Hi All.
I’m new to Linux and have been using it for about 6 months. This is my first time in the forum here. All has been OK so far with my step over to Linux. The last 3 weeks, I had to step away and have come back to a lot of updates. I ran the update and there was an error. Some more updates happened today and the same error has appeared. The result of the update was a ‘success’ but there was a pop up box that said an error occured. First appearance in the update below.
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
==> ERROR: '/lib/modules/5.7.19-2-MANJARO' is not a valid kernel module directory
Error while configuring
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'default'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
==> Starting build: 5.8.18-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
It then continues OK through linux58 and in to linux59. I assume this is updating the kernel because it needed it and there were errors in the update on the old one??
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
==> Starting build: 5.9.11-3-MANJARO
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
Error: command failed to execute correctly
Reloading system bus configuration...
Warn about old perl modules
Copy Firefox Distribution Settings
fix appstream datas for pamac
archive usr/share/app-info/xmls/community.xml.gz fixed
Compiling GSettings XML schema files...
Updating icon theme caches...
Hiding redundant menu entries
Updating the info directory file...
Updating the appstream cache...
AppStream cache update completed successfully.
Updating the desktop file MIME type cache...
Updating the MIME type database...
What is going on here? Anything to worry about with the last error? I have noted that my system is running the last build 5.9.11-3-MANJARO.
Thanks in advance.
