Update-resolv-conf fails to execute
Hi,
pinxi: (cannot edit my posts to replace inxi output with current)
I start OpenVPN from terminal.
After 2020-08-28 update update-resolve-conf fails, OpenVPN log at verb 4:
Fri Aug 28 15:46:49 2020 us=646697 /etc/openvpn/up.sh tun0 1500 1585 10.50.0.15 255.255.0.0 init
    + run /etc/openvpn/update-resolv-conf
    + /etc/openvpn/update-resolv-conf
    dhcp-option DNS 10.50.0.1
    /usr/lib/resolvconf/libc.d/avahi-daemon: line 31: kill: (434) - Operation not permitted
    + '[' 1 -ne 0 ']'
    + echo '/etc/openvpn/update-resolv-conf Failed with exit code 0'
    + return 1
    Fri Aug 28 15:46:49 2020 us=696834 WARNING: Failed running command (--up/--down): external program exited with error status: 1
    Fri Aug 28 15:46:49 2020 us=696857 Exiting due to fatal error
I never saw avahi-deamon in OpenVPN logs.
cat /usr/lib/resolvconf/libc.d/avahi-daemon
#!/bin/sh
: ${avahi_daemon_pidfile:=/var/run/avahi-daemon/pid}
if [ -s "$avahi_daemon_pidfile" ]; then
        kill -HUP $(cat "$avahi_daemon_pidfile")
fi
Help troubleshooting appreciated,
Thanks
Ok,
now using update-systemd-resolved:
https://wiki.archlinux.org/index.php/OpenVPN#The_update-systemd-resolved_custom_script
Works fine but still wondering why the previous solution failed…
Thanks
systemd runs at root level, so the kill that was failing:
now just works.
Also, in the future, please mark a solution like this:
Solution
:innocent:
Hi,
Using update-systemd-resolved doesn’t solve the problem with update-resolv-conf.
But yes, it is a solution from user point of view.
:wink:
Thanks
Coming back to this:
So does OpenVPN and it used to work fine before the 2020-08-28 update:
root      347026  0.0  0.1  19460 10620 ?        Ss   17:37   0:00 /usr/bin/openvpn --config client.conf
After a shutdown last night it doesn’t work anymore today.
I can ping:
ping 9.9.9.9
ping manjaro.org
but Firefox is unable to resolve DNS the same for dig.
Did a pre update restore, working fine.
Will wait for next update.
Thanks
openresolv added support to notify avahi-daemon and mdnsd of resolv.conf changes last month.
