This problem brings me to new problem: GUI update always show “target not found: PACKAGENAME” for all software (but console command in solution of mentioned topic is working)
Moderator edit: Useless screenshot and a copy of an AUR PKGBUILD removed
sudo pkgfile -u && pamac build yay-git
Result of run:
Checking yay-git dependencies...
cp: cannot create regular file '/var/tmp/pamac/dbs/sync/pamac_aur.db': Permission denied
Error: Failed to prepare transaction: target not found: yay-git
What is the output of…
ls -l /var/tmp/pamac/dbs/sync/
… and…
P.S.: Why are you not using the yay
from the Extra repository, or even if you need the AUR version, yay-bin
Outputs:
/home/myaccount$ ls -l /var/tmp/pamac/dbs/sync/
total 52536
-rw-r--r-- 1 root root 29 июл 17 15:18 community.db
-rw-r--r-- 1 root root 29 июл 10 14:49 community.files
-rw-r--r-- 1 root root 148607 июл 17 15:18 core.db
-rw-r--r-- 1 root root 2092210 июл 10 14:49 core.files
-rw-r--r-- 1 root root 0 июн 6 06:22 core.files.part
-rw-r--r-- 1 root root 9031978 июл 17 15:18 extra.db
-rw-r--r-- 1 root root 42107023 июл 11 16:25 extra.files
-rw-r--r-- 1 root root 17499 авг 16 2022 mhwd.db
-rw-r--r-- 1 root root 147187 июл 17 15:19 multilib.db
-rw-r--r-- 1 root root 222016 июл 10 22:37 multilib.files
-rw-r--r-- 1 root root 0 июл 10 10:44 refresh_timestamp
total 4
lrwxrwxrwx 1 myaccount myaccount 21 июл 19 09:15 local -> /var/lib/pacman/local
drwxr-xr-x 2 root root 4096 июл 19 09:15 sync
I just to want to make working this via GUI, that appear everyday in icon tray and reports about existing updates.
Try this…
sudo chmod 777 /var/tmp/pamac/dbs/sync
On my system, it is world-writable. I don’t know whether it’s supposed to work like that, but pamac
has been having issues for a long time now, and I personally recommend against using it unless you know what you’re doing.
Thank you, it’s working now.
p.s. I cann’t say what happen with permission of files, but it wasn’t me
I think this and similar posts are probably a symptom of sudo pamac ...
