Hey there.
Currently I’m trying to run a dual monitor setup where my second monitor is working (connected to my mobo) and my primary monitor is black (connected to GPU). I’m using a Nvidia 2080 Super and a i5 4690.
in xrandr we can see only one the onboard GPU is being identified. Probably because I’ve passed the PCI-E GPU using PCI passthrough via OVMF guide from archlinux wiki.
What I want to accomplish is having 2 setups. One is my main SO which is manjaro to study and work and the other a windows virtualization for gaming with friends and stuff.
The first setup it would be ideal to have two monitors (in windows this configurations was easy to achieve). One primary and other secondary.
Once I turn on the windows virtualization only my primary monitor would work in order to play games (here I don’t need two monitors but it would be nice to have).
I thought it would be possible to use all nvidia maybe? Or once I switch to all Nvidia my screens wouldn’t display any images because my PCI is passthrough to OVMF?
Thanks in advance for any comments on this…
xrandr result:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
VGA-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
1920x1080 60.00*+ 50.00 59.94
1920x1080i 60.00 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32
720x576 50.00
720x576i 50.00
720x480 60.00 59.94
720x480i 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
HDMI-2 disconnected (normal left inverted right x axis y axis)
lspci | grep VGA result:
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06)
01:00.0 VGA compatible controller: NVIDIA Corporation TU104 [GeForce RTX 2080 SUPER] (rev a1)
