I upgraded from kernel 5.4 to 5.10 (both latest) and now I’m experiencing problems with LVM. As a result, I have to manually activate the LVs under one VG (media). All other LVs are activated during boot as they should be. Here my drives:
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 1 10.9T 0 disk
└─sda1 8:1 1 10.9T 0 part
└─md0 9:0 0 10.9T 0 raid1
├─photos-photo_stripe 254:22 0 5.7T 0 lvm
└─photos-tmp_stripe 254:23 0 800G 0 lvm
sdb 8:16 1 931.5G 0 disk
└─sdb1 8:17 1 931.5G 0 part
├─vmvg-centos8 254:6 0 50G 0 lvm
├─vmvg-linuxmint 254:7 0 50G 0 lvm
├─vmvg-opensuse15.1 254:8 0 40G 0 lvm
├─vmvg-worker2 254:9 0 40G 0 lvm
├─vmvg-worker1 254:10 0 40G 0 lvm
├─vmvg-worker3 254:11 0 40G 0 lvm
├─vmvg-worker4 254:12 0 40G 0 lvm
├─vmvg-ubuntu1804 254:13 0 40G 0 lvm
├─vmvg-pop_os20 254:14 0 25G 0 lvm
├─vmvg-debian10 254:15 0 20G 0 lvm
└─vmvg-ubuntu-real 254:16 0 20G 0 lvm
├─vmvg-ubuntu 254:17 0 20G 0 lvm
└─vmvg-ubuntusnap 254:19 0 20G 0 lvm
sdc 8:32 1 3.6T 0 disk
└─sdc1 8:33 1 3.6T 0 part
└─media-photo_raw 254:21 0 2.7T 0 lvm
sdd 8:48 1 3.6T 0 disk
└─sdd1 8:49 1 3.6T 0 part
└─media-movies 254:20 0 3.4T 0 lvm /run/timeshift/backup
sde 8:64 1 10.9T 0 disk
└─sde1 8:65 1 10.9T 0 part
sr0 11:0 1 1024M 0 rom
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /boot/efi
└─nvme0n1p2 259:2 0 465.3G 0 part
├─host-swap 254:0 0 16G 0 lvm [SWAP]
├─host-root 254:1 0 30G 0 lvm /
├─host-home 254:2 0 150G 0 lvm /home
└─host-data 254:4 0 100G 0 lvm /media/heiko/data
nvme1n1 259:3 0 931.5G 0 disk
└─nvme1n1p1 259:4 0 931.5G 0 part
├─vmvg-win10 254:3 0 270G 0 lvm
├─vmvg-workdrive 254:5 0 400G 0 lvm
└─vmvg-ubuntusnap-cow 254:18 0 15.8G 0 lvm
After the upgrade to kernel 5.10, at first the vmvg (VG) LVs on drive sdb1 didn’t show up. I had to activate them manually. Somehow I managed to fix that deleting some remnant thin-provisioned LVs that I didn’t need.
Now, when I boot, the two LVs under “media” (VG) are not auto-activated. I need to manually activate using:
vgchange -aay media
Anyway, it’s lost at the next boot.
Here the relevant messages:
journalctl -xb | grep lvm2
Jul 23 20:07:12 manjaro systemd[1]: Created slice Slice /system/lvm2-pvscan.
Jul 23 20:07:13 manjaro systemd[1]: lvm2-pvscan@8:17.service: Main process exited, code=exited, status=5/NOTINSTALLED
░░ An ExecStart= process belonging to unit lvm2-pvscan@8:17.service has exited.
Jul 23 20:07:13 manjaro systemd[1]: lvm2-pvscan@8:17.service: Failed with result 'exit-code'.
░░ The unit lvm2-pvscan@8:17.service has entered the 'failed' state with result 'exit-code'.
░░ Subject: A stop job for unit lvm2-pvscan@8:17.service has finished
░░ A stop job for unit lvm2-pvscan@8:17.service has finished.
Jul 23 20:07:13 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-pvscan@8:17 comm="systemd" exe="/init" hostname=? addr=? terminal=? res=failed'
░░ Subject: A start job for unit lvm2-pvscan@8:33.service has begun execution
░░ A start job for unit lvm2-pvscan@8:33.service has begun execution.
░░ Subject: A start job for unit lvm2-pvscan@8:49.service has begun execution
░░ A start job for unit lvm2-pvscan@8:49.service has begun execution.
Jul 23 20:07:13 woody systemd[1]: lvm2-pvscan@8:33.service: Main process exited, code=killed, status=15/TERM
Jul 23 20:07:13 woody systemd[1]: lvm2-pvscan@8:33.service: Failed with result 'signal'.
