BEHRINGER UMC202HD problems with detection and choppy audio
Hello there!
I got a BEHRINGER U-PHORIA UMC202HD (Quick Start Guide) audio interface on my hands, but it does not behave correctly at all.
Device is either not detected by the system at all, or audio is choppy and stutters - sound is constantly being skipped every second or so.
My motherboard - ASUS PRIME-X470-PRO (Manual) has only USB3.1 ports: x2 Gen 2 ports, x5 Gen 1 ports and one Type-C Gen 1 .
Depending on the used port and cable UMC202HD’s behavior is different. Here are the ways I have tried to connect it:
Original cable plugged into USB 3.1 Gen 2 port (LOOP)
System detects the device (notification flash), immediately looses it, detects it again and so on in an infinite loop.
Device itself is flashing lights like it constantly being powered on and off.
journalctl --reverse
Jan 31 16:42:27 rattlewrench-pc kernel: usb 3-2: clock source 41 is not valid, cannot use
Jan 31 16:42:27 rattlewrench-pc mtp-probe[58757]: bus: 3, device: 3 was not an MTP device
Jan 31 16:42:27 rattlewrench-pc mtp-probe[58757]: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.2/0000:02:04.0/0000:04:00.0/usb3/3-2"
Jan 31 16:42:26 rattlewrench-pc mtp-probe[58709]: bus: 3, device: 3 was not an MTP device
Jan 31 16:42:26 rattlewrench-pc mtp-probe[58709]: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.2/0000:02:04.0/0000:04:00.0/usb3/3-2"
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: clock source 41 is not valid, cannot use
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: SerialNumber: 12345678
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: Manufacturer: BEHRINGER
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: Product: UMC202HD 192k
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: New USB device found, idVendor=1397, idProduct=0507, bcdDevice= 1.00
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: config 1 has no interface number 3
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: config 1 has an invalid interface number: 5 but max is 3
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: new high-speed USB device number 3 using xhci_hcd
Jan 31 16:42:26 rattlewrench-pc systemsettings5[2694]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jan 31 16:42:26 rattlewrench-pc systemsettings5[2694]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Jan 31 16:42:26 rattlewrench-pc systemsettings5[2694]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-input-0"
Jan 31 16:42:26 rattlewrench-pc systemsettings5[2694]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-output-0"
Jan 31 16:42:26 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jan 31 16:42:26 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Jan 31 16:42:26 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-input-0"
Jan 31 16:42:26 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-output-0"
Jan 31 16:42:26 rattlewrench-pc kernel: usb 3-2: USB disconnect, device number 2
Jan 31 16:42:26 rattlewrench-pc systemsettings5[2694]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/CardListItem.qml:16: TypeError: Cannot read property 'width' of null
Jan 31 16:42:26 rattlewrench-pc mtp-probe[58689]: bus: 3, device: 2 was not an MTP device
Jan 31 16:42:26 rattlewrench-pc mtp-probe[58689]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.2/0000:02:04.0/0000:04:00.0/usb3/3-2"
Jan 31 16:42:25 rattlewrench-pc mtp-probe[58632]: bus: 3, device: 2 was not an MTP device
Jan 31 16:42:25 rattlewrench-pc mtp-probe[58632]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.2/0000:02:04.0/0000:04:00.0/usb3/3-2"
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: SerialNumber: 12345678
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: Manufacturer: BEHRINGER
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: Product: UMC202HD 192k
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: New USB device found, idVendor=1397, idProduct=0507, bcdDevice= 1.00
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: config 1 has no interface number 3
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: config 1 has an invalid interface number: 5 but max is 3
Jan 31 16:42:25 rattlewrench-pc kernel: usb 3-2: new high-speed USB device number 2 using xhci_hcd
Original cable plugged into USB 3.1 Gen 1 port (NOT DETECTED)
System does not detects the device.
Device itself is flashing lights once during powered on and then only the Power light stays on, as it should.
