ajay69
30 November 2023 16:15
1
Hi,
first of all: great job for fixing a problem which I had with the sound on my Asus Rog Strix G713PV 2023 laptop. I found this discussion
System info System:
Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=d2a55327-f83c-40b1-8b9a-bc1b1919926a rw quiet
cryptdevice=UUID=4eee9d9f-29e3-4002-95e1-a9b95a5beeff:luks-4eee9d9f-29e3-4002-95e1-a9b95a5beeff
root=/dev/mapper/luks-4eee9d9f-29e3-4002-95e1-a9b95a5beeff splash
resume=/dev/mapper/luks-560ef57a-391b-4666-a575-d79d2bd0f88f
udev.log_priority=…
and tried the October image which made my soundcard/amplifier work immediately. Alas, after an update last week and just now, the soundcard can’t be found anymore.
I could revert the update thanks to timeshift but not updating somehow is no solution. Just wanted to ask: are the patches not included or is there something I missed?
Kind regards
Alex
Can you post some information ?
inxi -Fza
ajay69
30 November 2023 16:38
3
I’d love to but the forum software tells me, there’s a link in it which I must not post. Can’t find anything.
New users are not allowed to post active links, to prevent spamming and trolling
But inactive links can be posted in pre-formatted text (using </> or Ctrl + E )
https://manjaro.org
ajay69
30 November 2023 16:50
5
Kernel: 6.6.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=58c13a9b-4d41-4637-9b43-23aa24fc64af rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: ROG Strix G713PV_G713PV v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G713PV v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713PV.327 date: 08/23/2023
ID-1: BAT0 charge: 86.1 Wh (100.0%) condition: 86.1/90.0 Wh (95.7%)
volts: 17.3 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
serial: <filter> status: full
Info: model: AMD Ryzen 9 7845HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4152 high: 5239 min/max: 400/5298 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5236 2: 5239 3: 5121
4: 5235 5: 5215 6: 5238 7: 5010 8: 4876 9: 5063 10: 5049 11: 5063 12: 5055
13: 5239 14: 5237 15: 5237 16: 400 17: 5212 18: 5234 19: 400 20: 5046
21: 5050 22: 400 23: 400 24: 400 bogomips: 143789
Type: spec_rstack_overflow mitigation: safe RET, no microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none empty: DP-1, DP-2, HDMI-A-1, eDP-1 bus-ID: 01:00.0
chip-ID: 10de:28e0 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-3,DP-4,DP-5
bus-ID: 08:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 75.0 C
Device-3: IMC Networks [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5458
Display: x11 server: </X.Org> v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon
alternate: fbdev,nv,vesa dri: radeonsi gpu: amdgpu display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: eDP-2 mapped: eDP-1 model: BOE Display NE173QHM-NZ2 built: 2022
res: 2560x1440 hz: 240 dpi: 171 gamma: 1.2 size: 381x214mm (15x8.43")
diag: 437mm (17.2") ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6 vendor: amd mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
es-v: 3.2 direct-render: yes renderer: AMD Radeon Graphics
(raphael_mendocino LLVM 16.0.6 DRM 3.54 6.6.0-1-MANJARO)
device-ID: 1002:164e memory: 500 MiB unified: no
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 535.129.03
device-ID: 10de:28e0 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 23.1.9-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 08:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.83 status: off with: pipewire-media-session
status: active tools: pw-cli
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Foxconn / Hon Hai [] driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0489:e0f6
Local Storage: total: 953.87 GiB used: 97.66 GiB (10.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA1T0QFM
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
used: 97.66 GiB (10.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
System Temperatures: cpu: 83.1 C mobo: 38.0 C
Fan Speeds (rpm): cpu: 3100
Processes: 470 Uptime: 17m wakeups: 0 Memory: total: 16 GiB note: est.
available: 14.84 GiB used: 4.17 GiB (28.1%) Init: systemd v: 254
Packages: 1265 pm: pacman pkgs: 1254 libs: 348 tools: pamac,yay pm: flatpak
pkgs: 11 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.31
nikgnomic: please use proper formatting: [HowTo] Post command output and file content as formatted text
ajay69
30 November 2023 16:51
6
Thanks, that did the trick. It was the </x.org> under Display. But how to remove a link which you never put in?
ajay69
30 November 2023 16:57
7
and here the alsa-info.sh-output:
http://alsa-project.org/db/?f=322fd465597f73ace2e95dc06f9efbe960498c42
Can you also post pacmd list-sinks
philm
2 December 2023 08:20
9
Well. Those newer Asus laptops might not provide the needed info in BIOS. For example the ALLY did that with 323 the last time. Newer 33x BIOS versions fixed that. 6.5 and 6.6 kernel series I patch regarding that.
So check if any kernel worked for you and if which kernel broke it again. Else a BIOS update might have broke it.
Manjaro Linux GitLab
Also read the asus linux project
GitLab.com
ajay69
2 December 2023 13:54
10
Please find the output below. Weirdly after I updated again (the 3rd time), The sound and the bluetooth worked. Will put the status on solved.
pacmd list-sinks ✔ base at 14:51:39
1 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 49152 / 75% / -7.50 dB, front-right: 49152 / 75% / -7.50 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
card: 1 <alsa_card.pci-0000_08_00.6>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC294 Analog"
alsa.id = "ALC294 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc5c0000 irq 111"
device.bus_path = "pci-0000:08:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h/19h HD Audio Controller"
device.string = "front:1"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Family 17h/19h HD Audio Controller Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
ajay69
2 December 2023 14:00
11
Yes, I read that from you in the other thread. Unfortunately, there’s no updated BIOS, yet. I hope ASUS fixes this. They stated they fully support Linux but if such essential hardware info is missing, that statement has to be partially doubted.
The “problem” is I got the laptop quite cheap compared to others with that specs.
Luckily and thanks to your great work, it works now. No other distro does by now.
Many, many thanks to all of you. Happy to learn more about Manjaro.
system
Closed
4 December 2023 02:00
12
