Upgrade to 4.19 disables my amdgpu
#1
Hi, I am running an AMD FX8320 cpu with AMD R9 290x vid card. Using rEfind bootloader and running kernel 4.18. Everything was running smoothly until I upgraded the kernel to 4.19. Now I get a blank screen on boot.
Alt-F1-7 don’t work, still blank. Have to hit reset button to restart my computer and use nomodeset to get a text login screen on Alt-F2.
seeing EE open /dev/dri/card0: no such file or directory
EE screen 0 deleted because of no maching config
EE Devic(s) detected but non mach those in config file
I’m using video-amdgpu-experimental drivers
I’m a newb at this. Please help.
Can't get my amdgpu drivers to work. Stuck on radeon
#2
ok
you should have 2 kernels installed
linux418 & linux419
on boot Grub , choose details and select kernel 418
if you have put Grub-quiet
press and hold Shift or Esc or F8 on start to see Grub
#3
Thanks for replying, but I don’t have grub. I’m using refind instead. I can boot into 4.18 though.
#4
can you return
sudo pacman -Qs linux418-
sudo pacman -Qs linux419-
sudo journalctl -b -n - p 4
 ( n = 1 boot before , 2 boot before , etc  , when you have tried 419 )
provides also
inxi -SMGxxxz
#5
#6
this is a bug
https://bugs.freedesktop.org/show_bug.cgi?id=108260
STAY on linux 414 or 418
you can add headers
sudo pacman -S linux419-headers
#7
Oh ok. Installed headers but no change. I’ll stick to 418.
Thank you so much for your time.
#8
when patche will coming
you will have to change driver amdgpu --> radeon free for 419
#9
How do I do that?
#10
@tids may be answer for that i hope
#11
What exactly do you use? We do not ship MHWD settings for amdgpu-experimental anymore. If you just use the amdgpu-experimental package, its save to uninstall this one and reboot to go back to radeon.
#12
This is what I have installed
#13
With Sea Islands dont you have to add to options at /etc/default/grub
radeon.cik_support=0 amdgpu.cik_support=1
(and run sudo update-grub)
and add amdgpu to the front of MODULES in /etc/mkinitcpio.conf
(and then run sudo mkinitcpio -P)
[And reboot]
Have you done those things ?
#14
No I haven’t. I’m not using grub. I’m using reFind instead. Everything just worked.
#15
I am gonna assume the amdgpu experimental wasn’t playing well with the new kernel. Should uninstall it and only keep video-linux
#16
If using refind those options go in /boot/refind_linux.conf
(quiet is usually present for you to tell where they go)
#17
It could be related to that amdgpu experimental in mhwd. mhwd-db-amdgpu-experimental That one is not supported since forever and was never ported to the new “how to enable experimental support”. It shouldnt be there anymore for a long time but for some reason it still it.
@neoxjr try to uninstall that from mhwd (if possible):
mhwd -r pci $(mhwd -li | grep "video-" | awk '{print $1}')
if this works (only if), Otherwise please post the output.
pacman -R mhwd-db-amdgpu-experimental
next
mhwd -a pci nonfree 0300
So you’re back at radeon for now.
#18
This worked. Used @Tids option to remove using mhwd. Now I’m on video-linux with 419
I tried this first with reFind config but didn’t do anything
this is my inxi -SMGxxxz output now
Host: emmanuel-pc Kernel: 4.19.1-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.2.1 Desktop: Xfce 4.12.4 tk: Gtk 2.24.32 info: xfce4-panel wm: xfwm4
dm: LightDM 1.28.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: M5A99FX PRO R2.0 v: Rev 1.xx
serial: UEFI: American Megatrends v: 2501 date: 04/07/2014
Device-1: AMD Hawaii PRO [Radeon R9 290/390] vendor: ASUSTeK
driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:67b1
Display: x11 server: X.Org 1.20.3 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD HAWAII (DRM 2.50.0 4.19.1-1-MANJARO LLVM 7.0.0)
v: 4.5 Mesa 18.2.4 compat-v: 4.4 direct render: Yes
#19
Big thank you to everyone for helping me fix this. I know I could have just stayed with 418 but it was just bugging me that the newer one wasn’t working.
Didn’t know about this. I’ve been using it for a while for all my Steam games and now that I can play PC games through Steam I wanted the best performance I could get.
#20
If you’re back on the default radeon and there are no bits left of the mhwd config (hopefully). You should be able to switch to amdgpu with the amdgpu-experimental package.
I couldnt test it with your card, but with a R7 240 and 4.19 it works. :thinking:
If not you can uninstall that package to switch back to radeon.
