Invalid or corrupted package (PGP signature) --- Why
The other day while updating one of my machines, the power plug fell out while downloading the packages to be updated (unplugging a deceased rodent was the final straw but it must have worked loose over time).
After removing the database lock file, I was and to rerun pacman -Syu but all of the packages then reported an invalid PGP signature!
I was able to correct the problem by following the instructions in this thread.
I am however mystified as to why a power interrupt should cause such a problem, especially during the download phase. It might make sense if the fail was in the install phase, or for a single package (the one being downloaded).
Any ideas?
If you provide some logs you might stand a better chance of a useful response.
journalctl --boot=-1 --priority=3 --catalog --no-pager
Cheers.
Cache is a plausible explanation - but one cannot know for sure.
The kernel agressively caches everything and going cold with a lot of data cached - yes possible.
And it may also depend on the filesystem used.
The file systems all have some protection against problems after a power failure.
However, this protection varies depending on the file system.
FAT has next to no protection. :wink:
Other file systems use log files and/or checksums. Sometimes this helps to restore a previous good situation. (but not always)
Some file systems can create snapshots. Then a rollback to ā€œbefore the updateā€ is possible
Something like this works, for example, with Timeshift / snapper and btrfs.
You find good Information about Btrfs in the wiki
:footprints:
Thanks for the ideas.
I was really only wondering if there was an obvious reason, rather than asking anyone for a deep dive into the issue, thatā€™s why I didnā€™t put any details.
FWIW: journalctl for the relevant boot had only one line ā€“ a complaint about unable to enumerate a USB device (i.e. the dead rodent). And the FS is EXT4.
Perhaps this helps:
Logs and other information are what we generally rely on to find the likely cause of an issue, obvious or not; as is said ā€˜the devil is in the detailsā€™. Without that, weā€™re mostly peeing into the wind.
If interrupted during the download phase, an update can usually be recovered without any great issue; you obviously realize that. However, itā€™s always possible a loss of power will affect something else in your system. Just what may have been affected, is a little harder to guess.
A cache issue as suggested by @linux-aarhus is as plausible as anything else. The following links may be helpful in that regard:
According to my understanding is that it happens when you donā€™t keep your system updated.
Mainly from what Iā€™ve seen here, but also due to the fact that I update religiously and have never seen itā€¦
