what is status of the mesa 21 ?
mesa 21 is in testing repo on Arch Linux
Anyone else experiencing random Gnome shell restarts after the latest update from yesterday?
Mar 23 07:34:22 manjaro systemd-coredump[427085]: Process 397030 (gnome-shell) of user 1000
dumped core.
Linux manjaro 5.12.0-1-MANJARO #1 SMP PREEMPT Sun Mar 21 22:24:02 UTC 2021 x86_64 GNU/Linux
I am. My extensions were automatically disabled, but the system has stabilized and I’m able to browse, open apps and do some work.
I tried with 5.12 and 5.11 but the issue stills happens opening some app from shell.
I’m on 5.11. It could have something to do with which extensions you’re using. I guess this is the beginning of the expected chaos as Gnome 40 components are slowly introduced…
Manually installed:
- Flipper Move Clock
- Hide Top Bar
- User Themes
I have User Themes and go with the stock Manjaro dark theming, which doesn’t seem to have been effected at this point. I’m relatively new to Gnome (it took a while for me to realize it’s my favorite, after 20 years of XFCE, KDE and all the others), but I’ve heard that even if a particular extension is not enabled, having it installed can cause problems when Gnome moves from one version to another. I imagine it could also have something to do with graphics hardware, etc.
Already disabled all extensions, changed to 5.11 (At this point I can discard a kernel issue), so far no more crashes.
Yes, on two systems. It appears the gjs 2:1.68.0-2 update affected more than one extension. Downgrading to 2:1.66.2-1 solved the issue.
total fail with this update … I have to restore snapshot to be able to boot, is starting to roll in Gnome 40, but something is not ok and all screens are flickering mess, intel iGPU + Nvidia on laptop.
edit: all extension are disabled, app drawer is flickering like crazy and writing on top without clear
edit 2: background is rendered as transparent, no matter what I select as picture in settings
edit3: gnome-tweaks is not starting at all
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: Traceback (most recent call last):
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: File "/usr/lib/python3.9/site-packages/gtweak/app.py", line 29, in do_activate
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: self.win = Window(self, model)
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: File "/usr/lib/python3.9/site-packages/gtweak/tweakview.py", line 59, in __init__
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: self._model.load_tweaks(self)
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: File "/usr/lib/python3.9/site-packages/gtweak/tweakmodel.py", line 107, in load_tweaks
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: mods = __import__("gtweak.tweaks", globals(), locals(), tweak_files, 0)
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: File "/usr/lib/python3.9/site-packages/gtweak/tweaks/tweak_group_font.py", line 104, in <module>
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: FontXSettingsTweak(),
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: File "/usr/lib/python3.9/site-packages/gtweak/tweaks/tweak_group_font.py", line 32, in __init__
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: self.btn_full.set_active(self.settings["hinting"] == "full")
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: File "/usr/lib/python3.9/site-packages/gi/overrides/Gio.py", line 259, in __getitem__
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: raise KeyError('unknown key: %r' % (key,))
мар 26 12:56:45 org.gnome.tweaks.desktop[31386]: KeyError: "unknown key: 'hinting'"
Same here
Summary
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 Desktop: sway 1.5.1
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X556UQK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <filter>
UEFI: American Megatrends v: X556UQK.313 date: 03/13/2018
ID-1: BAT0 charge: 10.7 Wh (33.2%) condition: 32.2/38.0 Wh (84.7%)
volts: 7.6 min: 7.6
Info: Dual Core Intel Core i5-7200U [MT MCP] speed: 870 MHz
min/max: 400/1400 MHz
Device-1: Intel HD Graphics 620 driver: i915 v: kernel
Device-2: NVIDIA GM108M [GeForce 940MX] driver: nouveau v: kernel
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
Display: wayland server: X.Org 1.21.0.99 compositor: sway driver:
loaded: intel,nouveau unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
driver: r8169
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
driver: ath10k_pci
Local Storage: total: 1.03 TiB used: 18.31 GiB (1.7%)
Processes: 223 Uptime: 7m Memory: 11.59 GiB used: 2.05 GiB (17.7%)
Shell: Zsh inxi: 3.3.03
Same problem with Gnome 40 update here as well, lots of flickering in app drawer. It might be a nvidia problem or it might be a manjaro problem, not sure.
When it comes to Gnome-tweaks, it needs to be updated to new version but its still in beta.
I am using prime offload so Gnome is running on iGPU
So, flickering issues in iGPU and Nvidia?
I think that problem is connect with theme, but I am not entirely sure
I suspected the same thing and tried new Materia theme, which has a support for Gnome40.
Problem is not with theme.
I also tried gnome-shell-dev and Gnome 40 isos from github in the past and didn’t experience any flickering/layering there…
It doesn’t seem to be gpu-related, since the problem only occurs within the app drawer.
I might try gnome-shell40alfa from aur.
https://aur.archlinux.org/packages/gnome-shell-40alfa
You can try, but at this point it’s about Manjaro’s integration of Gnome 40.