Jan 31 16:51:31 rattlewrench-pc kernel: usb usb5-port1: unable to enumerate USB device
Jan 31 16:51:31 rattlewrench-pc kernel: usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
Jan 31 16:51:30 rattlewrench-pc kernel: usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
Jan 31 16:51:29 rattlewrench-pc kernel: usb usb5-port1: attempt power cycle
Jan 31 16:51:29 rattlewrench-pc kernel: usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
Jan 31 16:51:28 rattlewrench-pc kernel: usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 076: ID 1a2c:427c China Resource Semico Co., Ltd Backlit Keyboard [Cougar Vantar]
Bus 005 Device 077: ID 04d9:a09f Holtek Semiconductor, Inc. E-Signal LUOM G10 Mechanical Gaming Mouse
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lsusb -tv
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
    |__ Port 2: Dev 77, If 2, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 2: Dev 77, If 0, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 2: Dev 77, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 4: Dev 76, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    |__ Port 4: Dev 76, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 10000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/14p, 480M
Original cable plugged into a USB hub (DETECTED)
USB hub itself is plugged into the same USB 3.1 Gen 1 port
System does detects the device.
Looking in Plasma Audio settings UMC202HD 192k Pro is displayed with 3 available Profiles: Off, Analog Stereo Input and Pro Audio.
After setting profile to Pro Audio and trying to Test channels - I can hear only noise but in stereo.
Audacious and SMP are refusing to play any content, VLC and Firefox are playing everything without sound.
Spotify is able to play audio, but the sound is choppy.
Jan 31 17:10:36 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-input-0"
Jan 31 17:10:36 rattlewrench-pc kdeconnectd[1566]: org.kde.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-input-0"
Jan 31 17:10:36 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jan 31 17:10:36 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Jan 31 17:10:36 rattlewrench-pc kdeconnectd[1566]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jan 31 17:10:36 rattlewrench-pc kdeconnectd[1566]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jan 31 17:10:36 rattlewrench-pc kernel: usb 5-1.2: clock source 41 is not valid, cannot use
Jan 31 17:10:36 rattlewrench-pc mtp-probe[83084]: bus: 5, device: 91 was not an MTP device
Jan 31 17:10:36 rattlewrench-pc mtp-probe[83084]: checking bus 5, device 91: "/sys/devices/pci0000:00/0000:00:07.1/0000:09:00.3/usb5/5-1/5-1.2"
Jan 31 17:10:35 rattlewrench-pc mtp-probe[83026]: bus: 5, device: 91 was not an MTP device
Jan 31 17:10:35 rattlewrench-pc mtp-probe[83026]: checking bus 5, device 91: "/sys/devices/pci0000:00/0000:00:07.1/0000:09:00.3/usb5/5-1/5-1.2"
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: clock source 41 is not valid, cannot use
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: SerialNumber: 12345678
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: Manufacturer: BEHRINGER
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: Product: UMC202HD 192k
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: New USB device found, idVendor=1397, idProduct=0507, bcdDevice= 1.00
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: config 1 has no interface number 3
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: config 1 has an invalid interface number: 5 but max is 3
Jan 31 17:10:35 rattlewrench-pc kernel: usb 5-1.2: new high-speed USB device number 91 using xhci_hcd
Jan 31 17:09:46 rattlewrench-pc upowerd[1409]: treating change event as add on /sys/devices/pci0000:00/0000:00:07.1/0000:09:00.3/usb5/5-1
Jan 31 17:09:44 rattlewrench-pc kernel: usb 5-1-port1: Cannot enable. Maybe the USB cable is bad?
Jan 31 17:09:44 rattlewrench-pc upowerd[1409]: treating change event as add on /sys/devices/pci0000:00/0000:00:07.1/0000:09:00.3/usb6/6-1
Jan 31 17:09:43 rattlewrench-pc kernel: hub 6-1:1.0: 4 ports detected
Jan 31 17:09:43 rattlewrench-pc kernel: hub 6-1:1.0: USB hub found
Jan 31 17:09:43 rattlewrench-pc kernel: usb 6-1: Manufacturer: GenesysLogic
Jan 31 17:09:43 rattlewrench-pc kernel: usb 6-1: Product: USB3.0 Hub
Jan 31 17:09:43 rattlewrench-pc kernel: usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 31 17:09:43 rattlewrench-pc kernel: usb 6-1: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
Jan 31 17:09:43 rattlewrench-pc kernel: usb 6-1: new SuperSpeed USB device number 6 using xhci_hcd
Jan 31 17:09:43 rattlewrench-pc kernel: hub 5-1:1.0: 4 ports detected
Jan 31 17:09:43 rattlewrench-pc kernel: hub 5-1:1.0: USB hub found
Jan 31 17:09:43 rattlewrench-pc kernel: usb 5-1: Manufacturer: GenesysLogic
Jan 31 17:09:43 rattlewrench-pc kernel: usb 5-1: Product: USB2.0 Hub
Jan 31 17:09:43 rattlewrench-pc kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 31 17:09:43 rattlewrench-pc kernel: usb 5-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
Jan 31 17:09:43 rattlewrench-pc kernel: usb 5-1: new high-speed USB device number 88 using xhci_hcd
lsusb
Bus 006 Device 006: ID 05e3:0612 Genesys Logic, Inc. Hub
Bus 005 Device 091: ID 1397:0507 BEHRINGER International GmbH UMC202HD 192k
Bus 005 Device 088: ID 05e3:0610 Genesys Logic, Inc. Hub
lsusb -tv
    |__ Port 1: Dev 6, If 0, Class=Hub, Driver=hub/4p, 5000M
    |__ Port 1: Dev 88, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 2: Dev 91, If 0, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 2: Dev 91, If 1, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 2: Dev 91, If 2, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 2: Dev 91, If 5, Class=Vendor Specific Class, Driver=, 480M
Besides the original out-of-the box cable, I have tried two other USB 2.0 Type-A to Type-B cables. One brand new, one used. Unless I’m missing something, the only case with behaviour different from original cable was:
Spare cable plugged into USB 3.1 Gen 2 port (DETECTED)
Looking in Plasma Audio settings UMC202HD 192k Pro is displayed with 8 available Profiles: Off, Analog Stereo Output + Analog Stereo Input, Analog Stereo Output, Analog Stereo Input, Analog Mono Input, Analog Mono (Left) Input, Analog Mono (Right) Input and Pro Audio.
After setting profile to Analog Stereo Output + Analog Stereo Input and trying to Test channels - I can hear TTS voice for left/right channels, but the sound is choppy.
All system sounds are present (Audacious, SMP, VLC, Firefox, Spotify, etc. are playing all the media) but sound is choppy everywhere.
Jan 31 17:38:04 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-input-0"
Jan 31 17:38:04 rattlewrench-pc systemsettings5[87483]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-input-0"
Jan 31 17:38:04 rattlewrench-pc systemsettings5[87483]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jan 31 17:38:04 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jan 31 17:38:04 rattlewrench-pc systemsettings5[87483]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Jan 31 17:38:04 rattlewrench-pc plasmashell[1554]: org.kde.plasma.pulseaudio: No object for name "@DEFAULT_SINK@"
Jan 31 17:38:04 rattlewrench-pc kdeconnectd[1566]: org.kde.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC202HD_192k_12345678-00.pro-input-0"
Jan 31 17:38:04 rattlewrench-pc kdeconnectd[1566]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jan 31 17:38:04 rattlewrench-pc kdeconnectd[1566]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jan 31 17:38:04 rattlewrench-pc kernel: usb 3-2: clock source 41 is not valid, cannot use
Jan 31 17:38:04 rattlewrench-pc mtp-probe[98672]: bus: 3, device: 83 was not an MTP device
Jan 31 17:38:04 rattlewrench-pc mtp-probe[98672]: checking bus 3, device 83: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.2/0000:02:04.0/0000:04:00.0/usb3/3-2"
