Hello,
Sometimes, at startup, there is a message that updates are available.
Wen I try to update , after some time, a message appears : database not valid or corrupt (PGP signature). Failed to synchronize databases.
I try this but nothing happens.
Wen I restart, it says that the system is up-to-date !
What happens here and how to solve this ?
Thanks in advance for your reply.
Best regards.
Open a terminal and try
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
This question has been answered many times.
https://forum.manjaro.org/search?q=database%20not%20valid%20or%20corrupt
Hello,
Problem solved by :
Thank you.
Best regards.