Jul 23 20:07:13 woody systemd[1]: lvm2-pvscan@8:49.service: Main process exited, code=killed, status=15/TERM
Jul 23 20:07:13 woody systemd[1]: lvm2-pvscan@8:49.service: Failed with result 'signal'.
Jul 23 20:07:13 woody audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-pvscan@8:33 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jul 23 20:07:13 woody audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-pvscan@8:49 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Booting to kernel 5.4 solves the issues.
I found this somewhat dated Arch Linux bug report: https://bugs.archlinux.org/task/57275. Haven’t tried aqua’s workaround yet. Wanted to see if anyone here experienced similar issues with LVM.
For completeness, here the inxi output:
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=/dev/mapper/host-root
rw quiet apparmor=1 security=apparmor udev.log_priority=3 amd_iommu=on
amd_iommu=pt default_hugepagesz=1G hugepagesz=1G hugepages=48
vfio-pci.ids=10de:1e84,10de:10f8,10de:1ad8,10de:1ad9
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
Type: Desktop System: Gigabyte product: X570 AORUS PRO v: -CF serial: N/A
Mobo: Gigabyte model: X570 AORUS PRO serial: N/A
UEFI: American Megatrends LLC. v: F33 date: 05/21/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1
model: Logitech K780 Multi-Device Wireless Keyboard serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 62.79 GiB used: 50.53 GiB (80.5%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 32 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Corsair part-no: CMK64GX4M2E3200C16 serial: N/A
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 32 GiB speed: 3200 MT/s type: DDR4
Info: 12-Core model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP
arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: 0
microcode: 8701021 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB bogomips: 182131
Speed: 2792 MHz min/max: 2200/3800 MHz base/boost: 3800/4650 boost: enabled
volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 2792 2: 2023 3: 3679
4: 2090 5: 2771 6: 2030 7: 2060 8: 4408 9: 2120 10: 2112 11: 2196 12: 2196
13: 2194 14: 2196 15: 2113 16: 3238 17: 2151 18: 4396 19: 2034 20: 2114
21: 2196 22: 2195 23: 2196 24: 2169
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Gigabyte
driver: vfio-pci v: 0.2 alternate: nouveau,nvidia_drm,nvidia bus-ID: 0b:00.0
chip-ID: 10de:1e84 class-ID: 0300
Device-2: NVIDIA GF106GL [Quadro 2000] driver: nvidia v: 390.144
alternate: nouveau,nvidia_drm bus-ID: 0c:00.0 chip-ID: 10de:0dd8
class-ID: 0300
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-2.1.4:8 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Display: server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DP-3 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: Quadro 2000/PCIe/SSE2 v: 4.6.0 NVIDIA 390.144
direct render: Yes
Device-1: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
driver: snd_virtuoso v: kernel bus-ID: 06:04.0 chip-ID: 13f6:8788
class-ID: 0401
Device-2: NVIDIA TU104 HD Audio vendor: Gigabyte driver: vfio-pci v: 0.2
alternate: snd_hda_intel bus-ID: 0b:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: NVIDIA GF106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 0c:00.1 chip-ID: 10de:0be9 class-ID: 0403
Device-4: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0e:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-5: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: c000 bus-ID: 07:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: bridge0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
Device-1: VG: host type: LVM2 size: 465.26 GiB free: 169.26 GiB
LV-1: data maj-min: 254:4 type: linear dm: dm-4 size: 100 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 465.26 GiB
LV-2: home maj-min: 254:2 type: linear dm: dm-2 size: 150 GiB
Components:
LV-3: root maj-min: 254:1 type: linear dm: dm-1 size: 30 GiB
Components:
LV-4: swap maj-min: 254:0 type: linear dm: dm-0 size: 16 GiB
Components:
Device-2: VG: media type: LVM2 size: 7.28 TiB free: 1.13 TiB
LV-1: movies maj-min: 254:20 type: linear dm: dm-20 size: 3.42 TiB
Components:
p-1: sdd1 maj-min: 8:49 size: 3.64 TiB
