I don’t think so, i didn’t customize Manjaro att all and i don’t wanna do it.
The only thing i did was install ‘tlp’ and ‘optimus manager’ following these instructions:
And i have installed a couple of thing like spotify, telegram and brave, but that’s all.
“inxi -Fazy” output:
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=ac03895f-b869-431d-8f16-0b1e600319e2 rw quiet apparmor=1
security=apparmor resume=UUID=d03da114-39b9-4ef6-bea4-667e16058ae8
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.30 serial: <filter>
Mobo: CFL model: Octavia_CFS v: V1.30 serial: <filter> UEFI: Insyde v: 1.30
date: 05/11/2020
ID-1: BAT1 charge: 55.9 Wh condition: 56.0/57.5 Wh (97%) volts: 17.4/15.4
model: LGC AP18E8M type: Li-ion serial: <filter> status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
serial: N/A charge: 55% (should be ignored) rechargeable: yes
status: Discharging
Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 8192 KiB
bogomips: 38408
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Acer Incorporated ALI driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus ID: 1-5:3
chip ID: 04f2:b64f serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
[joaooswaldo@joaooswaldo-nitroan51554 ~]$ inxi -Fazy
udev.log_priority=3
date: 05/11/2020
status: Discharging
L2 cache: 8192 KiB
bogomips: 38408
Speed: 874 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 887 2: 850 3: 856
4: 833 5: 837 6: 812 7: 858 8: 817
Type: l1tf
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.9.11-3-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 07:00.0 chip ID: 10ec:8168
IF: enp7s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus ID: 08:00.0 chip ID: 8086:2723
IF: wlp8s0 state: up mac: <filter>
Device-3: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
bus ID: 1-4.4:7 chip ID: 045e:0719 serial: <filter>
Local Storage: total: 1.03 TiB used: 180.47 GiB (17.2%)
ID-1: /dev/nvme0n1 vendor: A-Data model: IM2P33F8BR1-128GB size: 119.24 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: S1107B0L scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-1: / raw size: 114.70 GiB size: 112.40 GiB (97.99%)
used: 14.54 GiB (12.9%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /home raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 165.93 GiB (18.1%) fs: ext4 dev: /dev/sda1
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2
System Temperatures: cpu: 58.0 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 261 Uptime: 13m Memory: 15.48 GiB used: 2.07 GiB (13.4%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1275 pacman: 1267
lib: 362 flatpak: 0 snap: 8 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
“sudo dmesg | grep usb” output
[ 0.240970] usbcore: registered new interface driver usbfs
[ 0.240970] usbcore: registered new interface driver hub
[ 0.240970] usbcore: registered new device driver usb
[ 0.452300] usbcore: registered new interface driver usbserial_generic
[ 0.452302] usbserial: USB Serial support registered for generic
[ 1.071254] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.071255] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.071256] usb usb1: Product: xHCI Host Controller
[ 1.071257] usb usb1: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
[ 1.071257] usb usb1: SerialNumber: 0000:00:14.0
[ 1.072142] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.072143] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.072144] usb usb2: Product: xHCI Host Controller
[ 1.072145] usb usb2: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
[ 1.072145] usb usb2: SerialNumber: 0000:00:14.0
[ 1.072391] usb: port power management may be unreliable
[ 1.400949] usb 1-4: new high-speed USB device number 2 using xhci_hcd
[ 1.543068] usb 1-4: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
[ 1.543071] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.543073] usb 1-4: Product: USB2.0 Hub
[ 1.543074] usb 1-4: Manufacturer: VIA Labs, Inc.
[ 1.787612] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[ 1.959513] usb 1-5: New USB device found, idVendor=04f2, idProduct=b64f, bcdDevice=96.49
[ 1.959514] usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.959515] usb 1-5: Product: HD User Facing
[ 1.959515] usb 1-5: Manufacturer: Chicony Electronics Co.,Ltd.
