Hi all,
Helpfull as Manjaro is, it pointed out today that I have an unsupported kernel on my system and I should remove it.
Fair enough.
Which is safest? CLI or interface (settings manager)?
What could be the concequences?
Thanks
Melissa
As long as you don’t remove the kernel you are running on when you do it, either should be fine.
Let’s do some sprint cleaning then
Melissa
