[Unstable Update] 2019-04-20 - gcc, kde, deepin
unstable
update
#1
gcc 8.3.0 has arrived and I will start re-building all our kernels with their latest updates and extramodules now...
Also new Kde and Deepin package versions are here.
Current supported Kernels
  • linux316 3.16.65
  • linux318 3.18.138 [EOL]
  • linux44 4.4.168 (nvidia-340xx module no longer available!)
  • linux49 4.9.169 > 4.9.170
  • linux414 4.14.112 > 4.14.113
  • linux419 4.19.35 > 4.19.36
  • linux420 4.20.17
  • linux50 5.0.8 > 5.0.9
  • linux51rc 5.1rc1.d0317.g9e98c67 (experimental, currently no extramodules)
  • linux419-rt 4.19.31_rt18
  • linux50-rt 5.0.7_rt5
The full list of updated packages to be found here.
0 voters
Almost everything went smoothly. The only issue was a rhythmic clicking through wireless headphones that would come through when no sound was playing.
Solved by disabling power saving in TLP as per this thread Audio *click* when sound is about to play and when sound finishes playing
Everything seems to be OK at this point. Had to reinstall my kernel 5.0.9 just to keep it above updated 4.19 in rEFInd menu - but it has nothing to do with the very update.
#4
Am fully updated and see no problems, as usual.
#5
@oberon , i see a new version glibc,
does it means all will be again compiled ?
#6
#7
Not sure.
#8
@jonathon can you please have a look at this overlay pkg? Thanks.
newer overwritten sync packages:
   [OVERWRITTEN SYNC PACKAGE]  ->  [LOCAL PACKAGE]
   openssh-8.0p1-1-x86_64.pkg.tar.xz  ->  openssh-7.9p1-1.1-x86_64.pkg.tar.xz
#9
It depends. When extramodules are updated they sometimes complain when compiler version of the kernel is different, not sure about dkms ... we shall find out, soon :wink:
However, we have a lot of new versions of kernels anyway and I just built them with their modules.
We now have:
5.0.9
4.19.36
4.14.113
and
4.9.170
But still 5.1-rc1... :thinking:
#11
Looks like the VirtualBox issues have been solved in Arch and they have uploaded a new build.
That has now been removed. The overlay package was a security update which shouldn't be needed now.
Edit: It looks like boxit has broken on the server - I don't know if you have access to be able to clear it?
Errors of branch unstable
uncomplete desc file '/var/tmp/boxit/sessions/sync_session/.db/metasploit-5.0.9-1/desc'!
Yes. I am trying to fix it - am in contact with Phil also ... We shall see.
#14
And apparently packages are dropped to AUR and require "update"
Rebuilding of pacman-mirrors is failing
#15
$ pacman -Si spectre-meltdown-checker xcursor-breeze xfce-theme-greybird
Repository      : community
Version         : 0.37-1
Description     : Spectre & Meltdown vulnerability/mitigation checker
                  (CVE-2017-5753, CVE-2017-5715, CVE-2017-5754)
Architecture    : any
URL             : https://github.com/speed47/spectre-meltdown-checker
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : bash
Optional Deps   : None
Conflicts With  : None
Replaces        : None
Download Size   : 44.41 KiB
Installed Size  : 161.00 KiB
Packager        : Philip Mueller <philm@manjaro.org>
Build Date      : So 29 Apr 2018 12:32:10 CEST
Validated By    : MD5 Sum  SHA-256 Sum  Signature
Version         : 5.11.5-1
Description     : KDE5 cursor theme
Architecture    : any
URL             : http://kde-look.org/content/show.php/Breeze?content=165371
Licenses        : GPL
Groups          : None
Provides        : breeze-snow-cursor-theme
Depends On      : libxcursor
Conflicts With  : breeze-snow-cursor-theme
Replaces        : breeze-snow-cursor-theme
Download Size   : 271.07 KiB
Installed Size  : 5346.00 KiB
Packager        : Bernhard Landauer <oberon@manjaro.org>
Build Date      : Fr 19 Jän 2018 20:33:43 CET
Version         : 3.22.9+1-1
Description     : A grey and blue Xfce theme.
Architecture    : any
URL             : https://github.com/shimmerproject/Greybird
Licenses        : CCPL:by-sa-3.0  GPL
Groups          : None
Provides        : None
Depends On      : gtk-engine-murrine
Optional Deps   : elementary-xfce-icons: Matching icon set; use the dark icon
                  theme
                  shimmer-wallpapers: Contains the Greybird wallpaper, among
                  others
                  lightdm-gtk-greeter: Required for the LightDM GTK theme
                  lightdm-unity-greeter: Required for the LightDM Unity theme
                  lib32-gtk-engine-murrine: Required for 32-bit apps in 64-bit
                  environments
Replaces        : None
Download Size   : 200.68 KiB
Installed Size  : 1188.00 KiB
Build Date      : So 21 Okt 2018 10:20:23 CEST
Everything back to normal now. Thanks!
Now i get the update for
:+1:
#17
While trying to apply the patch for Elan touchpads to mainline kernel I've encountered an error. It turned out that 5.1-rc6 had already received a bunch of relevant commits. So for 5.1 both Elan and tpm2 patches are not needed @philm @oberon
#18
$ pacman -Qi virtualbox
Version                  : 6.0.6-2
fixed the problem with the ACPI tables and Windows 7 VM boots normal.
:+1: to all guys working on this
@oberon
After the last upgrade on gnome (23/04/19) doesn't launch any qt5 app (virtualbox, kdenlive, e.t.c). The error is:
Cannot mix incompatible Qt library (version 0x50c03) with this library (version 0x50c02))
Incompatible Qt library after upgrade (5.12.3)
#20
In addition to @kouros17 - on KDE Plasma kwin crashes like a champ and in fact not even SDDM is able to be consistent :slight_smile:
This is from a VBox install but is the same on a bare metal install
None of the options work. The system is unusable.