Jan 31 17:38:03 rattlewrench-pc mtp-probe[98614]: bus: 3, device: 83 was not an MTP device
Jan 31 17:38:03 rattlewrench-pc mtp-probe[98614]: checking bus 3, device 83: "/sys/devices/pci0000:00/0000:00:01.3/0000:01:00.2/0000:02:04.0/0000:04:00.0/usb3/3-2"
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: SerialNumber: 12345678
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: Manufacturer: BEHRINGER
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: Product: UMC202HD 192k
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: New USB device found, idVendor=1397, idProduct=0507, bcdDevice= 1.00
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: config 1 has no interface number 3
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: config 1 has an invalid interface number: 5 but max is 3
Jan 31 17:38:03 rattlewrench-pc kernel: usb 3-2: new high-speed USB device number 83 using xhci_hcd
lsusb
Bus 003 Device 083: ID 1397:0507 BEHRINGER International GmbH UMC202HD 192k
lsusb -tv
    |__ Port 2: Dev 83, If 0, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 2: Dev 83, If 1, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 2: Dev 83, If 2, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 2: Dev 83, If 5, Class=Vendor Specific Class, Driver=, 480M
mhwd -lh -d --usb
03: USB 00.5: 0000 Unclassified device
  SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:01:00.2/0000:02:04.0/0000:04:00.0/usb3/3-2/3-2:1.5
  SysFS BusID: 3-2:1.5
  Hardware Class: unknown
  Model: "BEHRINGER International UMC202HD 192k"
  Hotplug: USB
  Vendor: usb 0x1397 "BEHRINGER International GmbH"
  Device: usb 0x0507 "UMC202HD 192k"
  Revision: "1.00"
  Serial ID: "12345678"
  Speed: 480 Mbps
  Module Alias: "usb:v1397p0507d0100dcEFdsc02dp01icFFisc01ip10in05"
  Attached to: #7 (Hub)
System information (while spare cable plugged into Gen 2 port)
$ inxi --admin --verbosity=7 --filter --width
  Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
    root=UUID=6355521b-530e-4960-9fb6-2c97de1c955c rw quiet
    resume=UUID=b8f1cc5c-b866-4b24-8eec-ab472a010875
  Console: pty pts/4 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x
    serial: <filter> UEFI: American Megatrends v: 5851 date: 06/16/2021
  RAM: total: 15.59 GiB used: 5.79 GiB (37.1%)
  Array-1: capacity: 128 GiB note: check slots: 4 EC: None
  Device-1: DIMM_A1 size: 4 GiB speed: 2666 MT/s type: DDR4
    detail: synchronous unbuffered (unregistered) bus-width: 64 bits
    total: 64 bits manufacturer: Kingston part-no: KHX2800C14D4/4GX
    serial: <filter>
  Device-2: DIMM_A2 size: 4 GiB speed: 2666 MT/s type: DDR4
    serial: <filter>
  Device-3: DIMM_B1 size: 4 GiB speed: 2666 MT/s type: DDR4
    serial: <filter>
  Device-4: DIMM_B2 size: 4 GiB speed: 2666 MT/s type: DDR4
    serial: <filter>
  Info: model: AMD Ryzen 7 2700X socket: AM4 bits: 64 type: MT MCP arch: Zen+
    family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2293 high: 3700 min/max: 2200/3700 boost: enabled
    base/boost: 3700/4350 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 3700 4: 2200
    5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 118455
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
    smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    disabled, RSB filling
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia
    v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 08:00.0 chip-ID: 10de:13c2
    class-ID: 0300
  Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
  Screen-1: 0 s-res: 3840x1080 s-dpi: 91 s-size: 1070x301mm (42.1x11.9")
    s-diag: 1112mm (43.8")
  Monitor-1: DVI-I-1 res: 1920x1080 dpi: 92 size: 531x298mm (20.9x11.7")
    diag: 609mm (24")
  Monitor-2: HDMI-0 res: 1920x1080
  OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 495.46
    direct render: Yes
  Device-1: NVIDIA GM204 High Definition Audio vendor: eVga.com.
    driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0fbb
    class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: BEHRINGER UMC202HD 192k type: USB driver: snd-usb-audio
    bus-ID: 3-2:83 chip-ID: 1397:0507 class-ID: 0102 serial: <filter>
  Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.20 running: no
  Sound Server-4: PulseAudio v: 15.0 running: no
  Sound Server-5: PipeWire v: 0.3.43 running: yes
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    port: e000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: br-1b9bb12f6066 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy scope: link
  Local Storage: total: 558.92 GiB used: 441.47 GiB (79.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BW480A4
    family: 53x and Pro 1500/2500 Series SSDs size: 447.13 GiB block-size:
    physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: SSD
    serial: <filter> rev: DC32 temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 180d 11h cycles: 2979
    read: 64.51 TiB written: 45.1 TiB
  ID-2: /dev/sdb maj-min: 8:16 vendor: OCZ model: ARC100
    family: Barefoot 3 based SSDs size: 111.79 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 1.01 scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 337d 23h cycles: 2984
  ID-1: / raw-size: 438.03 GiB size: 430.16 GiB (98.20%)
    used: 392.97 GiB (91.4%) fs: ext4 block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2 label: N/A uuid: 6355521b-530e-4960-9fb6-2c97de1c955c
    used: 6.1 MiB (2.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: FCC2-2D57
  ID-3: /run/media/rattlewrench/OCZ_ARC100 raw-size: 111.79 GiB
    size: 109.47 GiB (97.93%) used: 48.49 GiB (44.3%) fs: ext4
    block-size: 4096 B dev: /dev/sdb1 maj-min: 8:17 label: OCZ_ARC100
    uuid: 099ff74d-9b07-4864-a375-aa00dd372c5a
  ID-1: swap-1 type: partition size: 8.8 GiB used: 256 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: b8f1cc5c-b866-4b24-8eec-ab472a010875
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-2:83 info: BEHRINGER UMC202HD 192k type: Audio
    driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-2:77 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
    type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 04d9:a09f class-ID: 0300
  Device-2: 5-4:76
    info: China Resource Semico Backlit Keyboard [Cougar Vantar]
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:427c class-ID: 0301
  Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 39.5 C mobo: N/A gpu: nvidia temp: 60 C
  Processes: 403 Uptime: 2h 38m wakeups: 0 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1917
  pacman: 1884 lib: 443 flatpak: 33 Shell: Zsh (sudo) v: 5.8
  running-in: konsole inxi: 3.3.12
Snippets of sudo dmesg -w output after plugging the interface into different USB ports.
Reddit thread
Would appreciate any help at making this thing operational!
Hello.
How about trying different kernels?
When I first tried my MOTU M4, there were some noise on the sound.
But after changing to non-rt (realtime) kernel, the noise was gone.
Have you tried the responses you got when you posted about this on Reddit a few hours ago? I’ll post the link here in case it helps other people.
I particularly like this response you got 20 minutes ago:
Get rid of that piece of crap and buy a focusrite. I had nothing but problems with this thing I got rid of it years ago
You could make sure that your sample rates are the same on your computer and your interface.
Have you tried using the Jack audio connection kit?
I have Jack2 and JackCtl (a jack controller) installed. You need to start jack from the controller.
If the Reddit community solved your problem, please mark this as solved with the solution you used, which might help others.
Update on the situation:
I have tested UMC202HD on win10 laptop with USB 3 Type-A and Type-C (using a hub) ports, with and without Behringer proprietary drivers, and device is always detected there.
But I have noticed similar stutters persist there too, however they are nowhere near as noticeable as on Linux - no recognizable pattern, but a stutter usually happens once every 5 to 10 minutes - sometimes more often, sometimes less often.
So, I decided to attempt to do a refund, while it is still possible.
Before sending it out I have tried a few things:
  • Checking the device from Live-USB of Manjaro and Ubuntu 21.10 (latter managed to screw up my GRUB)
  • Switching kernel from 5.16.2-1 to LTS 5.10.93-1 and back.
  • Switching to untested branch of Manjaro and testing the interface with fresh PipeWire 0.3.45, among other things.
  • Following the suggestion from reddit thread and creating a file /etc/modprobe.d/behringer.conf with the following line: options snd_usb_audio implicit_fb=1
Neither of the attempts displayed any significant difference with detecting device or choppy audio.
If I am not mistaken, after the creating behringer.conf file, the interface refused to playback any audio at all.
I’ll update post, if I’ll get some response from the retailer.
Another update:
After sending UMC202HD back (no response from retailer yet), I picked up Behringer U-PHORIA UMC204HD.
This one worked near perfectly out-of-the-box: detected by the system on all tested USB ports, audio playback is clean without any stutters.
Only problem with UMC204HD was that the detected profiles were limited to combinations of Analog Surround 4.0 Output and Analog/Digital Stereo Inputs, when I have stereo headphones and a mono mic.
The solution to this was found in the pipewire configuration file. I have copied the config template from system-wide to user folder:
cp /usr/share/pipewire/pipewire.conf ~/.config/pipewire/pipewire.conf
And then added virtual sink and source to the ~/.config/pipewire/pipewire.conf, following the examples on PipeWire wiki.
