0n0w1c
22 January 2022 18:45
1
I am trying to use the manjaro-arm-installer and this package keeps failing:
:: Retrieving packages...
xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz failed to download
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirrors.gigenet.com : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from muug.ca : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirror.0xem.ma : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirror.koddos.net : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from manjaro.dcc.uchile.cl : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from repo.skni.umcs.pl : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirror1.cl.netactuate.com : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirror.easyname.at : Given file does not exist
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from manjaro.kyberorg.fi : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from ftp.nluug.nl : Maximum file size exceeded
warning: failed to retrieve some files
error: failed to commit transaction (download library error)
Same occurs if I try to use pacman -Sw xsel
Strit
22 January 2022 19:01
2
That package has not been updated in ages. I wonder why it suddenly complains about its size.
0n0w1c
22 January 2022 19:11
3
I downloaded a copy from an Arch Arm repo and copied it to the arm installer package cache, hoping the installer does not require a .sig file.
Trying to do an i3 install, if you are wondering what is trying to pull this package.
Edit: Yes, it fails without the .sig file. So I downloaded it and trying again, thinking it will work this time.
Strit
22 January 2022 19:16
4
Yeah, I think only the i3 actually uses that package, so maybe @oberon can enlighten us, if the package overlay is still needed?
0n0w1c
22 January 2022 19:49
5
Nope, no dice.
(643/643) checking package integrity [################################################################################] 100%
error: xsel: signature from "Bernhard Landauer <oberon@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package)
Strit
22 January 2022 19:51
6
Hm. Xsel is not in the i3 profile… So it seems to be a dependency of something.
0n0w1c
22 January 2022 19:52
7
Oh hey, I was just able to use wget to download it and the .sig from a Manjaro repo. Maybe it works now… trying again.
0n0w1c
22 January 2022 20:47
8
wget will download the package and .sig, but when copied to the installer’s cache, they fail the integrity check.
Edit: I downloaded from the arm-stable repo and no difference between arm-stable and arm-unstable files, weird. Maybe it is a symlink.
0n0w1c
23 January 2022 14:04
9
The download issue still exists.
Edit: I am going to try starting with the 20.10 i3 image… but that may be doomed from the start.
Edit 2: It seems starting with the old image is still viable. It has xsel installed but no update of xsel was required.
0n0w1c
24 January 2022 19:06
10
Still unable to download the file.
$ sudo pacman -Sw xsel
resolving dependencies...
Packages (1) xsel-1.2.0.20190821-1
Total Download Size: 0.02 MiB
:: Proceed with download? [Y/n] y
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirrors.sonic.net : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirrors.ocf.berkeley.edu : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirror.math.princeton.edu : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from repo.ialab.dsu.edu : Maximum file size exceeded
error: failed retrieving file 'xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz' from mirror.clarkson.edu : Maximum file size exceeded
Strit
24 January 2022 19:16
11
Have you tried other mirrors?
Looks like those are a subset (maybe US based) mirrors.
0n0w1c
24 January 2022 19:29
12
When first reported the error, it was from the installer and it used worldwide mirrors.
0n0w1c
24 January 2022 21:58
13
I downloaded the file from the Arch ARM repo via https and then downloaded the file from a Manjaro repo with wget, the files are exactly the same.
I then set SigLevel = Never
and removed the .sig file from the cache and then tried to install the package:
$ sudo pacman -S xsel
Total Installed Size: 0.04 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [##########################################] 100%
(1/1) checking package integrity [##########################################] 100%
:: File /var/cache/pacman/pkg/xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (checksum)).
Do you want to delete it? [Y/n] n
error: failed to commit transaction (invalid or corrupted package (checksum))
So now a checksum error.
0n0w1c
25 January 2022 00:11
14
This could be a pacman issue.
If I run pacman -U --debug
it passes the integrity test.
debug: using cachedir: /var/cache/pacman/pkg/
checking keyring...
checking package integrity...
loading package files...
But pacman -S --debug
it fails.
debug: found cached pkg: /var/cache/pacman/pkg/xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz
checking keyring...
debug: sha256sum: 38bde74baaee3b1e91aac7832e11a2e7d62945c435b1996d6f366c4d559bcf25
debug: checking sha256sum for /var/cache/pacman/pkg/xsel-1.2.0.20190821-1-aarch64.pkg.tar.xz
debug: returning error 36 from _alpm_pkg_validate_internal (../lib/libalpm/be_package.c: 329) : invalid or corrupted package (checksum)
0n0w1c
25 January 2022 00:24
15
I downloaded the PKGBUILD and built the package, copied it to the cache and still get the error. So thinking this is a pacman bug.
Edit: Anyone else have errors with sudo pacman -S xsel
Dulbi
25 January 2022 04:25
16
Same here. Even with pamac (PGP error).
gumbo
25 January 2022 04:33
17
Works fine for me
sudo pacman -S xsel
[sudo] password for gumbo:
xsel-1.2.0.20190821-1-... 18.2 KiB 2.38 KiB/s 00:08 [##############################] 100%
(1/1) checking keys in keyring [##############################] 100%
(1/1) checking package integrity [##############################] 100%
(1/1) loading package files [##############################] 100%
(1/1) checking for file conflicts [##############################] 100%
(1/1) checking available disk space [##############################] 100%
(1/1) installing xsel [##############################] 100%
(1/1) Arming ConditionNeedsUpdate...
Dulbi
25 January 2022 04:49
18
What is your manjaro branch and manjaro version ?
@0n0w1c I wad thinking about a PGP Key revoked or expired
http://pgp.mit.edu/pks/lookup?search=oberon@manjaro.org&op=vindex&fingerprint=on
@Strit Are the keyring package differents on each branch ?
gumbo
25 January 2022 05:06
19
Currently running stable
[gumbo@manjaro ~]$ cat /etc/lsb-release
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=21.2.2
DISTRIB_CODENAME=Qonos
DISTRIB_DESCRIPTION="Manjaro Linux"
Dulbi
25 January 2022 06:58
20
Ok mine is on unstable. What are you keyring package version ?
Mine are:
$ pamac list -i | grep -i keyring
archlinux-keyring 20220118-1 core 1,5 Mo
archlinuxarm-keyring 20140119-1 core 35,8 ko
manjaro-arm-keyring 20210807-1 core 16,7 ko
manjaro-keyring 20210910-2 core 184,2 ko
