Hello
I recently updated my system to the latest Manjaro version and a problem appeared. I’m connected to Internet via wifi. The system has internet for a bit and then it doesn’t. The peculiar thing is that the system still reports to be connected to the wifi. I have to reconnect a few times and then its back to normal. Then it happens again.
Some things I’ve experimented:
- Wired connection is ok.
- Phones don’t seem to have a problem with connecting to this wifi source.
- If I hotspot a phone connected to this wifi and then connect my system to the hotspot it runs without disconnections.
- I’ve booted Manjaro from a USB and it has the same issue.
It’s odd because all the other systems connected to this wifi seem to run normally.
I’m running Manjaro Gnome. Here’s my inix -F
Summary
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 43.1 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20KS0039PG v: ThinkPad E580
serial: <superuser required>
Mobo: LENOVO model: 20KS0039PG v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R0PET68W (1.45 )
date: 04/29/2021
ID-1: BAT0 charge: 35.7 Wh (91.3%) condition: 39.1/45.7 Wh (85.5%)
Info: quad core model: Intel Core i7-8550U bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 699 min/max: 400/4000 cores: 1: 694 2: 700 3: 700 4: 700
5: 700 6: 700 7: 700 8: 700
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
driver: amdgpu v: kernel
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
Display: wayland server: X.Org v: 22.1.5 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: amdgpu,intel
unloaded: modesetting dri: i965,radeonsi gpu: i915
resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2)
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-1: PipeWire v: 0.3.61 running: yes
driver: r8169
IF: enp3s0 state: down mac: e8:6a:64:5d:67:6e
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
IF: wlp5s0 state: up mac: 1c:1b:b5:90:55:a1
Local Storage: total: 1.14 TiB used: 185.94 GiB (15.9%)
ID-1: /dev/nvme0n1 vendor: Lenovo model: LENSE30256GMSP34MEAT3TA
ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-1: / size: 65.92 GiB used: 61.07 GiB (92.6%) fs: btrfs
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 511 MiB used: 588 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 167.08 GiB used: 124.86 GiB (74.7%) fs: btrfs
dev: /dev/nvme0n1p4
ID-4: /var/log size: 65.92 GiB used: 61.07 GiB (92.6%) fs: btrfs
dev: /dev/nvme0n1p3
ID-1: swap-1 type: partition size: 4.98 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p2
System Temperatures: cpu: 53.0 C pch: 47.5 C mobo: N/A gpu: amdgpu
temp: 48.0 C
Fan Speeds (RPM): fan-1: 0
Processes: 311 Uptime: 16m Memory: 7.53 GiB used: 2.06 GiB (27.3%)
Shell: Zsh inxi: 3.3.24
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
With HTML, please use <pre><code>
, not just <pre>
