I want to log in to google through the settings in manjaro but when i click on it it opens a white empty tab and stays that way no matter what i do, send help
i looked through a bunch of similar forums and found this one Trouble connecting Google account - #3 by narender
which apparently worked for the guy but im new here and cant even properly use a terminal without having a set of commands on my notepad beside me.
If the above mentioned forum really is the solution can someone guide me through the process?
I dont think you meant to link the post you did.
Maybe this one instead:
In which case it is as written - just copy the following command and hit enter:
WEBKIT_DISABLE_COMPOSITING_MODE=1 MESA_LOADER_DRIVER_OVERRIDE=i965 gnome-control-center online-accounts
Though thats assuming its the same. For one thing its forcing use of intel … and I dont know your gfx setup.
mhwd -l -li
inxi -Fazy
mhwd -l -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2023.03.23 false PCI
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
> 0000:01:00.0 (0300:10de:1f82) Display controller nVidia Corporation:
video-nvidia-470xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
i tried the command you gave
but then it just opened the online settings, the supposedly login-in tab is still showing only white
