I’ve just reinstalled Manjaro onto a new hard drive after a recent failed upgrade killed my old Manjaro distro.
However, since installing Manjaro XFCE linux kernel 5.9.16_1 I’m getting random lockups. Yesterday I had 5 in the same day and had to hard power off.
The system sometimes just goes into and endless stutter and becomes completely unresponsive, or occasionally it drops out of the desktop session back to login (happened a couple of times)
When it properly locks up its virtually instantaneous and CTRL+ALT+DELETE does nothing.
It’s driving me mad - it’s a dual boot machine and Windows 10 works fine without crashes making me think its a driver issue. I also ran a memtest86 and found no errors after an hour (I’ll run it overnight tonight)
Thanks for any help in advance!
inxi -Fazy
ystem:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=de1991d5-6d23-4af7-bb3a-cc5062107c86 ro quiet pci=noaer apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: X99 Extreme6 serial: N/A
UEFI [Legacy]: American Megatrends v: P3.50 date: 04/06/2018
Info: 6-Core model: Intel Core i7-5820K socket: LGA2011-3 bits: 64
type: MT MCP arch: Haswell family: 6 model-id: 3F (63) stepping: 2
microcode: 44 L1 cache: 384 KiB L2 cache: 15 MiB L3 cache: 14.6 MiB
bogomips: 79205
Speed: 3599 MHz min/max: 1200/3600 MHz base/boost: 3300/4000 volts: 0.0 V
ext-clock: 100 MHz Core speeds (MHz): 1: 3599 2: 3299 3: 1200 4: 1315
5: 1657 6: 2299 7: 1200 8: 1405 9: 3599 10: 3299 11: 1678 12: 2299
Type: l1tf
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: Micro-Star MSI
driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 03:00.0
chip ID: 10de:13c0
Display: server: X.Org 1.20.10 driver: loaded: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x318mm (40.0x12.5")
s-diag: 1065mm (41.9")
Monitor-1: DVI-I-1 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: GeForce GTX 980/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
direct render: Yes
Device-1: Intel C610/X99 series HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8d20
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 10de:0fbb
Device-3: Logitech OrbiCam type: USB driver: snd-usb-audio,uvcvideo
bus ID: 5-1:2 chip ID: 046d:0892 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Ethernet I218-V vendor: ASRock driver: e1000e v: kernel
port: f000 bus ID: 00:19.0 chip ID: 8086:15a1
IF: enp0s25 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: ASRock
driver: alx v: kernel port: d000 bus ID: 05:00.0 chip ID: 1969:10a1
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
v: kernel port: d000 bus ID: 07:00.0 chip ID: 168c:0032
IF: wlp7s0 state: down mac: <filter>
IF-ID-1: br-3bc0a45a53cb state: down mac: <filter>
IF-ID-2: br-bf48325dd5e0 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Local Storage: total: 1.36 TiB used: 213.9 GiB (15.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 3B7QCXE7 temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0A-00SM50 size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 00WD
ID-1: / raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 213.9 GiB (23.4%) fs: ext4 block size: 4096 B dev: /dev/sda1
maj-min: 8:1
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 280 Uptime: 44m wakeups: 1 Memory: 15.56 GiB
used: 3.52 GiB (22.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1406 lib: 378 flatpak: 0 Shell: Bash (sudo) v: 5.1.0
running in: yakuake inxi: 3.2.02
sudo dmesg -l emerg,alert,crit,err,warn
[ 0.136588] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.136588] #7 #8 #9 #10 #11
[ 0.408327] pmd_set_huge: Cannot satisfy [mem 0xf1000000-0xf1200000] with a huge-page mapping due to MTRR override.
[ 3.018428] usb 2-8: device descriptor read/64, error -71
[ 3.122972] nvidia: loading out-of-tree module taints kernel.
[ 3.122979] nvidia: module license 'NVIDIA' taints kernel.
[ 3.122980] Disabling lock debugging due to kernel taint
[ 3.252118] usb 2-8: device descriptor read/64, error -71
[ 3.266504] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.32.03 Sun Dec 27 19:00:34 UTC 2020
[ 3.605095] usb 2-8: device descriptor read/64, error -71
[ 3.835098] usb 2-8: device descriptor read/64, error -71
[ 4.585184] usb 2-8: Device not responding to setup address.
[ 4.791851] usb 2-8: Device not responding to setup address.
[ 4.998416] usb 2-8: device not accepting address 7, error -71
[ 5.121848] usb 2-8: Device not responding to setup address.
[ 5.328513] usb 2-8: Device not responding to setup address.
[ 5.349901] kauditd_printk_skb: 30 callbacks suppressed
[ 5.535081] usb 2-8: device not accepting address 8, error -71
[ 5.535124] usb usb2-port8: unable to enumerate USB device
[ 21.673491] i2c i2c-0: Systems with more than 4 memory slots not supported yet, not instantiating SPD
[ 22.097917] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.097920] EDAC sbridge: Couldn't find mci handler
[ 22.097922] EDAC sbridge: Failed to register device with error -19.
[ 22.199056] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.199060] EDAC sbridge: Couldn't find mci handler
[ 22.199061] EDAC sbridge: Failed to register device with error -19.[ 0.136588] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 22.247094] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.247100] EDAC sbridge: Couldn't find mci handler
[ 22.247101] EDAC sbridge: Failed to register device with error -19.
[ 22.343087] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.343096] EDAC sbridge: Couldn't find mci handler
[ 22.343099] EDAC sbridge: Failed to register device with error -19.
[ 22.459196] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.459200] EDAC sbridge: Couldn't find mci handler
[ 22.459201] EDAC sbridge: Failed to register device with error -19.
[ 22.622484] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.622487] EDAC sbridge: Couldn't find mci handler
[ 22.622487] EDAC sbridge: Failed to register device with error -19.
[ 22.715665] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.715668] EDAC sbridge: Couldn't find mci handler
[ 22.715669] EDAC sbridge: Failed to register device with error -19.
[ 22.779376] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.779383] EDAC sbridge: Couldn't find mci handler
[ 22.779385] EDAC sbridge: Failed to register device with error -19.
[ 22.903627] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 22.903638] EDAC sbridge: Couldn't find mci handler
[ 22.903641] EDAC sbridge: Failed to register device with error -19.
[ 23.038203] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 23.038206] EDAC sbridge: Couldn't find mci handler
[ 23.038208] EDAC sbridge: Failed to register device with error -19.
[ 23.169819] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 23.169826] EDAC sbridge: Couldn't find mci handler
[ 23.169828] EDAC sbridge: Failed to register device with error -19.
[ 23.290120] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 23.290130] EDAC sbridge: Couldn't find mci handler
[ 23.290133] EDAC sbridge: Failed to register device with error -19.
[ 24.091934] gspca_vc032x: reg_r err -32
[ 24.091954] vc032x: probe of 5-1:1.0 failed with error -32
[ 28.687978] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
[ 43.070234] kauditd_printk_skb: 70 callbacks suppressed
[ 53.237985] kauditd_printk_skb: 13 callbacks suppressed
[ 1899.887188] kauditd_printk_skb: 7 callbacks suppressed
(All my memory is non ECC)
cat /var/log/Xorg.0.log.old
[ 29.347]
X.Org X Server 1.20.10
[ 29.347] Build Operating System: Linux Manjaro Linux
[ 29.347] Current Operating System: Linux jamie-desktop 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[ 29.347] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=de1991d5-6d23-4af7-bb3a-cc5062107c86 ro quiet pci=noaer apparmor=1 security=apparmor udev.log_priority=3
[ 29.347] Build Date: 16 December 2020 10:33:32PM
[ 29.347]
[ 29.347] Current version of pixman: 0.40.0
[ 29.347] Before reporting problems, check http://wiki.x.org
[ 29.347] Markers: (--) probed, (**) from config file, (==) default setting,
[ 29.347] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 29 11:41:24 2021
[ 29.351] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 29.351] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 29.355] (==) ServerLayout "layout"
[ 29.355] (**) |-->Screen "Screen0" (0)
[ 29.355] (**) | |-->Monitor "Monitor0"
[ 29.355] (**) | |-->Device "Device0"
[ 29.355] (==) Automatically adding devices
[ 29.355] (==) Automatically enabling devices
[ 29.355] (==) Automatically adding GPU devices
[ 29.355] (==) Automatically binding GPU devices
[ 29.355] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 29.358] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 29.358] Entry deleted from font path.
[ 29.358] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 29.358] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 29.358] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 29.358] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 29.358] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 29.358] (**) Extension "COMPOSITE" is enabled
[ 29.358] (II) The server relies on udev to provide the list of input devices.
[ 29.358] (II) Module ABI versions:
[ 29.358] X.Org ANSI C Emulation: 0.4
[ 29.358] X.Org Video Driver: 24.1
[ 29.358] X.Org XInput driver : 24.1
[ 29.358] X.Org Server Extension : 10.0
[ 29.359] (++) using VT number 7
[ 29.359] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 29.359] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 29.364] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 29.364] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 29.367] (--) PCI:*(3@0:0:0) 10de:13c0:1462:3170 rev 161, Mem @ 0xfa000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 29.367] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 29.367] (II) LoadModule: "glx"
[ 29.369] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 29.558] (II) Module glx: vendor="X.Org Foundation"
[ 29.558] compiled for 1.20.10, module version = 1.0.0
[ 29.558] ABI class: X.Org Server Extension, version 10.0
[ 29.558] (II) LoadModule: "nvidia"
[ 29.559] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 29.564] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 29.564] compiled for 1.6.99.901, module version = 1.0.0
[ 29.564] Module class: X.Org Video Driver
[ 29.565] (II) NVIDIA dlloader X Driver 460.32.03 Sun Dec 27 18:56:00 UTC 2020
[ 29.565] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 29.566] (II) Loading sub module "fb"
[ 29.566] (II) LoadModule: "fb"
[ 29.567] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 29.569] (II) Module fb: vendor="X.Org Foundation"
[ 29.569] compiled for 1.20.10, module version = 1.0.0
[ 29.569] ABI class: X.Org ANSI C Emulation, version 0.4
[ 29.569] (II) Loading sub module "wfb"
[ 29.569] (II) LoadModule: "wfb"
[ 29.569] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 29.570] (II) Module wfb: vendor="X.Org Foundation"
[ 29.570] compiled for 1.20.10, module version = 1.0.0
[ 29.570] ABI class: X.Org ANSI C Emulation, version 0.4
[ 29.570] (II) Loading sub module "ramdac"
[ 29.570] (II) LoadModule: "ramdac"
[ 29.570] (II) Module "ramdac" already built-in
[ 29.573] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 29.573] (==) NVIDIA(0): RGB weight 888
[ 29.573] (==) NVIDIA(0): Default visual is TrueColor
[ 29.573] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 29.573] (**) Option "AllowNVIDIAGpuScreens"
[ 29.573] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 29.573] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 29.573] (**) NVIDIA(0): Enabling 2D acceleration
[ 29.573] (II) Loading sub module "glxserver_nvidia"
[ 29.573] (II) LoadModule: "glxserver_nvidia"
[ 29.573] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 29.641] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 29.641] compiled for 1.6.99.901, module version = 1.0.0
[ 29.641] Module class: X.Org Server Extension
[ 29.641] (II) NVIDIA GLX Module 460.32.03 Sun Dec 27 18:53:34 UTC 2020
[ 29.642] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 30.443] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:3:0:0
[ 30.443] (--) NVIDIA(0): CRT-0
[ 30.443] (--) NVIDIA(0): DFP-0 (boot)
[ 30.443] (--) NVIDIA(0): DFP-1
[ 30.443] (--) NVIDIA(0): DFP-2
[ 30.443] (--) NVIDIA(0): DFP-3
[ 30.443] (--) NVIDIA(0): DFP-4
[ 30.443] (--) NVIDIA(0): DFP-5
[ 30.443] (--) NVIDIA(0): DFP-6
[ 30.443] (--) NVIDIA(0): DFP-7
[ 30.443] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 980 (GM204-A) at PCI:3:0:0 (GPU-0)
[ 30.443] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 30.443] (--) NVIDIA(0): VideoBIOS: 84.04.1f.00.f6
[ 30.443] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 30.459] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 30.459] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 30.491] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[ 30.491] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[ 30.491] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[ 30.522] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): connected
[ 30.522] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): Internal TMDS
[ 30.522] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): 600.0 MHz maximum pixel clock
[ 30.522] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 30.522] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 30.522] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 30.522] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 30.522] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 30.522] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 30.522] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 30.522] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 30.522] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 30.522] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 30.522] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 30.522] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 30.522] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 30.522] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 30.522] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 30.522] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 30.522] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 30.522] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 30.527] (==) NVIDIA(0):
[ 30.527] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 30.527] (==) NVIDIA(0): will be used as the requested mode.
