@philm could it be possible that for grub updates we get a thread similar to those eos does? Just an idea for gathering in the same place the most common solutions for any grub-related problem, if they ever happen again, as they happen.
Yep, I remember we had the same when grub gets pkg updates.
We could update the grub.install
Please revert as it might break more installs than solving anything @Yochanan. See my comment here. [pkg-upd] 2.06.r456.g65bc45963-3 (3eeb3603) · Commits · Packages / Core / grub · GitLab You can also re-read the remark from Arch.
i agree, usually i think everyone(who has experience installing bootloader) has their own set of parameters they supply to their respective setups and a generic command would not work. however as someone suggested, probing how calamares does it (most of the time) successfully is worth a shot. till then this should remain forwarding people to the wiki with all the options for the respective setups.
Upgrading libvirt from 9.1.0 to 9.2.0 breaks the compatibility of loses the ability to create a new internal snapshots of KVM.virt-manager, which
See the error message of virt-manager when creating a new internal snapshot of KVM:
Error creating snapshot: Operation not supported: internal snapshots of a VM with pflash based firmware are not supported
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 72, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/details/snapshots.py", line 237, in _do_create_snapshot
self.vm.create_snapshot(xml)
File "/usr/share/virt-manager/virtManager/object/domain.py", line 1197, in create_snapshot
self._backend.snapshotCreateXML(xml, flags)
File "/usr/lib/python3.10/site-packages/libvirt.py", line 3119, in snapshotCreateXML
raise libvirtError('virDomainSnapshotCreateXML() failed')
libvirt.libvirtError: Operation not supported: internal snapshots of a VM with pflash based firmware are not supported
Solution:
Downgrade to libvirt 9.1.0 and then reboot to fix the issue.
Edit:
Creating internal snapshot hat the limit with UEFI, but it has no issue with legacy BIOS.
Creating external snapshot is a solution.
I’ve linked to the wiki instead: [pkg-upd] 2.06.r456.g65bc45963-4 (81678efb) · Commits · Packages / Core / grub · GitLab
I reckon it might be worth listing manjaro-rescue as an option there next to those wiki entries. Grub is very technical.
One will only see that message the first time grub is installed.
May be grub package update should make influence onto new stable ISO release date by making it closer to grub package release date. Thus more new Manjaro installations will be assured to receive important updates of grub by the new installation procedure.
Also want to note that the stable/testing ISO releases are absent for more than 2 months in the Releases · manjaro/release-review · GitHub
Thanks!
All the cominity ones are January i.e. three months
Don’t forget to check in the Manjaro Development section from time to time. ![]()
