Im trying to install the new 450 drivers, but im having no luck.
In manjaro settings manager, it’s showing im using 440 drivers.
If i try to install 450 drivers i get.
Error: config ‘video-nvidia-450xx’ conflicts with config(s): video-nvidia-440xx
When I try to remove 440 drivers i get.
Starting
Removing video-nvidia-440xx…
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia-440xx/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies…
:: removing linux58-nvidia-440xx breaks dependency ‘linux58-nvidia-440xx’ required by linux-latest-nvidia-440xx
Error: pacman failed!
Error: script failed!
Honestly, i’m really scared to mess with nvidia drivers lol Its so easy to break the OS. So i thought it best to ask you professionals
visone
September 13, 2020, 5:51pm
#2
Hi!
You need to uninstall linux-latest linux-latest-nvidia-440 video-nvidia-440xx
Then reboot, then install video-nvidia-450xx
I just did a quick search for video-nvidia but I dont have it in pamac.
visone
September 13, 2020, 6:02pm
#4
Hi!
The drivers are installed by mhwd
sudo mhwd -r pci video-nvidia-440xx
Use -r to remove, -i to install
The packages linux-latest linux-latest-nvidia-440 with pacman
sudo pacman -R package
Ah ok, I understand now. Thank you.
you can try this command line from a previous post. Ignore the videomosetting line.
sudo mhwd -r pci video-modesetting
sudo mhwd -f -i pci video-hybrid-intel-nvidia-450xx-prime
systemctl reboot
Thank you. Visones advice just did the trick for me. All was smooth.
Please don’t forget to mark the post as ‘Solved’
system
closed
September 16, 2020, 9:42pm
#9
