Updates are downloading really slow
I got a 222 updates. I’m trying to install but the download speed is too slow. I tried after connecting to even better internet connection, but nothing changed.
Have you updated the mirrors list?
sudo pacman-mirrors -f
You can specify particular regions and protocols (https) as well, but that command above will use default values to update the mirrors list.
Have a look at man pacman-mirrors.
READ the announcements for the updates to make sure you won’t have any problems. I’ve given you the link to the stable channel updates.
