Running Manjaro KDE. When I go to Systemd in Systems Settings, I see the apparmor.service as inactive and a Unit State of dead. If I right click on it and select “Start Unit”, I am asked for my password, then nothing happens, the apparmor.service remains inactive/dead.
Any ideas?
Thanks
Tomek
20 September 2021 15:17
2
No information, no ideas
What you see when you type:
systemctl status apparmor.service
journalctl -b -u apparmor.service
Any errors?
Tomek,
I ran the two commands you suggested, the results are shown below.
Thanks
$ systemctl status apparmor.service
○ apparmor.service - Load AppArmor profiles
Loaded: loaded (/usr/lib/systemd/system/apparmor.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Condition: start condition failed at Mon 2021-09-20 13:36:42 MDT; 4h 7min left
└─ ConditionSecurity=apparmor was not met
$ journalctl -b -u apparmor.service
-- Journal begins at Sun 2021-08-22 07:37:26 MDT, ends at Mon 2021-09-20 13:37:13 MDT. --
-- No entries --
Do you have the following as an entry in grub?
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor"
So, I opened GRUB with nano at the /etc/default folder, and found the following line in it:
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=efd44b71-95f2-4625-9bd9-ea72dd1fb5df udev.log_priority=3"
However, did not find
So, I am assuming said line should be added to GRUB, however, I do not know the correct way of doing this. Would it be as:
A second, separate line, or
Somehow adding it to the end of the existing GRUB_CMDLINE_LINUX_DEFAULT=
If #2 above is the right answer, would you be so kind to show me the proper way to structure it, so I don’t end up hosing my system?
Thanks
Tomek
20 September 2021 16:34
6
That line in your case should look like (there is no matter if you add entries in the end or in the begining, just put space between entries):
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor quiet resume=UUID=efd44b71-95f2-4625-9bd9-ea72dd1fb5df udev.log_priority=3"
Save and update GRUB:
sudo update-grub
After reboot you should be able to run apparmor service.
I did as indicated, and it is now running.
Thanks!!
system
Closed
23 September 2021 06:58
8