LV-2: photo_raw maj-min: 254:21 type: linear dm: dm-21 size: 2.73 TiB
Components:
p-1: sdc1 maj-min: 8:33 size: 3.64 TiB
Device-3: VG: photos type: LVM2 size: 10.91 TiB free: 4.4 TiB
LV-1: photo_stripe maj-min: 254:22 type: linear dm: dm-22 size: 5.73 TiB
Components:
c-1: md0 maj-min: 9:0 size: 10.91 TiB
pp-1: sda1 maj-min: 8:1 size: 10.91 TiB
pp-2: sde1 maj-min: 8:65 size: 10.91 TiB
LV-2: tmp_stripe maj-min: 254:23 type: linear dm: dm-23 size: 800 GiB
Components:
Device-4: VG: vmvg type: LVM2 size: 1.82 TiB free: 772.25 GiB
LV-1: centos8 maj-min: 254:6 type: linear dm: dm-6 size: 50 GiB
Components:
p-1: sdb1 maj-min: 8:17 size: 931.51 GiB
LV-2: debian10 maj-min: 254:15 type: linear dm: dm-15 size: 20 GiB
Components:
LV-3: linuxmint maj-min: 254:7 type: linear dm: dm-7 size: 50 GiB
Components:
LV-4: opensuse15.1 maj-min: 254:8 type: linear dm: dm-8 size: 40 GiB
Components:
LV-5: pop_os20 maj-min: 254:14 type: linear dm: dm-14 size: 25 GiB
Components:
LV-6: ubuntu maj-min: 254:17 type: linear dm: dm-17 size: 20 GiB
Components:
c-1: dm-16 maj-min: 254:16 mapped: vmvg-ubuntu-real size: 20 GiB
pp-1: sdb1 maj-min: 8:17 size: 931.51 GiB
LV-7: ubuntu1804 maj-min: 254:13 type: linear dm: dm-13 size: 40 GiB
Components:
LV-8: ubuntusnap maj-min: 254:19 type: linear dm: dm-19 size: 15.77 GiB
Components:
c-2: dm-18 maj-min: 254:18 mapped: vmvg-ubuntusnap-cow size: 15.77 GiB
pp-1: nvme1n1p1 maj-min: 259:4 size: 931.51 GiB
LV-9: win10 maj-min: 254:3 type: linear dm: dm-3 size: 270 GiB
Components:
LV-10: workdrive maj-min: 254:5 type: linear dm: dm-5 size: 400 GiB
Components:
LV-11: worker1 maj-min: 254:10 type: linear dm: dm-10 size: 40 GiB
Components:
LV-12: worker2 maj-min: 254:9 type: linear dm: dm-9 size: 40 GiB
Components:
LV-13: worker3 maj-min: 254:11 type: linear dm: dm-11 size: 40 GiB
Components:
LV-14: worker4 maj-min: 254:12 type: linear dm: dm-12 size: 40 GiB
Components:
Supported mdraid levels: raid1
Device-1: md0 maj-min: 9:0 type: mdraid level: mirror status: active
state: clean size: 10.91 TiB
Info: report: 2/2 UU blocks: 11718752192 chunk-size: N/A super-blocks: 1.2
Components: Online:
1: sde1 maj-min: 8:65 size: 10.91 TiB state: active sync
2: sda1 maj-min: 8:1 size: 10.91 TiB state: active sync
Local Storage: total: raw: 31.38 TiB usable: 20.47 TiB lvm-free: 6.45 TiB
used: 2.75 TiB (13.4%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 51.9 C scheme: GPT
SMART: yes health: PASSED on: 34d 17h cycles: 612
read-units: 6,894,586 [3.53 TB] written-units: 4,800,504 [2.45 TB]
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 47.9 C scheme: GPT
SMART: yes health: PASSED on: 45d 7h cycles: 611
read-units: 38,547,156 [19.7 TB] written-units: 53,005,909 [27.1 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST12000NM001G-2MV103
family: Exos X16 size: 10.91 TiB block-size: physical: 4096 B logical: 512 B
sata: 3.3 speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: SN03
temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 55d 5h cycles: 181
read: 6.46 TiB written: 15.4 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 347d 16h cycles: 1072
written: 7.3 TiB
ID-5: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HUS726040ALE610
family: Ultrastar 7K6000 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: T907 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 23d 21h cycles: 1258
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST4000DM000-1F2168
family: Desktop HDD.15 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5900
serial: <filter> rev: CC54 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 78d 15h cycles: 1529
read: 11.89 TiB written: 12.84 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-7: /dev/sde maj-min: 8:64 vendor: Seagate model: ST12000NM001G-2MV103
sata: 3.3 speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: SN02
SMART: yes state: enabled health: PASSED on: 54d 7h cycles: 179
read: 11.22 TiB written: 4.49 TiB Pre-Fail: attribute: Spin_Retry_Count
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS70 rev: EX00
dev-links: cdrom
ID-1: / raw-size: 30 GiB size: 29.4 GiB (98.01%) used: 16.97 GiB (57.7%)
fs: ext4 block-size: 4096 B dev: /dev/dm-1 maj-min: 254:1 mapped: host-root
label: N/A uuid: N/A
