There is a new entry named Manjaro Linux on /dev/nvmenp2 and Advanced options for /dev/nvme0n1p2.
This option appeared after I recovered an older snapshot from timeshift.
Is there a way to get rid of these? Also the snapshots
One more issue:
Each snapshot created from time shift has versions corresponding to kernel 6.1, kernel 6.2, kernel 6.3 and I don’t need all of these. Just versions corresponding to kernel 6.3 would suffice. So how do I get rid of the remaining ones?
Yes possible if snapshots are writeable and allow you to delete the old kernels. But that makes you a lot of work to manually check and uninstall the old Kernels correctly via pacman in each snapshot.
