Slayd
1
I’m getting my openbox set up. Conky is “reporting” the local weather at my location as
Cloudy, 9C.
I’ve changed the only conky rc file I have to show temperature_unit = ‘fahrenheit’,
I tried moving it to the top of the rc file as was tried by someone, but I’m still getting 9C.
I noticed that the weather and weather.raw files in the accu_weather directory both report the temp as 9C.
I went to accuweather.com and made sure my settings specified Imperial and not Metric.
I don’t know what else to try.
Steve
Share your conkyrc file. You can try adding --unit=F
after the specified command to show temps in fahrenheit.
The script contains the following command to pull the rss feed for the given location
address="https://rss.accuweather.com/rss/liveweather_rss.asp?metric=1&locCode=${REGION_ID}|${COUNTRY_ID}|${LOCATION_KEY}|${LOCALIZED_NAME}"
To have Fahrenheit instead of Celcius - change the metric=1 to metric=0 and save the script
Slayd
4
Your script change selection worked, linux-aarhus.
Thank you
system
Closed
5
