Update loading is so slow
very low update speed. i read 2 commands on forum here but not understand how use fast mirror:
[al@komp ~]$ sudo pacman-mirrors --geoip
[sudo] пароль для al:
::INFO Downloading mirrors from repo.manjaro.org
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.507 Russia         : https://mirror.truenetwork.ru/manjaro/
  0.289 Russia         : http://mirror.truenetwork.ru/manjaro/
::INFO Writing mirror list
::Russia          : https://mirror.truenetwork.ru/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[al@komp ~]$ sudo pacman-mirrors --fasttrack 5
::INFO Using custom mirror file
  0.410 Russia         : https://mirror.truenetwork.ru/manjaro/
  0.282 Russia         : http://mirror.truenetwork.ru/manjaro/
::Russia          : https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
[al@komp ~]$
https://wiki.manjaro.org/ write:
Sorry! This site is experiencing technical difficulties.
Try waiting a few minutes and reloading.
(Cannot access the database)
Backtrace:
#0 /var/www/html/includes/libs/rdbms/loadbalancer/LoadBalancer.php(931): Wikimedia\Rdbms\LoadBalancer->reportConnectionError()
#1 /var/www/html/includes/libs/rdbms/loadbalancer/LoadBalancer.php(898): Wikimedia\Rdbms\LoadBalancer->getServerConnection(0, 'manjarowiki_fZ7...', 0)
#2 /var/www/html/includes/page/WikiPage.php(499): Wikimedia\Rdbms\LoadBalancer->getConnection(-1)
#3 /var/www/html/includes/page/WikiPage.php(612): WikiPage->loadPageData()
#4 /var/www/html/includes/page/WikiPage.php(653): WikiPage->exists()
#5 /var/www/html/includes/page/WikiPage.php(291): WikiPage->getContentModel()
#6 /var/www/html/includes/page/WikiPage.php(278): WikiPage->getContentHandler()
#7 /var/www/html/includes/actions/Action.php(98): WikiPage->getActionOverrides()
#8 /var/www/html/includes/actions/Action.php(155): Action::factory('view', Object(WikiPage), Object(RequestContext))
#9 /var/www/html/includes/MediaWiki.php(155): Action::getActionName(Object(RequestContext))
#10 /var/www/html/includes/MediaWiki.php(817): MediaWiki->getAction()
#11 /var/www/html/includes/MediaWiki.php(527): MediaWiki->main()
#12 /var/www/html/index.php(44): MediaWiki->run()
#13 {main}
sudo pacman-mirrors -f 5
sudo pacman -Syyu
That’s enough. pacman-mirrors -f 5 create list 5 fastest mirrors, --geoip create list of mirrors which are closest to you (which isn’t equal fastest mirrors).
Thank you, we’re aware.
Tip: When pasting terminal output, highlight it and use the Preformatted text </> button. I’ve done it for you this time. :wink:
ok thank you!
sorry, I forgot this. i will be use formatting in next time. thank you!
