entire stack from arch repos? Either go all in or none. Otherwise you will soon have incompatible versions of mesa with vulkan drivers etc.
read again, there is a disclaimer. FYI of the entire mesa-stack that you speak of, manjaro has only replaced mesa package only, rest of the stack is as is from arch. (atleast for now)
If you care to take a look at the PKGBUILD, you will see there are quite a few packages involved:
pkgname=(‘vulkan-mesa-layers’ ‘opencl-mesa’ ‘vulkan-intel’ ‘vulkan-radeon’ ‘vulkan-swrast’ ‘libva-mesa-driver’ ‘mesa-vdpau’ ‘mesa’)`
excuse my possible naivety. i’m learning here.
i find the same set of packages in both PKGBUILD (here is arch’s PKGBUILD for comparison) there are indeed 8 packages involved, but they are the same. BTW arch mesa has an additional patch, that manjaro does not :-p
of the packages in question, to-date, manjaro has only altered package “mesa”, the rest of it is still inherited as built by arch.
i know this is only relevant for now(this build), but what are the pitfalls in substituting manjaro’s package with arch’s
All the split packages in mesa and lib32-mesa are now built by Manjaro, without patent encumbered codec support. That means you need to replace all of the core and split packages if you want hardware acceleration back without messing up your system.
Example:
pacman -Qi vulkan-mesa-layers | grep Packager
Packager : Philip Müller <philm@manjaro.org>
This is basically no solution and less experienced people are left out in the dark!
This should’ve been communicated with the community before any changes were made, to try finding a different solution, but it didn’t happen.
When will the rest of the patent infringing stuff be removed? It seems the Intel VAAPI drivers are still there, along with x264 and x265. Fedora doesn’t ship any of that.