used: 320 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 103B-7EFC
ID-3: /home raw-size: 150 GiB size: 146.65 GiB (97.76%)
used: 86.09 GiB (58.7%) fs: ext4 block-size: 4096 B dev: /dev/dm-2
maj-min: 254:2 mapped: host-home label: N/A uuid: N/A
ID-4: /media/heiko/data raw-size: 100 GiB size: 97.93 GiB (97.93%)
used: 75.81 GiB (77.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-4
maj-min: 254:4 mapped: host-data label: N/A uuid: N/A
ID-5: /run/timeshift/backup raw-size: 3.42 TiB size: 3.36 TiB (98.43%)
used: 2.58 TiB (76.6%) fs: ext4 block-size: 4096 B dev: /dev/dm-20
maj-min: 254:20 mapped: media-movies label: N/A uuid: N/A
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 254:0 mapped: host-swap label: N/A
uuid: 6f9c4054-35d9-4445-bc61-e2a50393a112
ID-1: /dev/dm-10 maj-min: 254:10 mapped: vmvg-worker1 size: 40 GiB fs: N/A
ID-2: /dev/dm-11 maj-min: 254:11 mapped: vmvg-worker3 size: 40 GiB fs: N/A
ID-3: /dev/dm-12 maj-min: 254:12 mapped: vmvg-worker4 size: 40 GiB fs: N/A
ID-4: /dev/dm-13 maj-min: 254:13 mapped: vmvg-ubuntu1804 size: 40 GiB
fs: N/A label: N/A uuid: N/A
ID-5: /dev/dm-14 maj-min: 254:14 mapped: vmvg-pop_os20 size: 25 GiB fs: N/A
ID-6: /dev/dm-15 maj-min: 254:15 mapped: vmvg-debian10 size: 20 GiB fs: N/A
ID-7: /dev/dm-16 maj-min: 254:16 mapped: vmvg-ubuntu-real size: 20 GiB
ID-8: /dev/dm-17 maj-min: 254:17 mapped: vmvg-ubuntu size: 20 GiB fs: N/A
ID-9: /dev/dm-18 maj-min: 254:18 mapped: vmvg-ubuntusnap-cow size: 15.77 GiB
ID-10: /dev/dm-19 maj-min: 254:19 mapped: vmvg-ubuntusnap size: 20 GiB
ID-11: /dev/dm-21 maj-min: 254:21 mapped: media-photo_raw size: 2.73 TiB
ID-12: /dev/dm-22 maj-min: 254:22 mapped: photos-photo_stripe size: 5.73 TiB
ID-13: /dev/dm-23 maj-min: 254:23 mapped: photos-tmp_stripe size: 800 GiB
fs: ext4 label: N/A uuid: 15920ee9-b368-4f83-9975-bdce1bb72e1a
ID-14: /dev/dm-3 maj-min: 254:3 mapped: vmvg-win10 size: 270 GiB fs: N/A
ID-15: /dev/dm-5 maj-min: 254:5 mapped: vmvg-workdrive size: 400 GiB fs: N/A
ID-16: /dev/dm-6 maj-min: 254:6 mapped: vmvg-centos8 size: 50 GiB fs: N/A
ID-17: /dev/dm-7 maj-min: 254:7 mapped: vmvg-linuxmint size: 50 GiB fs: N/A
ID-18: /dev/dm-8 maj-min: 254:8 mapped: vmvg-opensuse15.1 size: 40 GiB
ID-19: /dev/dm-9 maj-min: 254:9 mapped: vmvg-worker2 size: 40 GiB fs: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-1:2 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.1:4 info: Corsair H115i Platinum type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1b1c:0c17 class-ID: 0300
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-5: 3-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: Canon CanoScan LiDE 110 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 04a9:1909 class-ID: ff00
Hub-8: 5-2:3 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-9: 5-2.1:4 info: Genesys Logic USB2.1 Hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 05e3:061a class-ID: 0900
Device-1: 5-2.1.3:6 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 5-2.1.4:8 info: Logitech Webcam C930e type: Video,Audio
power: 500mA chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Hub-10: 5-2.2:5 info: Genesys Logic Hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-11: 5-2.2.1:7 info: ASIX AX68004 ports: 7 rev: 1.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b95:6804 class-ID: 0900
Device-1: 5-2.2.1.1:10 info: Microsoft Wired Keyboard 600 type: Keyboard,HID
driver: microsoft,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 045e:0750 class-ID: 0300
Device-2: 5-2.2.2:9 info: HP HP Monitor Z31x/Z27x-G2 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 90mA
chip-ID: 03f0:1f47 class-ID: 0000 serial: <filter>
Hub-12: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-13: 6-2:2 info: Genesys Logic USB3.1 Hub ports: 3 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
Hub-14: 6-2.1:3 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 05e3:062a class-ID: 0900
System Temperatures: cpu: 66.6 C mobo: 16.8 C gpu: nvidia temp: 68 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 429 Uptime: 2h 30m wakeups: 16 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1545 lib: 423
flatpak: 0 Shell: Bash (sudo) v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.06
