Update-grub fail after a kernel update
grub
kernel
#1
Hi,
I recently found something strange on my system after each update of the Linux kernel : the update-grub command fail :
$ sudo update-grub
Found background: /usr/share/grub/background.png
Found linux image: /boot/vmlinuz-4.14-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
/dev/mapper/control: open failed: No such device
Failure to communicate with kernel device-mapper driver.
Check that device-mapper is available in the kernel.
Incompatible libdevmapper 1.02.150 (2018-08-01) and kernel driver (unknown version).
Command failed.
Command failed.
Command failed.
Command failed.
done
And I found some interesting leads here : Incompatible libdevmapper on update-grub
And I checked :
$ sudo modprobe dm_mod
modprobe: FATAL: Module dm_mod not found in directory /lib/modules/4.14.66-1-MANJARO
$ sudo modprobe dm-mod
modprobe: FATAL: Module dm-mod not found in directory /lib/modules/4.14.66-1-MANJARO
If I reboot the issue disapears … but it bothers me because during that time my dual-boot is not working (there is a Manjaro entry but not a Windows entry in the Grub). I have to update Manjaro then reboot then run update-grub then everything is ok …
Any idea ?
#2
From Manjaro terminal, print out output of
efibootmgr -v
sudo parted -l
sudo blkid
findmnt -s
ls /boot/efi/EFI/
Provide information of all disks.
#3
Just curious , have you tried a newer kernel such as 4.18 or 4.19 ?
#4
The issue takes place with all few last kernels up to 18 (not tried 19 yet)
#5
If I understand correctly, now you can run update-grub successfully and have a proper grub multiboot menu. The (quoted) sequence you mention is the proper one AFAIK.
#6
To be honest I’ve always updated grub upon a reboot after a system upgrade regardless if grub updated properly or not during the upgrade itself simply due to the reboot being necessary for the updates to be applied to the kernel and modules anyway . So it’s really kind of a no issue . I am a gamer and I’ve been dual booting with Windoze 10 and Manjaro for two years without a hitch doing it that way . You may have a lesser incidence of your issue with another kernel but the reboot is still gonna be necessary after a kernel update anyway .
#7
At my case on the NAS with the problem the output is:
~ >>> efibootmgr -v
EFI variables are not supported on this system.
~ >>> sudo parted -l
[sudo] password for user:
Model: ATA SPCC Solid State (scsi)
Disk /dev/sda: 120GB
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type     File system  Flags
 1      1049kB  538MB  537MB  primary               boot
 2      538MB   120GB  119GB  primary  ext4
Model: ATA WDC WD20EZRZ-00Z (scsi)
Disk /dev/sdb: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name                  Flags
 1      1049kB  2000GB  2000GB               zfs-26013cea79add312
 9      2000GB  2000GB  8389kB
Disk /dev/sdc: 2000GB
Disk Flags:
 1      1049kB  2000GB  2000GB               zfs-d63dca6b21a0ea0a
~ >>> sudo blkid
/dev/sda1: PARTUUID="f19d5f5e-01"
/dev/sda2: UUID="000f5465-0e55-4a44-9836-86d3a5b78b76" TYPE="ext4" PARTUUID="f19d5f5e-02"
/dev/sdc1: LABEL="data" UUID="14318109765728649202" UUID_SUB="7571353807103248258" TYPE="zfs_member" PARTLABEL="zfs-d63dca6b21a0ea0a" PARTUUID="b0f661ec-efc3-4443-aa50-a83d3152a2f5"
/dev/sdc9: PARTUUID="c873c916-4c31-b445-9637-1b57b5eb84d4"
/dev/sdb1: LABEL="data" UUID="14318109765728649202" UUID_SUB="14439258925625876186" TYPE="zfs_member" PARTLABEL="zfs-26013cea79add312" PARTUUID="ab86aef6-2b6b-cc4e-a89e-ae904b1e681a"
/dev/sdb9: PARTUUID="619df13f-822b-c54d-aaa4-ee3d062dd004"
~ >>> findmnt -s
TARGET SOURCE                                    FSTYPE OPTIONS
/      UUID=000f5465-0e55-4a44-9836-86d3a5b78b76 ext4   rw,noatime,data=ordered
none   /swapfile                                 swap   defaults
~ >>> ls /boot/efi/EFI/
ls: cannot access '/boot/efi/EFI/': No such file or directory
#8
What does this have to do with this topic?
Please, start another topic for your issue.
#9
There is a ref to Incompatible libdevmapper on update-grub with similar issue. And I’m that topic starter. Do you really checked the ref?
#10
The issue disappears on reboot for the reasons I’ve already stated in my earlier post . It’s simply necessary housekeeping in a dual boot setup . It’s going to be the same regardless of distro , I have to do the same thing with Linux Mint after a kernel update or whatever other distro I have as linux du jour . It is really not an issue .
#11
I could not imagine, I apologize!
Why did you post that boot-related output?
#12
Few messages above @gohlip asked these commands output.
#13
@Retic1959
Yours is on msdos and you have Linux Mint and Manjaro.
After a kernel change in Linux Mint, yes, you need to go to Manjaro (the ‘controlling’ grub) to do an ‘update-grub’ to incorporate the new kernel there. The OP’s case is different.
@student975
You have mixed gpt and msdos and you’re booting up Manjaro in bios-legacy.
While it is not so much an issue on linux OS’s grub (with newer kernels), it will be a problem with windows not having the same boot mode as the linux OS. You will still face some issues occasionally and may need some ‘tweaks’ to go round it.
But thanks both for your input and thoughts [1].
Well, we’ll wait for the OP to provide the infomation, if he/she wish.
Entirely up to him/her. [2]
[1] - Meant that sincerely. Some have thought my politeness as condescending, sarcastic or worse.
I only do that to my best pals or my worst enemies. And some cannot differentiate between the two. :stuck_out_tongue_closed_eyes: Ho! Ho! Relax, don’t take everything so seriously. Life is short, have a bit of fun.
[2] - I think OP does not have the booting $esp in the internal drive.
But we can still fix it, if he replies, and if he want to.
#14
It’s a single-boot headless self-made NAS without windows or other furniture :slight_smile:
So, must I just ignore the issue?
#15
I guess, since your issue is solved with a module loading, it will be fixed for the other kernels with the next updates. Jonathon may know better.
#16
Sorry but you misunderstood . I have the exact same situation as the OP, after a kernel update in Manjaro grub doesn’t update during the upgrade process , it has nothing to do with Linux Mint . I was simply stating that I had to do the same thing when dual booting Windows with Linux Mint . After a kernel update in Manjaro the grub fails to update and I lose my Windows entry in grub . It requires a reboot and updating grub manually in the terminal to correct . This is SOP as far as I’m concerned .
#17
That should not happen. Kernel updates in any linux OS will generate a grub.cfg that will incorporate the new kernel automatically for us.
Unless… you have (or had in the past (will remain after uninstalled)) installed grub-customizer.
If you did not, just reinstall grub and see if that happens again.
Good luck.
It’s not good to mix uefi OS’s with bios-legacy OS’s or msdos disks with gpt disks (with OS’s in them). It (grub) may work with just linux OS’s in them, sometimes and sometimes not.
If it is working now for you, and reinstalling (need to wipe disk to fix it) is understandably best avoided, best to boot up the OS’s using their own grub rather than the other OS grub.
#18
Never used a Grub customizer and the situation is inconsistent for me and applies to multiple distro’s and computers . Since you have to reboot for the upgrade to be applied to a kernel and modules anyway & a simple sudo update-grub fixes it , it’s really a non issue IMO .
#19
Okay, understand. Just surprised you need to do that.
Cheers, take care.
#20
Sorry I’m late (I hope not too much), I had a rough week then hollidays then my-life-is-too-complicated-to-explain-here-and-does-not-interest-anyone ^^
But I’m very glad to see the issue leads to a lot of interesting talks :blush:
For the commands :
$ efibootmgr -v
$ sudo parted -l
Model: ATA SAMSUNG HD103UJ (scsi)
Disk /dev/sda: 1000GB
Disk Flags:
 1      1049kB  106MB   105MB   primary  ntfs         boot
 2      106MB   78.6GB  78.5GB  primary  ntfs
 3      78.6GB  1000GB  922GB   primary  ntfs
Model: ATA WDC WD10EARS-00Y (scsi)
Disk /dev/sdb: 1000GB
Disk Flags:
 1      1049kB  1000GB  1000GB  primary  ext4
Disk /dev/sdc: 1000GB
Disk Flags:
 1      1049kB  8390MB  8389MB  primary  linux-swap(v1)
 2      8390MB  60.8GB  52.4GB  primary  ext4
 3      60.8GB  1000GB  939GB   primary  ext4
Model: WD Elements 10B8 (scsi)
Disk /dev/sdd: 3001GB
Sector size (logical/physical): 4096B/4096B
Disk Flags:
 1      1049kB  3001GB  3001GB  primary  ntfs
Warning: Unable to open /dev/sr0 read-write (Read-only file system).  /dev/sr0
has been opened read-only.
Error: /dev/sr0: unrecognised disk label
Model: ASUS DRW-20B1LT (scsi)
Disk /dev/sr0: 8072MB
Sector size (logical/physical): 2048B/2048B
Partition Table: unknown
Disk Flags:
$ sudo blkid
/dev/sda1: LABEL="RM-CM-)servM-CM-) au systM-CM-(me" UUID="A43272113271E926" TYPE="ntfs" PARTUUID="0001be35-01"
/dev/sda2: LABEL="Win7" UUID="C6149CCF149CC439" TYPE="ntfs" PARTUUID="0001be35-02"
/dev/sda3: LABEL="Jeux" UUID="50144E6D144E565E" TYPE="ntfs" PARTUUID="0001be35-03"
/dev/sdc1: UUID="8c33ce28-7191-4040-bbd4-ad349b99dbd6" TYPE="swap" PARTUUID="12c625c6-01"
/dev/sdc2: LABEL="ManjaroLinux" UUID="dfd31e24-625f-4585-9380-ddaa71824845" TYPE="ext4" PARTUUID="12c625c6-02"
/dev/sdc3: LABEL="Home" UUID="b4bdc515-5b3e-4b02-8e8e-b54d9d30201c" TYPE="ext4" PARTUUID="12c625c6-03"
/dev/sdb1: LABEL="Data" UUID="c152acad-2fa2-4670-be57-c217796ea615" TYPE="ext4" PARTUUID="158b158a-01"
/dev/sr0: UUID="47cf9fb6000002cf" LABEL="CNC3KW" TYPE="udf"
/dev/sdd1: LABEL="Elements" UUID="54D8D96AD8D94ABE" TYPE="ntfs"
$ findmnt -s
swap   UUID=8c33ce28-7191-4040-bbd4-ad349b99dbd6 swap   defaults,noatime
/      UUID=dfd31e24-625f-4585-9380-ddaa71824845 ext4   defaults,noatime
/home  UUID=b4bdc515-5b3e-4b02-8e8e-b54d9d30201c ext4   defaults,noatime
$ ls /boot/efi/EFI/
And I didn’t try an other kernel than the 4.14.x and I didn’t customize my Grub either btw.
Thanks for the help guys :+1:
PS : I still have the issue with the 4.14.70-1
