Update / Upgrade failed after fresh Live-Iso Install
Hello there!
I installed download dot manjaro dot org/kde/24.1.2/manjaro-kde-24.1.2-241104-linux610.iso from USB onto my fairly old Toshiba Satellite C600 Laptop.
While the installation went smoothly without any issues,
any attempt to update (pacman -Syu) or upgrade (pacman -Syyu) either on CLI or via GUI (pamac) resulted in a unusable (Plasma-)GUI with missing applications. plasmoids, etc.
Even with selecting different mirrors (main-mirrors/ germany-mirrors) I had the same results.
That was really time consuming, as the wifi-/ethernet- connection couldn’t established because modem-manager/ Network-Manager was failing, missing or plasmoids and/or dependencies were not found.
So the only solution was, to install the system over and over again, to have at least a working system. :-/
  • What steps did I missed or could have be done differently?
  • Is this a known issue of the current KDE (Plasma) Live-Iso?
  • And most important, how I can solve it?
If you need further informations, please let me know.
Added inxi -Farz Info:
  Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=df31cfe7-7191-4646-bc97-c520e86d1887 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Laptop System: TOSHIBA product: SATELLITE C660 v: PSC1LE-00K00KGR
  Mobo: TOSHIBA model: PWWHA v: 1.00 serial: <superuser required>
    BIOS: TOSHIBA v: 1.40 date: 10/04/2011
  ID-1: BAT1 charge: 53.6 Wh (97.1%) condition: 55.2/71.3 Wh (77.4%)
    volts: 12.0 min: 10.8 model: COMPAL PABAS0241231 type: Li-ion
    serial: <filter> status: discharging
  Info: model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 868 high: 985 min/max: 800/2100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 985 2: 798 3: 800 4: 890
    bogomips: 16767
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Toshiba driver: i915 v: kernel arch: Gen-6 code: Sandybridge
    process: Intel 32nm built: 2011 ports: active: LVDS-1 empty: VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
  Device-2: Chicony CNF9055 Toshiba Webcam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:4
    chip-ID: 04f2:b1d6 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31") monitors: <missing: xrandr>
  Monitor-1: LVDS-1 model: Seiko Epson 0x5541 built: 2009 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
    inactive: gbm,wayland
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
    GT2) device-ID: 8086:0116 memory: 1.46 GiB unified: yes
    vendor: Toshiba 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Toshiba
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
    chip-ID: 10ec:8176 class-ID: 0280
  Local Storage: total: 465.76 GiB used: 8.45 GiB (1.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS547550A9E384
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: A60B scheme: MBR
  ID-1: / raw-size: 63.02 GiB size: 61.73 GiB (97.95%) used: 8.45 GiB (13.7%)
    fs: ext4 dev: /dev/sda7 maj-min: 8:7
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1146 libs: 339 tools: pamac pm: flatpak pkgs: 0
    1: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    2: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    5: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    6: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    7: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    9: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    10: https://manjaro.kurdy.org/stable/$repo/$arch
  Processes: 180 Uptime: 8h 21m wakeups: 2 Memory: total: 4 GiB
  available: 3.74 GiB used: 2.26 GiB (60.4%) Init: systemd v: 254
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Kind regards,
ingo
Welcome to the forum.
Just to be clear, the inxi information that you show is from a system that was installed using manjaro-kde-24.1.2-241104-linux610.iso? The reason I ask is that these are not the versions that I would expect.
Yes, I used rufus under Windows to create the installer USB stick and that mentioned iso.
That went without any errors.
I’m sorry … but that is impossible.
As the download file shows - the kernel would be 6.10.
The ISO does not have kernel 6.5 anywhere on it.
Similarly you show a Plasma 5 system, when the ISO provides Plasma 6.
Are you sure you have been writing the correct ISO?
Plasma 5.27.8? Kernel 6.5? That is from a very old installation disk. I would download and try again. Are you posting an inxi from a previous installation? 4GB RAM and no swap found?
Can you post error messages from the update attempt(s)?
You are right 100%, I checked the Iso i used to create the Stick.
Because of User error I copied / installed the wrong (old) Iso on the Stick,
while the fresh downloaded Iso from the Website wasted Space in a subsubsub folder somewhere on the disk.
So I spent hours to track down a non existent error of mine without even checking the main basic thing.
FFFFFFF…rustrating!
Edit: Done fresh usb-stick and install and im tired now.
Thanks all for pointing me in the right direction.
The other one would technically be upgradeable but would take some care … the EOL kernel and the big changes between Plasma versions being just a few considerations.
All in all it would probably be easiest to use the modern ISO. :wink:
