A post was split to a new topic: Getting horrible screen tearing on every game I play on second monitor
woohoo timeshift
is in manjaro repos
Found the culprit of my issue, wireplumber!
So hereās the problem: if you were running pulseaudio then the wireplumber daemon will not let pulseaudio play audio, and therefore pulseaudio will break.
If you switch to pipewire then all media will work, but then I was curious to see why MPRIS was not.
Running systemctl --user status wireplumber
, I found the following error message
<WpSiAudioAdapter:0x55daa9d25080> Object activation aborted: proxy destroyed
It seems that wireplumber destroys the mpris-proxy
daemon, and therefore pausing and playing from bluetooth headsets no longer works.
To fix my MPRIS issue I did the following:
- switch back to pulseaudio
- disable the wireplumber systemd service
- rebooted
PS: It still seems that wireplumber randomly starts at boot whenever it wants, so make sure to add killlall wireplumber
as a startup command in your desktop environment/window manager
Now all audio is playing and MPRIS is working fine. Since this issue was only introduced in this unstable update, it isnāt very well documented, so Iām gonna leave some SEO keywords here so that people with the same problem can easily google it and run into this post.
search keywords
mpris-proxy not working pipewire, mpris not working pipewire, pulseaudio audio not working, mpris pipewire, mpris wireplumber, mpris not working manjaro, cant pause and play bluetooth audio pipewire
No need for this.
It is documented and already posted in this very thread: Arch Linux - News: Undone replacement of pipewire-media-session with wireplumber
For some reason the vmmon
module which is relevant for the VMware Network Stack is missing. On 5.15.39 (tested) not sure if this is the case for all kernel series.
Even if headers are installed.
:: installing qt5-base (5.15.4+kde+r135-1) breaks dependency 'qt5-base<5.15.4' required by manjaro-settings-manager
How to fix it?
Sync your mirrors, youāre missing manjaro-settings-manager
0.5.7-4.
Hi,
Would it be possible to decouple the dependency between malcontent and flatpak?
malcontent is a dependency for gnome-control-center and it means by extension gnome-control-center requires flatpak.
And I absolutely donāt want flatpak installed on my system. I resorted to a different control center for now.
Unfortunately not.
malcontent relies on flatpak quite heavilyā¦
Every time you think Gnome has hit rock bottom, they manage to find some rock drilling excavator to go even further belowā¦
Good news! Arch just split libmalcontent
out of malcontent
in Arch Testing. Weāll see how they manage that.
Thanks for the follow-up!
Hopefully, this allows for a snapflatpak-free experience.
Once flatpak is installed, it means open days and any flatpak packaged app can be installed without my consent or even me noticing.
In my opinion, going back to the medieval Windows computer era of bundled packages and unshared libraries is really not a good prospect for the future. I want to avoid this at all costs.
Systemd 251 is out with a lot of major changes. The minimum kernel version required has been bumped from 3.13 to 4.15. This of course means Manjaro will have to drop the 4.9 and 4.14 LTS kernels.
@philm wants to wait because major Systemd releases can cause issues and it may take a point release or two to iron out bugs.
Arch has had the two release candidates in their Testing branch for over two weeks. The stable 251 release is now in Arch Stable.
What you do think?
- Bring it on! Bugs be damned!
- No! Iām too scared
0 voters
P.S. I already built it and installed it. Running fine so farā¦
This and and approaching Plasma 5.25 with lots of under the hood changes makes me want to switch branch to Testing or postpone updates until first point releases are rolled out
But why not, really. I have backups anyway. Rock on!
I spot (not so) subtle wording to influence the poll