[ 30.527] (II) NVIDIA(0): Validated MetaModes:
[ 30.527] (II) NVIDIA(0): "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[ 30.527] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 1200
[ 30.529] (--) NVIDIA(0): DPI set to (93, 95); computed from "UseEdidDpi" X config
[ 30.529] (--) NVIDIA(0): option
[ 30.530] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 30.530] (II) NVIDIA: access.
[ 30.531] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 30.531] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 30.531] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 30.531] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 30.531] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 30.531] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 30.531] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 30.531] (II) NVIDIA(0): Config Options in the README.
[ 30.554] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[ 30.609] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 30.609] (==) NVIDIA(0): Backing store enabled
[ 30.609] (==) NVIDIA(0): Silken mouse disabled
[ 30.609] (**) NVIDIA(0): DPMS enabled
[ 30.610] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 30.610] (II) Loading sub module "dri2"
[ 30.610] (II) LoadModule: "dri2"
[ 30.610] (II) Module "dri2" already built-in
[ 30.610] (II) NVIDIA(0): [DRI2] Setup complete
[ 30.610] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 30.611] (II) Initializing extension Generic Event Extension
[ 30.611] (II) Initializing extension SHAPE
[ 30.611] (II) Initializing extension MIT-SHM
[ 30.611] (II) Initializing extension XInputExtension
[ 30.611] (II) Initializing extension XTEST
[ 30.611] (II) Initializing extension BIG-REQUESTS
[ 30.611] (II) Initializing extension SYNC
[ 30.611] (II) Initializing extension XKEYBOARD
[ 30.611] (II) Initializing extension XC-MISC
[ 30.612] (II) Initializing extension SECURITY
[ 30.612] (II) Initializing extension XFIXES
[ 30.612] (II) Initializing extension RENDER
[ 30.612] (II) Initializing extension RANDR
[ 30.612] (II) Initializing extension COMPOSITE
[ 30.612] (II) Initializing extension DAMAGE
[ 30.612] (II) Initializing extension MIT-SCREEN-SAVER
[ 30.612] (II) Initializing extension DOUBLE-BUFFER
[ 30.612] (II) Initializing extension RECORD
[ 30.612] (II) Initializing extension DPMS
[ 30.612] (II) Initializing extension Present
[ 30.612] (II) Initializing extension DRI3
[ 30.612] (II) Initializing extension X-Resource
[ 30.612] (II) Initializing extension XVideo
[ 30.612] (II) Initializing extension XVideo-MotionCompensation
[ 30.612] (II) Initializing extension GLX
[ 30.613] (II) Initializing extension GLX
[ 30.613] (II) Indirect GLX disabled.
[ 30.613] (II) GLX: Another vendor is already registered for screen 0
[ 30.613] (II) Initializing extension XFree86-VidModeExtension
[ 30.613] (II) Initializing extension XFree86-DGA
[ 30.613] (II) Initializing extension XFree86-DRI
[ 30.613] (II) Initializing extension DRI2
[ 30.613] (II) Initializing extension NV-GLX
[ 30.613] (II) Initializing extension NV-CONTROL
[ 30.613] (II) Initializing extension XINERAMA
[ 30.734] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 30.734] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 30.734] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 30.734] (**) Power Button: Applying InputClass "system-keyboard"
[ 30.734] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 30.734] (II) LoadModule: "libinput"
[ 30.734] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 30.741] (II) Module libinput: vendor="X.Org Foundation"
[ 30.741] compiled for 1.20.8, module version = 0.30.0
[ 30.741] Module class: X.Org XInput Driver
[ 30.741] ABI class: X.Org XInput driver, version 24.1
[ 30.741] (II) Using input driver 'libinput' for 'Power Button'
[ 30.741] (**) Power Button: always reports core events
[ 30.741] (**) Option "Device" "/dev/input/event1"
[ 30.741] (**) Option "_source" "server/udev"
[ 30.749] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 30.749] (II) event1 - Power Button: device is a keyboard
[ 30.749] (II) event1 - Power Button: device removed
[ 30.761] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 30.761] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 30.761] (**) Option "xkb_layout" "gb"
[ 30.761] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 30.777] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 30.777] (II) event1 - Power Button: device is a keyboard
[ 30.778] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 30.778] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 30.778] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 30.778] (**) Power Button: Applying InputClass "system-keyboard"
[ 30.778] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 30.778] (II) Using input driver 'libinput' for 'Power Button'
[ 30.778] (**) Power Button: always reports core events
[ 30.778] (**) Option "Device" "/dev/input/event0"
[ 30.778] (**) Option "_source" "server/udev"
[ 30.779] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 30.779] (II) event0 - Power Button: device is a keyboard
[ 30.779] (II) event0 - Power Button: device removed
[ 30.794] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 30.794] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 30.794] (**) Option "xkb_layout" "gb"
[ 30.794] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 30.795] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 30.796] (II) event0 - Power Button: device is a keyboard
[ 30.796] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event3)
[ 30.796] (II) No input driver specified, ignoring this device.
[ 30.796] (II) This device may have been added with another device file.
[ 30.797] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event4)
[ 30.797] (II) No input driver specified, ignoring this device.
[ 30.797] (II) This device may have been added with another device file.
[ 30.797] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event5)
[ 30.797] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event6)
[ 30.798] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event7)
[ 30.798] (II) No input driver specified, ignoring this device.
[ 30.798] (II) This device may have been added with another device file.
[ 30.798] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event8)
[ 30.799] (II) No input driver specified, ignoring this device.
[ 30.799] (II) This device may have been added with another device file.
[ 30.799] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event9)
[ 30.801] (II) config/udev: Adding input device Wacom Intuos PT S Pen (/dev/input/event23)
[ 30.801] (**) Wacom Intuos PT S Pen: Applying InputClass "evdev tablet catchall"
[ 30.801] (**) Wacom Intuos PT S Pen: Applying InputClass "libinput tablet catchall"
[ 30.801] (**) Wacom Intuos PT S Pen: Applying InputClass "Wacom USB tablet class"
[ 30.801] (**) Wacom Intuos PT S Pen: Applying InputClass "Wacom tablet class"
[ 30.801] (II) LoadModule: "wacom"
[ 30.801] (II) Loading /usr/lib/xorg/modules/input/wacom_drv.so
[ 30.809] (II) Module wacom: vendor="X.Org Foundation"
[ 30.809] compiled for 1.20.8, module version = 0.39.0
[ 30.809] Module class: X.Org XInput Driver
[ 30.809] ABI class: X.Org XInput driver, version 24.1
[ 30.809] (II) Build version: 0.39.0
[ 30.809] (II) wacom: Driver for Wacom graphics tablets: PenPartner, Graphire,
Graphire2 4x5, Graphire2 5x7, Graphire3 4x5, Graphire3 6x8,
Graphire4 4x5, Graphire4 6x8, BambooFun 4x5, BambooFun 6x8,
Bamboo1 Medium, Graphire4 6x8 BlueTooth, CTL-460, CTH-461, CTL-660,
CTL-461/S, Bamboo Touch, CTH-460/K, CTH-461/S, CTH-661/S1, CTH-461/L,
CTH-661/L, Intuos 4x5, Intuos 6x8, Intuos 9x12, Intuos 12x12,
Intuos 12x18, PTU600, PL400, PL500, PL600, PL600SX, PL550, PL800,
PL700, PL510, PL710, DTI520, DTF720, DTF720a, DTF521, DTU1931,
DTU2231, DTU1631, DTH1152, DTH1152, DTK2451, DTH2452, DTH2452,
Intuos2 4x5, Intuos2 6x8, Intuos2 9x12, Intuos2 12x12, Intuos2 12x18,
Intuos2 6x8 , Volito, PenStation, Volito2 4x5, Volito2 2x3,
PenPartner2, Bamboo, Bamboo1, Bamboo1 4x6, Bamboo1 5x8, Intuos3 4x5,
Intuos3 6x8, Intuos3 9x12, Intuos3 12x12, Intuos3 12x19,
Intuos3 6x11, Intuos3 4x6, Intuos4 4x6, Intuos4 6x9, Intuos4 8x13,
Intuos4 12x19, Intuos4 WL USB Endpoint,
Intuos4 WL Bluetooth Endpoint, Intuos5 touch S, Intuos5 touch M,
Intuos5 touch L, Intuos5 S, Intuos5 M, Intuos Pro S, Intuos Pro M,
Intuos Pro L, Cintiq 21UX, Cintiq 20WSX, Cintiq 12WX, Cintiq 21UX2,
Cintiq 24HD, Cintiq 22HD, Cintiq 24HD touch (EMR digitizer),
Cintiq 13HD, DTK2241, DTH2242, Cintiq 22HDT, Cintiq 27QHDT,
Cintiq 27QHDT, Mobilestudio Pro 13, MobileStudio Pro 16,
MobileStudio Pro 13, MobileStudio Pro 16, Cintiq 13 FHD Pro,
Cintiq 16 UHD Pro, Cintiq Pro 24, Cintiq Pro 32, Cintiq 13 FHD Pro,
Cintiq 16 UHD Pro, Cintiq Pro 24, Cintiq Pro 32, Cintiq Pro 24,
Mobilestudio Pro 13, MobileStudio Pro 16, MobileStudio Pro 13,
MobileStudio Pro 16, MobileStudio Pro 16, MobileStudio Pro 16,
TabletPC 0x90, TabletPC 0x93, TabletPC 0x97, TabletPC 0x9A,
CapPlus 0x9F, TabletPC 0xE2, TabletPC 0xE3, TabletPC 0xE5,
TabletPC 0xE6, TabletPC 0xEC, TabletPC 0xED, TabletPC 0xEF,
TabletPC 0x100, TabletPC 0x101, TabletPC 0x10D, TabletPC 0x116,
TabletPC 0x12C, TabletPC 0x4001, TabletPC 0x4004, TabletPC 0x5000,
TabletPC 0x5002, usb:172f:0024, usb:172f:0025, usb:172f:0026,
usb:172f:0027, usb:172f:0028, usb:172f:0030, usb:172f:0031,
usb:172f:0032, usb:172f:0033, usb:172f:0034, usb:172f:0035,
usb:172f:0036, usb:172f:0037, usb:172f:0038, usb:172f:0039,
usb:172f:0051, usb:172f:0052, usb:172f:0053, usb:172f:0054,
usb:172f:0055, usb:172f:0056, usb:172f:0057, usb:172f:0058,
usb:172f:0500, usb:172f:0501, usb:172f:0502, usb:172f:0503,
usb:1b96:0001, usb:17ef:6004
[ 30.810] (II) Using input driver 'wacom' for 'Wacom Intuos PT S Pen'
[ 30.810] (**) Wacom Intuos PT S Pen: always reports core events
[ 30.810] (**) Option "Device" "/dev/input/event23"
[ 30.864] (II) Wacom Intuos PT S Pen: type not specified, assuming 'stylus'.
[ 30.864] (II) Wacom Intuos PT S Pen: other types will be automatically added.
[ 30.864] (--) Wacom Intuos PT S Pen stylus: using pressure threshold of 851 for button 1
[ 30.864] (**) Wacom Intuos PT S Pen stylus: panscroll is 0
[ 30.864] (**) Wacom Intuos PT S Pen stylus: panscroll modified to 1300
[ 30.864] (--) Wacom Intuos PT S Pen stylus: maxX=15200 maxY=9500 maxZ=1023 resX=100000 resY=100000 tilt=enabled
[ 30.864] (II) Wacom Intuos PT S Pen stylus: hotplugging dependent devices.
[ 30.864] (EE) Wacom Intuos PT S Pen stylus: Invalid type 'cursor' for this device.
[ 30.864] (EE) Wacom Intuos PT S Pen stylus: Invalid type 'touch' for this device.
[ 30.864] (EE) Wacom Intuos PT S Pen stylus: Invalid type 'pad' for this device.
[ 30.864] (II) Wacom Intuos PT S Pen stylus: hotplugging completed.
[ 30.901] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:056A:0302.0004/input/input23/event23"
[ 30.901] (II) XINPUT: Adding extended input device "Wacom Intuos PT S Pen stylus" (type: STYLUS, id 8)
[ 30.901] (**) Wacom Intuos PT S Pen stylus: (accel) keeping acceleration scheme 1
[ 30.902] (**) Wacom Intuos PT S Pen stylus: (accel) acceleration profile 0
[ 30.902] (**) Wacom Intuos PT S Pen stylus: (accel) acceleration factor: 2.000
[ 30.902] (**) Wacom Intuos PT S Pen stylus: (accel) acceleration threshold: 4
[ 30.959] (II) config/udev: Adding input device Wacom Intuos PT S Pen (/dev/input/mouse0)
[ 30.959] (II) No input driver specified, ignoring this device.
[ 30.959] (II) This device may have been added with another device file.
[ 30.959] (II) config/udev: Adding input device Wacom Intuos PT S Finger (/dev/input/event24)
[ 30.959] (**) Wacom Intuos PT S Finger: Applying InputClass "evdev touchpad catchall"
[ 30.959] (**) Wacom Intuos PT S Finger: Applying InputClass "evdev tablet catchall"
[ 30.959] (**) Wacom Intuos PT S Finger: Applying InputClass "libinput touchpad catchall"
[ 30.959] (**) Wacom Intuos PT S Finger: Applying InputClass "libinput tablet catchall"
[ 30.959] (**) Wacom Intuos PT S Finger: Applying InputClass "Wacom USB tablet class"
[ 30.959] (**) Wacom Intuos PT S Finger: Applying InputClass "Wacom USB touchpad class"
[ 30.959] (**) Wacom Intuos PT S Finger: Applying InputClass "Wacom tablet class"
[ 30.960] (**) Wacom Intuos PT S Finger: Applying InputClass "Wacom touchpad class"
[ 30.960] (II) Using input driver 'wacom' for 'Wacom Intuos PT S Finger'
[ 30.960] (**) Wacom Intuos PT S Finger: always reports core events
[ 30.960] (**) Option "Device" "/dev/input/event24"
[ 31.014] (EE) Wacom Intuos PT S Finger: Invalid type 'stylus' for this device.
[ 31.014] (EE) Wacom Intuos PT S Finger: Invalid type 'eraser' for this device.
[ 31.014] (EE) Wacom Intuos PT S Finger: Invalid type 'cursor' for this device.
[ 31.014] (II) Wacom Intuos PT S Finger: type not specified, assuming 'touch'.
[ 31.014] (II) Wacom Intuos PT S Finger: other types will be automatically added.
[ 31.014] (**) Wacom Intuos PT S Finger touch: panscroll is 0
[ 31.014] (**) Wacom Intuos PT S Finger touch: panscroll modified to 13
[ 31.014] (--) Wacom Intuos PT S Finger touch: maxX=4096 maxY=4096 maxZ=0 resX=27000 resY=43000
[ 31.014] (II) Wacom Intuos PT S Finger touch: hotplugging dependent devices.
[ 31.014] (EE) Wacom Intuos PT S Finger touch: Invalid type 'stylus' for this device.
[ 31.014] (EE) Wacom Intuos PT S Finger touch: Invalid type 'eraser' for this device.
[ 31.014] (EE) Wacom Intuos PT S Finger touch: Invalid type 'cursor' for this device.
[ 31.014] (EE) Wacom Intuos PT S Finger touch: Invalid type 'pad' for this device.
[ 31.014] (II) Wacom Intuos PT S Finger touch: hotplugging completed.
[ 31.064] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.1/0003:056A:0302.0005/input/input27/event24"
[ 31.064] (II) XINPUT: Adding extended input device "Wacom Intuos PT S Finger touch" (type: TOUCH, id 9)
[ 31.065] (**) Wacom Intuos PT S Finger touch: (accel) keeping acceleration scheme 1
[ 31.065] (**) Wacom Intuos PT S Finger touch: (accel) acceleration profile 0
[ 31.065] (**) Wacom Intuos PT S Finger touch: (accel) acceleration factor: 2.000
[ 31.065] (**) Wacom Intuos PT S Finger touch: (accel) acceleration threshold: 4
[ 31.122] (II) config/udev: Adding input device Wacom Intuos PT S Finger (/dev/input/mouse1)
[ 31.122] (II) No input driver specified, ignoring this device.
[ 31.122] (II) This device may have been added with another device file.
[ 31.124] (II) config/udev: Adding input device Wacom Intuos PT S Pad (/dev/input/event25)
[ 31.124] (**) Wacom Intuos PT S Pad: Applying InputClass "evdev tablet catchall"
[ 31.124] (**) Wacom Intuos PT S Pad: Applying InputClass "libinput tablet catchall"
[ 31.124] (**) Wacom Intuos PT S Pad: Applying InputClass "Wacom USB tablet class"
[ 31.124] (**) Wacom Intuos PT S Pad: Applying InputClass "Wacom tablet class"
[ 31.124] (II) Using input driver 'wacom' for 'Wacom Intuos PT S Pad'
[ 31.124] (**) Wacom Intuos PT S Pad: always reports core events
[ 31.124] (**) Option "Device" "/dev/input/event25"
[ 31.124] (EE) Wacom Intuos PT S Pad: Invalid type 'stylus' for this device.
[ 31.124] (EE) Wacom Intuos PT S Pad: Invalid type 'eraser' for this device.
[ 31.124] (EE) Wacom Intuos PT S Pad: Invalid type 'cursor' for this device.
[ 31.124] (EE) Wacom Intuos PT S Pad: Invalid type 'touch' for this device.
[ 31.124] (II) Wacom Intuos PT S Pad: type not specified, assuming 'pad'.
[ 31.124] (II) Wacom Intuos PT S Pad: other types will be automatically added.
[ 31.124] (**) Wacom Intuos PT S Pad pad: panscroll is 0
[ 31.124] (**) Wacom Intuos PT S Pad pad: panscroll modified to 13
[ 31.124] (II) Wacom Intuos PT S Pad pad: hotplugging dependent devices.
[ 31.124] (EE) Wacom Intuos PT S Pad pad: Invalid type 'stylus' for this device.
[ 31.124] (EE) Wacom Intuos PT S Pad pad: Invalid type 'eraser' for this device.
[ 31.124] (EE) Wacom Intuos PT S Pad pad: Invalid type 'cursor' for this device.
[ 31.124] (EE) Wacom Intuos PT S Pad pad: Invalid type 'touch' for this device.
[ 31.124] (II) Wacom Intuos PT S Pad pad: hotplugging completed.
[ 31.174] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.1/0003:056A:0302.0005/input/input28/event25"
[ 31.174] (II) XINPUT: Adding extended input device "Wacom Intuos PT S Pad pad" (type: PAD, id 10)
[ 31.175] (**) Wacom Intuos PT S Pad pad: (accel) keeping acceleration scheme 1
[ 31.175] (**) Wacom Intuos PT S Pad pad: (accel) acceleration profile 0
[ 31.175] (**) Wacom Intuos PT S Pad pad: (accel) acceleration factor: 2.000
[ 31.175] (**) Wacom Intuos PT S Pad pad: (accel) acceleration threshold: 4
[ 31.175] (II) config/udev: Adding input device Wacom Intuos PT S Pad (/dev/input/js0)
[ 31.175] (II) No input driver specified, ignoring this device.
[ 31.175] (II) This device may have been added with another device file.
[ 31.175] (II) config/udev: Adding input device Wacom Intuos PT S Pad (/dev/input/mouse2)
[ 31.176] (II) No input driver specified, ignoring this device.
[ 31.176] (II) This device may have been added with another device file.
[ 31.176] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[ 31.176] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[ 31.176] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[ 31.177] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[ 31.177] (II) No input driver specified, ignoring this device.
[ 31.177] (II) This device may have been added with another device file.
[ 31.177] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event14)
[ 31.177] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event15)
[ 31.178] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event16)
[ 31.178] (II) No input driver specified, ignoring this device.
[ 31.178] (II) This device may have been added with another device file.
[ 31.178] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event17)
[ 31.178] (II) config/udev: Adding input device HD Pro Webcam C920 (/dev/input/event22)
[ 31.178] (**) HD Pro Webcam C920: Applying InputClass "evdev keyboard catchall"
[ 31.178] (**) HD Pro Webcam C920: Applying InputClass "libinput keyboard catchall"
[ 31.178] (**) HD Pro Webcam C920: Applying InputClass "system-keyboard"
[ 31.178] (**) HD Pro Webcam C920: Applying InputClass "Keyboard Defaults"
[ 31.178] (II) Using input driver 'libinput' for 'HD Pro Webcam C920'
[ 31.178] (**) HD Pro Webcam C920: always reports core events
[ 31.178] (**) Option "Device" "/dev/input/event22"
[ 31.178] (**) Option "_source" "server/udev"
[ 31.179] (II) event22 - HD Pro Webcam C920: is tagged by udev as: Keyboard
[ 31.180] (II) event22 - HD Pro Webcam C920: device is a keyboard
[ 31.180] (II) event22 - HD Pro Webcam C920: device removed
[ 31.224] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:06:00.0/usb5/5-1/5-1:1.0/input/input29/event22"
[ 31.224] (II) XINPUT: Adding extended input device "HD Pro Webcam C920" (type: KEYBOARD, id 11)
[ 31.224] (**) Option "xkb_layout" "gb"
[ 31.224] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.226] (II) event22 - HD Pro Webcam C920: is tagged by udev as: Keyboard
[ 31.226] (II) event22 - HD Pro Webcam C920: device is a keyboard
[ 31.226] (II) config/udev: Adding input device AONE Varmilo Keyboard (/dev/input/event18)
[ 31.226] (**) AONE Varmilo Keyboard: Applying InputClass "evdev keyboard catchall"
[ 31.226] (**) AONE Varmilo Keyboard: Applying InputClass "libinput keyboard catchall"
[ 31.226] (**) AONE Varmilo Keyboard: Applying InputClass "system-keyboard"
[ 31.226] (**) AONE Varmilo Keyboard: Applying InputClass "Keyboard Defaults"
[ 31.226] (II) Using input driver 'libinput' for 'AONE Varmilo Keyboard'
[ 31.226] (**) AONE Varmilo Keyboard: always reports core events
[ 31.226] (**) Option "Device" "/dev/input/event18"
[ 31.226] (**) Option "_source" "server/udev"
[ 31.228] (II) event18 - AONE Varmilo Keyboard: is tagged by udev as: Keyboard
[ 31.228] (II) event18 - AONE Varmilo Keyboard: device is a keyboard
[ 31.228] (II) event18 - AONE Varmilo Keyboard: device removed
[ 31.245] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:06:00.0/usb5/5-2/5-2:1.0/0003:04D9:A0D1.0001/input/input18/event18"
[ 31.245] (II) XINPUT: Adding extended input device "AONE Varmilo Keyboard" (type: KEYBOARD, id 12)
[ 31.245] (**) Option "xkb_layout" "gb"
[ 31.245] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.246] (II) event18 - AONE Varmilo Keyboard: is tagged by udev as: Keyboard
[ 31.246] (II) event18 - AONE Varmilo Keyboard: device is a keyboard
[ 31.247] (II) config/udev: Adding input device AONE Varmilo Keyboard (/dev/input/event19)
[ 31.247] (**) AONE Varmilo Keyboard: Applying InputClass "evdev keyboard catchall"
[ 31.247] (**) AONE Varmilo Keyboard: Applying InputClass "libinput keyboard catchall"
[ 31.247] (**) AONE Varmilo Keyboard: Applying InputClass "system-keyboard"
[ 31.247] (**) AONE Varmilo Keyboard: Applying InputClass "Keyboard Defaults"
[ 31.247] (II) Using input driver 'libinput' for 'AONE Varmilo Keyboard'
[ 31.247] (**) AONE Varmilo Keyboard: always reports core events
[ 31.247] (**) Option "Device" "/dev/input/event19"
[ 31.247] (**) Option "_source" "server/udev"
[ 31.248] (II) event19 - AONE Varmilo Keyboard: is tagged by udev as: Keyboard
[ 31.248] (II) event19 - AONE Varmilo Keyboard: device is a keyboard
[ 31.248] (II) event19 - AONE Varmilo Keyboard: device removed
[ 31.265] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:06:00.0/usb5/5-2/5-2:1.1/0003:04D9:A0D1.0002/input/input19/event19"
[ 31.265] (II) XINPUT: Adding extended input device "AONE Varmilo Keyboard" (type: KEYBOARD, id 13)
[ 31.265] (**) Option "xkb_layout" "gb"
[ 31.265] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.266] (II) event19 - AONE Varmilo Keyboard: is tagged by udev as: Keyboard
[ 31.266] (II) event19 - AONE Varmilo Keyboard: device is a keyboard
[ 31.267] (II) config/udev: Adding input device AONE Varmilo Keyboard System Control (/dev/input/event20)
[ 31.267] (**) AONE Varmilo Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 31.267] (**) AONE Varmilo Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 31.267] (**) AONE Varmilo Keyboard System Control: Applying InputClass "system-keyboard"
[ 31.267] (**) AONE Varmilo Keyboard System Control: Applying InputClass "Keyboard Defaults"
[ 31.267] (II) Using input driver 'libinput' for 'AONE Varmilo Keyboard System Control'
[ 31.267] (**) AONE Varmilo Keyboard System Control: always reports core events
[ 31.267] (**) Option "Device" "/dev/input/event20"
[ 31.267] (**) Option "_source" "server/udev"
[ 31.268] (II) event20 - AONE Varmilo Keyboard System Control: is tagged by udev as: Keyboard
[ 31.268] (II) event20 - AONE Varmilo Keyboard System Control: device is a keyboard
[ 31.268] (II) event20 - AONE Varmilo Keyboard System Control: device removed
[ 31.285] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:06:00.0/usb5/5-2/5-2:1.1/0003:04D9:A0D1.0002/input/input20/event20"
[ 31.285] (II) XINPUT: Adding extended input device "AONE Varmilo Keyboard System Control" (type: KEYBOARD, id 14)
[ 31.285] (**) Option "xkb_layout" "gb"
[ 31.285] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.286] (II) event20 - AONE Varmilo Keyboard System Control: is tagged by udev as: Keyboard
[ 31.286] (II) event20 - AONE Varmilo Keyboard System Control: device is a keyboard
[ 31.287] (II) config/udev: Adding input device AONE Varmilo Keyboard Consumer Control (/dev/input/event21)
[ 31.287] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 31.287] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 31.287] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 31.287] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 31.287] (II) Using input driver 'libinput' for 'AONE Varmilo Keyboard Consumer Control'
[ 31.287] (**) AONE Varmilo Keyboard Consumer Control: always reports core events
[ 31.287] (**) Option "Device" "/dev/input/event21"
[ 31.287] (**) Option "_source" "server/udev"
[ 31.288] (II) event21 - AONE Varmilo Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 31.288] (II) event21 - AONE Varmilo Keyboard Consumer Control: device is a keyboard
[ 31.288] (II) event21 - AONE Varmilo Keyboard Consumer Control: device removed
[ 31.305] (II) libinput: AONE Varmilo Keyboard Consumer Control: needs a virtual subdevice
[ 31.305] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:06:00.0/usb5/5-2/5-2:1.1/0003:04D9:A0D1.0002/input/input21/event21"
[ 31.305] (II) XINPUT: Adding extended input device "AONE Varmilo Keyboard Consumer Control" (type: MOUSE, id 15)
[ 31.305] (**) Option "AccelerationScheme" "none"
[ 31.305] (**) AONE Varmilo Keyboard Consumer Control: (accel) selected scheme none/0
[ 31.305] (**) AONE Varmilo Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 31.305] (**) AONE Varmilo Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 31.306] (II) event21 - AONE Varmilo Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 31.306] (II) event21 - AONE Varmilo Keyboard Consumer Control: device is a keyboard
[ 31.306] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 31.307] (II) No input driver specified, ignoring this device.
[ 31.307] (II) This device may have been added with another device file.
[ 31.310] (**) Wacom Intuos PT S Pen eraser: Applying InputClass "evdev tablet catchall"
[ 31.310] (**) Wacom Intuos PT S Pen eraser: Applying InputClass "libinput tablet catchall"
[ 31.310] (**) Wacom Intuos PT S Pen eraser: Applying InputClass "Wacom USB tablet class"
[ 31.310] (**) Wacom Intuos PT S Pen eraser: Applying InputClass "Wacom tablet class"
[ 31.310] (II) Using input driver 'wacom' for 'Wacom Intuos PT S Pen eraser'
[ 31.310] (**) Wacom Intuos PT S Pen eraser: always reports core events
[ 31.310] (**) Option "Device" "/dev/input/event23"
[ 31.310] (**) Option "Type" "eraser"
[ 31.310] (**) Wacom Intuos PT S Pen eraser: panscroll is 1300
[ 31.310] (**) Wacom Intuos PT S Pen eraser: panscroll modified to 1300
[ 31.310] (--) Wacom Intuos PT S Pen eraser: maxX=15200 maxY=9500 maxZ=1023 resX=100000 resY=100000 tilt=enabled
[ 31.325] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:056A:0302.0004/input/input23/event23"
[ 31.325] (II) XINPUT: Adding extended input device "Wacom Intuos PT S Pen eraser" (type: ERASER, id 16)
[ 31.325] (**) Wacom Intuos PT S Pen eraser: (accel) keeping acceleration scheme 1
[ 31.325] (**) Wacom Intuos PT S Pen eraser: (accel) acceleration profile 0
[ 31.325] (**) Wacom Intuos PT S Pen eraser: (accel) acceleration factor: 2.000
[ 31.325] (**) Wacom Intuos PT S Pen eraser: (accel) acceleration threshold: 4
[ 31.325] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 31.325] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 31.325] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 31.325] (**) AONE Varmilo Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 31.325] (II) Using input driver 'libinput' for 'AONE Varmilo Keyboard Consumer Control'
[ 31.325] (**) AONE Varmilo Keyboard Consumer Control: always reports core events
[ 31.325] (**) Option "Device" "/dev/input/event21"
[ 31.325] (**) Option "_source" "_driver/libinput"
[ 31.325] (II) libinput: AONE Varmilo Keyboard Consumer Control: is a virtual subdevice
[ 31.325] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:06:00.0/usb5/5-2/5-2:1.1/0003:04D9:A0D1.0002/input/input21/event21"
[ 31.325] (II) XINPUT: Adding extended input device "AONE Varmilo Keyboard Consumer Control" (type: KEYBOARD, id 17)
[ 31.325] (**) Option "xkb_layout" "gb"
[ 31.325] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 44.325] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 44.325] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 44.356] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[ 44.356] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[ 44.356] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[ 44.387] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): connected
[ 44.387] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): Internal TMDS
[ 44.387] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): 600.0 MHz maximum pixel clock
[ 44.387] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 44.387] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 44.387] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 44.388] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 44.388] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 44.388] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 44.388] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 44.388] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 44.388] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 44.388] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 44.388] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 44.388] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 44.388] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 44.388] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 44.388] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 44.388] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 44.388] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 44.388] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 44.395] (II) NVIDIA(0): Setting mode "DVI-I-1: nvidia-auto-select @1920x1200 +1920+0 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 44.445] (II) NVIDIA(0): Setting mode "DVI-I-1: nvidia-auto-select @1920x1200 +1920+0 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 45.374] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 45.374] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 45.405] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[ 45.405] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[ 45.405] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[ 45.406] (--) NVIDIA(GPU-0):
[ 45.436] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): connected
[ 45.436] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): Internal TMDS
[ 45.436] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): 600.0 MHz maximum pixel clock
[ 45.436] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 45.436] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 45.436] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 45.436] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 45.436] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 45.436] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 45.436] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 45.436] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 45.436] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 45.437] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 45.437] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 45.437] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 45.437] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 45.437] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 45.437] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 45.437] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 45.437] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 45.437] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 50.261] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 50.261] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 50.294] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[ 50.294] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[ 50.294] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[ 50.324] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): connected
[ 50.324] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): Internal TMDS
[ 50.324] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): 600.0 MHz maximum pixel clock
[ 50.324] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 50.325] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 50.325] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 50.325] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 50.325] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 50.325] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 50.325] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 50.325] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 50.325] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 50.325] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 50.325] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 50.325] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 50.325] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 50.325] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 50.325] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 50.325] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 50.325] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 50.325] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 65.352] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 65.352] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 65.398] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[ 65.398] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[ 65.398] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[ 65.439] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): connected
[ 65.439] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): Internal TMDS
[ 65.439] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): 600.0 MHz maximum pixel clock
[ 65.439] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 65.439] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 65.439] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 65.439] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 65.439] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 65.439] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 65.439] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 65.439] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 65.439] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 65.439] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 65.439] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 65.439] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 65.440] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 65.440] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 65.440] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 65.440] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 65.440] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 65.440] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 90.314] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 90.314] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 90.350] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[ 90.350] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[ 90.350] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[ 90.381] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): connected
[ 90.381] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): Internal TMDS
[ 90.381] (--) NVIDIA(GPU-0): LG Electronics M227WDP (DFP-1): 600.0 MHz maximum pixel clock
[ 90.381] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 90.382] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 90.382] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 90.382] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 90.382] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 90.382] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 90.382] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 90.382] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 90.382] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[ 90.382] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 90.382] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 90.382] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 90.382] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 90.382] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 90.382] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 90.382] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 90.382] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 90.382] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 1330.264] (EE) event18 - AONE Varmilo Keyboard: client bug: event processing lagging behind by 16ms, your system is too slow
[ 1894.416] (II) event1 - Power Button: device removed
[ 1894.438] (II) event0 - Power Button: device removed
[ 1894.564] (II) event22 - HD Pro Webcam C920: device removed
[ 1894.614] (II) event18 - AONE Varmilo Keyboard: device removed
[ 1894.644] (II) event19 - AONE Varmilo Keyboard: device removed
[ 1894.664] (II) event20 - AONE Varmilo Keyboard System Control: device removed
[ 1894.734] (II) event21 - AONE Varmilo Keyboard Consumer Control: device removed
[ 1894.765] (II) UnloadModule: "libinput"
[ 1894.765] (II) UnloadModule: "wacom"
[ 1894.766] (II) UnloadModule: "libinput"
[ 1894.766] (II) UnloadModule: "wacom"
[ 1894.932] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 1894.933] (II) Server terminated successfully (0). Closing log file.
