Update causes dependency error and stops
This is the error message:
installing boost-libs (1.92.0-1) breaks dependency 'libboost_filesystem.so=1.91.0-64' required by wsjtx
I recently built the wsjtx package and now cannot upgrade with this error.
Anything I can do to get around it?
Remove the wsjtx package:
sudo pacman -R wsjtx
Then run your update:
sudo pacman -Syu
Then rebuild the wsjtx package:
pamac build wsjtx
Thank you. Perfect, quick and easy.
