I’m trying to run the load of updates showing in the software centre today (It’s been about 3 or 4 days I think since I last updated).
I’ve done what I usually do and excluded any AUR stuff manually (I like to see it in the software centre but will update that separately using Yay later) - Today that’s only Zoom.
When trying to apply the updates I get the following error…
target not found: xdg-desktop-portal-xapp
I can’t find this in the list of updates so I suspect it’s a dependency, where can I begin tracking this down with nearly 100 updates listed?
Here’s the command line output log…
Preparing...
Warning: zoom: ignoring package upgrade (5.15.2-1 => 5.15.3-1)
Resolving dependencies...
Checking inter-conflicts...
Warning: dependency cycle detected:
Warning: freetype2 will be installed before its harfbuzz dependency
Warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
Warning: mhwd-nvidia will be installed before its mhwd dependency
Warning: mhwd-nvidia-390xx will be installed before its mhwd dependency
Warning: mhwd-nvidia-470xx will be installed before its mhwd dependency
Failed to prepare transaction:
The transaction summary that appears after I first click apply lists the following…
TO REMOVE
- python-cchardet 2.1.7-5
TO INSTALL
- libutempter 1.2.1-3
- electron24 24.6.2-1
- python-faust-cchardet 2.1.18-1
- js102 102.13.0-1
- xdg-desktop-portal-app 1.0.2-1
- aribb24 1.0.3-3
So it looks like it’s coming in here.