[ 1.959516] usb 1-5: SerialNumber: 0001
[ 2.084196] usb 1-14: new full-speed USB device number 4 using xhci_hcd
[ 2.225446] usb 1-14: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 2.225448] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.347533] usb 1-4.2: new full-speed USB device number 5 using xhci_hcd
[ 2.489976] usb 1-4.2: New USB device found, idVendor=046d, idProduct=c52f, bcdDevice=30.00
[ 2.489977] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.489978] usb 1-4.2: Product: USB Receiver
[ 2.489979] usb 1-4.2: Manufacturer: Logitech
[ 2.617530] usb 1-4.3: new full-speed USB device number 6 using xhci_hcd
[ 3.519420] usbcore: registered new interface driver btusb
[ 3.557469] input: HD User Facing: HD User Facing as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input14
[ 3.557560] usbcore: registered new interface driver uvcvideo
[ 7.813759] usb 1-4.3: New USB device found, idVendor=258a, idProduct=0016, bcdDevice= 0.01
[ 7.813764] usb 1-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.813768] usb 1-4.3: Product: Usb Gaming Keyboard
[ 7.813770] usb 1-4.3: Manufacturer: BY Tech
[ 7.944313] usb 1-4.4: new full-speed USB device number 7 using xhci_hcd
[ 8.098018] usb 1-4.4: New USB device found, idVendor=045e, idProduct=0719, bcdDevice= 1.00
[ 8.098024] usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.098028] usb 1-4.4: Product: Xbox 360 Wireless Receiver for Windows
[ 8.098030] usb 1-4.4: Manufacturer: ©Microsoft
[ 8.098033] usb 1-4.4: SerialNumber: E1251FF0
[ 9.266909] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.0/0003:046D:C52F.0002/input/input19
[ 9.267015] hid-generic 0003:046D:C52F.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-4.2/input0
[ 9.268237] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:046D:C52F.0003/input/input20
[ 9.268263] usbcore: registered new interface driver xpad
[ 9.324708] hid-generic 0003:046D:C52F.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-4.2/input1
[ 9.326284] input: BY Tech Usb Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0/0003:258A:0016.0004/input/input23
[ 9.381689] hid-generic 0003:258A:0016.0004: input,hidraw3: USB HID v1.10 Keyboard [BY Tech Usb Gaming Keyboard] on usb-0000:00:14.0-4.3/input0
[ 9.385975] input: BY Tech Usb Gaming Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:0016.0005/input/input24
[ 9.441415] input: BY Tech Usb Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:0016.0005/input/input25
[ 9.441706] input: BY Tech Usb Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:0016.0005/input/input27
[ 9.441974] input: BY Tech Usb Gaming Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:258A:0016.0005/input/input28
[ 9.442529] hid-generic 0003:258A:0016.0005: input,hiddev1,hidraw4: USB HID v1.10 Keyboard [BY Tech Usb Gaming Keyboard] on usb-0000:00:14.0-4.3/input1
[ 9.442646] usbcore: registered new interface driver usbhid
[ 9.442648] usbhid: USB HID core driver
[ 9.507797] logitech-djreceiver 0003:046D:C52F.0002: hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-4.2/input0
[ 9.605152] logitech-djreceiver 0003:046D:C52F.0003: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-4.2/input1
[ 9.664577] input: Logitech Wireless Mouse PID:4057 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:046D:C52F.0003/0003:046D:4057.0006/input/input29
[ 9.665050] input: Logitech Wireless Mouse PID:4057 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:046D:C52F.0003/0003:046D:4057.0006/input/input30
[ 9.665274] hid-generic 0003:046D:4057.0006: input,hidraw5: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4057] on usb-0000:00:14.0-4.2/input1:1
[ 9.947970] input: Logitech M280/320/275 as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:046D:C52F.0003/0003:046D:4057.0006/input/input34
[ 9.948641] logitech-hidpp-device 0003:046D:4057.0006: input,hidraw5: USB HID v1.11 Mouse [Logitech M280/320/275] on usb-0000:00:14.0-4.2/input1:1
“sudo dmesg -l emerg,alert,crit,err,warn” output:
[ 0.105767] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.105767] #5 #6 #7
[ 0.111593] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.060150] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 2.227861] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.227863] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.227865] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.227866] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.228032] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.228105] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.301635] i2c_hid i2c-ELAN0504:01: supply vdd not found, using dummy regulator
[ 2.301652] i2c_hid i2c-ELAN0504:01: supply vddl not found, using dummy regulator
[ 2.465896] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 2.623859] iwlwifi 0000:08:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 2.626532] iwlwifi 0000:08:00.0: api flags index 2 larger than supported by driver
[ 2.885630] urandom_read: 1 callbacks suppressed
[ 3.203850] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 4.256777] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 5.557124] kauditd_printk_skb: 46 callbacks suppressed
[ 14.025824] kauditd_printk_skb: 7 callbacks suppressed
[ 44.416045] kauditd_printk_skb: 8 callbacks suppressed
“journalctl -x -p3 -b1” output:
-- Logs begin at Tue 2020-12-01 20:57:40 -03, end at Tue 2020-12-08 15:50:20 -03. --
-- No entries --
“sudo journalctl -p 3 -xb” output:
-- Logs begin at Tue 2020-12-01 20:57:40 -03, end at Tue 2020-12-08 16:00:47 -03. --
dez 08 15:44:36 joaooswaldo-nitroan51554 systemd-modules-load[261]: Failed to find module 'platform-integrity'
dez 08 15:44:36 joaooswaldo-nitroan51554 systemd-udevd[331]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Also, i don’t know if it’s relevant but i get some messages when i turn off or restart the notebook.
[ 15.549401] watchdog: watchdog0: watchdog did not stop!
[ 15.597621] sd-umoun[1617]: Failed to unmount /oldroot: Device or resource busy
[ 15.598163] sd-umoun[1618]: Failed to unmount /oldroot/sys: Device or resource busy
[ 15.598841] Failed to finalize file systems, ignoring.
Please, let me know if there is a especific comand that i should run, cause i’m like…just copying and pasting things here, but i don’t have a clue about what that means.
