Hi there,
I am searching for a solution
I have these two bizarre things in my pamac GUI for 6 months now. They are not updating because I can not select them and the box to tick them is greyed out. I do not know what to do. Please help.
I am no Manjaro GNOME. Thank you.
Hi @vatosflokos ,
You’ll notice that the packages are not official Manjaro packages from the repository, but actually Flatpaks:
https://i.imgur.com/lmGILPf.png
Best is to manage them on their own, in my opinion. See
https://wiki.archlinux.org/title/Flatpak#Update_a_runtime_or_application
Oh, I think the flatpack update via terminal solved the problem. Thanks! I will wait until the end and mark this as solved. Kudos!
Ben
28 February 2025 07:35
6
You can attempt to avoid some issues by using Konsole for updates:
alias update='sudo pacman -Syu && flatpak update && pamac update'
You can do alias, or abbr to make it trivial:
system
Closed
3 March 2025 07:35
7
