I already watched grub.cfg
by myself. It’s really long.
And what I think is suspicious: there are serveral parts in file where text “/boot” within path to files “*.img” is multiple duplicated like this:
initrd /boot/boot/boot/boot/boot/boot/boot/intel-ucode.img
sometimes it’s duplicated “over 9000” times))).
[dm@manjaro ~]$ sudo cat /boot/grub/grub.cfg
[sudo] password for dm:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod btrfs
set root='hd1,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,gpt2' --hint-bios=hd1,gpt2 --hint-efi=hd1,gpt2 --hint-baremetal=ahci1,gpt2 25461172-4d72-4aa7-b17f-f0a5be876826
else
search --no-floppy --fs-uuid --set=root 25461172-4d72-4aa7-b17f-f0a5be876826
fi
font="/@/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=ru_RU
insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod btrfs
set root='hd1,gpt2'
else
fi
insmod gfxmenu
loadfont ($root)/@/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/@/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/@/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=3
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 3 ; then
set timeout=0
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-25461172-4d72-4aa7-b17f-f0a5be876826' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,gpt1' --hint-bios=hd1,gpt1 --hint-efi=hd1,gpt1 --hint-baremetal=ahci1,gpt1 C3ED-C4D7
else
search --no-floppy --fs-uuid --set=root C3ED-C4D7
fi
linux /vmlinuz-5.4-x86_64 root=UUID=25461172-4d72-4aa7-b17f-f0a5be876826 rw rootflags=subvol=@ quiet udev.log_priority=3
initrd /intel-ucode.img /amd-ucode.img /initramfs-5.4-x86_64.img
submenu 'Дополнительные параметры для Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-25461172-4d72-4aa7-b17f-f0a5be876826' {
menuentry 'Manjaro Linux (Kernel: 5.4.124-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.124-1-MANJARO x64-advanced-25461172-4d72-4aa7-b17f-f0a5be876826' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel: 5.4.124-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.124-1-MANJARO x64-fallback-25461172-4d72-4aa7-b17f-f0a5be876826' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /initramfs-5.4-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Manjaro Linux (на /dev/sdb2)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
submenu 'Дополнительные параметры для Manjaro Linux (на /dev/sdb2)' $menuentry_id_option 'osprober-gnulinux-advanced-25461172-4d72-4aa7-b17f-f0a5be876826' {
menuentry 'Manjaro Linux (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/intel-ucode.img /boot/boot/boot/amd-ucode.img /boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.124-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Manjaro Linux (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/intel-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/amd-ucode.img /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64.img
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Manjaro Linux (Kernel 5.4.105-1-MANJARO x64 - fallback initramfs) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-5.4-x86_64--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/boot/initramfs-5.4-x86_64-fallback.img
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
linux /memtest86+/memtest.bin
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Memory Tester (memtest86+) (на /dev/sdb2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/memtest86+/memtest.bin--25461172-4d72-4aa7-b17f-f0a5be876826' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/41_snapshots-btrfs ###
submenu 'Manjaro Linux snapshots' {
configfile "${prefix}/grub-btrfs.cfg"
### END /etc/grub.d/41_snapshots-btrfs ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
search --fs-uuid --no-floppy --set=root --hint-ieee1275='ieee1275//disk@0,gpt1' --hint-bios=hd1,gpt1 --hint-efi=hd1,gpt1 --hint-baremetal=ahci1,gpt1 C3ED-C4D7
linux16 /memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
