[Unstable Update] 2018-08-06 - Kernels, Python 3.7, Perl 5.28, LibreOffice
unstable
update
#22
Flameshot is an alternative you could consider. @LucyDemoon, Thunderbird 60 isn’t is the arch repos yet, so we’ll have to wait, I guess.
#23
@Berneri - Interesting, hadn’t heard of that one before. Only difference is that Shutter allows you to do annotations as well as screenshots which makes it useful sometimes, as far as I can tell from github Flameshot doesn’t offer that function.
I will wait and see if a new version of Shutter appears, but thanks anyway.
Edit: I was wrong, I had a play with Flameshot and it does do annotations - not as good as Shutter, but it has them just the same, they ought to mention that on github maybe more people would use it!
#24
Just finished the update on KDE Plasma. No issues that I can find on my system.
#26
Hi, I’m having a problem with powerpill after recently updating. This might have to do with the recent update to python 3.7
/usr/bin/python3: No module named Powerpill
#27
Calamares seems to need a rebuild also because I get an error when launching it from my fresh ISO built against unstable:
[manjaro@manjaro-awesome ~]$ calamares_polkit
/usr/bin/calamares: error while loading shared libraries: libpython3.6m.so.1.0: cannot open shared object file: No such file or directory
#28
Manjaro does not support AUR packages. You have to take this up with the package maintainer.
My mistake. Powerpill is in the Manjaro repos. I only checked for Arch packages.
#29
powerpill is in the community repos :wink:
#30
I have patched powerpill to work on Manjaro :wink:… I m not able to do this now… Wait after 13/8 (when come back to my pc) or @philm and @oberon can look into it… :grin:
#32
@Ste74: well I’ve to see. Seems more dependencies than one package for powerpill …
#33
Yep… I forgot to upload on gitlab the package build tree… My fault ( i will do it)… Also in package build if i remember you need to change the folder for python release (only for powerpill)
#34
Python packages in Community
phil@development ~/dev/git/manjaro/repositories/stable-repos/community $ grep python */PKGBUILD | grep -v python2 | cut -d/ -f1 | uniq
alternating-layouts
audacious-gtk3
audacious-plugins-gtk3
budgie-extras
compare-mirrors
compiz-manjaro
deluge
dockbarx
econnman
gimp-devel
gimp-gtk3
jade-dashboard-git
kmozillahelper
lightdm-settings
menulibre
ms-office-online
mugshot
nautilus-admin
networkmanager-dmenu
ob-autostart
ocrdesktop
pkgbrowser
pmenu
pocketsphinx
pulseaudio-equalizer-ladspa
python-efl
python-jade-application-kit
python-npyscreen
python-svgwrite
python-tesserwrap
python-xapp
sddm-classic
slack-online
snapd-git
snapd
snapper-gui
sphinxbase
terminus-font
tintwizard
transifex-client
udiskie
webdad-webapps-git
xapps
xdgmenumaker
xfce4-dockbarx-plugin
phil@development ~/dev/git/manjaro/repositories/stable-repos/community $ grep python */*/PKGBUILD | grep -v python2 | cut -d/ -f2 | uniq
cinnamon
deepin-desktop-base
mate-tweak
pm2ml
powerpill
python3-memoizedb
python3-xcgf
python3-xcpf
#35
Python packages Extra
phil@development ~/dev/git/manjaro/repositories/stable-repos/extra $ grep python */*/PKGBUILD | grep -v python2 | cut -d/ -f2 | uniq
a
xfce4-notifyd-gtk3
xfce4-power-manager-gtk3
phil@development ~/dev/git/manjaro/repositories/stable-repos/extra $ grep python */PKGBUILD | grep -v python2 | cut -d/ -f1 | uniq
calamares-git
calamares
cups-filters-driverless
gst-plugins-good
kinfocenter
kpmcore-dev
kpmcore
libglvnd
libinput-git
manjaro-features-dev
manjaro-features-pre
manjaro-hello
manjaro-printer
partitionmanager-dev
python-pykwalify
python-pyparted
pythonqt
samba
thus-dev
thus
#36
Today 1,400 MB update, new language pack, but Manjaro Setting do not work/open, neither in the menu bar nor under Settings
My fold? Due to my installation problems at that first time?
  1. Software-Aktualisierungen
  2. Software hinzufügen/entfernen
  3. Software hinzufügen/entfernen
    1.-3. all Pamac 6.5.0-1
#37
manjaro-settings-manager: error while loading shared libraries: libicuuc.so.61 needs a rebuild for icu update in unstable.
#38
Go again, thank you very much. :slight_smile:
Gnome Themes
Manjaro GNOME version 17.1.11: Settings Manager "disappeared"
#39
I dont know what is happening but with the latest updates all my AUDIO is a mess.
I mean everywhere I play Video with Audio is a mess with massive lag/noise/crackling etc.
I am using kernel 4.18rc8
#40
glibc 2.28-2, currently in Arch testing, seems to fix the issue with prebuilt electron apps. Skypeforlinux runs fine for me with 2.28-2.
#41
$ manjaro-settings-manager
qt5ct: using qt5ct plugin
error: failed to get installed kernels
QProcess: Destroyed while process (“pacman”) is still running.
Shutting down Manjaro Settings Manager…
#42
➜  ~ uname -r
4.18.0-1-MANJARO
#43
With Kernel 4.17 everything works fine :slight_smile:
