Updates are too slow
#1
Hello
I am trying to upgrade my system. I am using a connection of 7Mb/s. But during the updates, Manjaro is using only 2 Mb/s of it. Its very frustrating. I love Manjaro but it seems I have to wait for a dacade only for a 700 Mb updates. Please save me from this disaster :frowning:
#2
Sound like the mirror you are using is slow compared to your connection. Have you tried another mirror?
#3
Any way to change ?
#4
This command should rank the mirror according to latency speed:
sudo pacman-mirrors -g
Note: latency speed is not the same is bandwidth speed. There is no way (that I know of) to sort by bandwidth speed.
#5
Okay, I have used the command. Now ? Should I do something else ?
#6
sudo pacman -Syy
sudo pacman -Syu
To finish updating. :slight_smile:
#7
Loving the language of “decade” and “disaster” to describe a 2MB/sec connection. Mine at home is 80KB/sec. Just a chuckle. :stuck_out_tongue:
#8
About the same as mine then :rofl:
#9
You can use sudo pacman-mirrors -f3 to get the three fastest mirrors in your area.
#10
