[Unstable Update] 2017-05-02 - Plasma5, Gnome, VirtualBox, OpenSSL
Hi community,
seems somebody is really angry about Manjaro lately. Therefore I spent most of my time to restore our Main-Webserver. It took a while to complete all tasks. This forum however and our repositories weren’t affected by all this.
I found some time to compare our current stable branch with what is going on within unstable. We had several updates:
Please test and give us feedback as usual
Current supported Kernels
  • linux310 3.10.105
  • linux312 3.12.73
  • linux316 3.16.42
  • linux318 3.18.51
  • linux41 4.1.39
  • linux44 4.4.65
  • linux48 4.8.17 [EOL]
  • linux49 4.9.25
  • linux410 4.10.13
  • linux411 4.11.0
  • linux-RT-LTS 4.4.60_rt73
  • linux-RT 4.9.20_rt16
Package Updates (Tue May 2 10:49:36 CEST 2017)
A detailed list of package changes can be found here.
  • No issues, everything went smoothly
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Install VirtualBox 5.1.22 please
Networking is broken for me on linux411, because of missing linux411-r8168 maybe? Back on 410 everythings fine.
mhwd -l
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
other than that everything works perfectly for me :thumbsup:
Easy upgrade, thanks!
My 64-bit LXQt guest is running fine with virtualbox-guest-utils and linux49-virtualbox-guest-modules both upgraded to 5.1.22-1, even though their host (KDE Stable) is still at 5.1.20.
“We still don’t recommend to use linux411 series” xD
Working fine in VBox - no problems happened to me
no problems with 4.11 here - using it since rc6 on my main system.
Everything fine except one issue:
I still don’t know what causes this behaviour since it occurs randomly.
This is not related on the update … is a Gnome issue : have you try to login not in wayland but in Xorg ?
At last you can switch form gdm to lightdm …
As i mentioned in the morning when there where some troubles with the mirrors, i switched to pacman-mirrors-dev and from testing to unstable and i can say that everything went smooth and clean. 229 packages and i could say that tis update seems to be rock solid stable for an unstable update.
Really awesome!!!
but I wanted to try :stuck_out_tongue: it’s unstable, so I dont expect it to work
Woo! Finally! Going to get that 4.11 from the unstable branch.
Tried with my Manjaro Mate in virtual box and surprisingly everything worked, including the linux411 kernel.
For being unstable updates these one’s were pretty stable.
I was able to fix this. Just needed to write the r8169 driver to a modules-load file and rebuild mkinitcpio and it was able to successfully use this driver. No need for the r8168 anymore. :grinning:
I still don’t get why it don’t wants to load r8169 (and use) just by itself, without a modules-load entry, tho
I added some more extramodules for linux411 series. Please test.
extra/linux411-acpi_call 1.1.0-0.4 (linux411-extramodules)
    A linux kernel module that enables calls to ACPI methods through
extra/linux411-bbswitch 0.8-0.4 (linux411-extramodules)
    kernel module allowing to switch dedicated graphics card on Optimus laptops
extra/linux411-broadcom-wl (linux411-extramodules)
    Broadcom 802.11 Linux STA wireless driver BCM43142.
extra/linux411-nvidia-304xx 1:304.134-0.4 (linux411-extramodules)
    NVIDIA drivers for linux.
extra/linux411-nvidia-340xx 340.101-0.4 (linux411-extramodules)
extra/linux411-nvidiabl 0.88-0.4 (linux411-extramodules)
    Driver to adjust display backlight on modern mobile NVidia graphics
extra/linux411-r8168 8.044.02-0.4 (linux411-extramodules)
    A kernel module for Realtek 8168 network cards
extra/linux411-rt3562sta (linux411-extramodules)
    Ralink RT3562 PCI WLAN adaptors kernel module
extra/linux411-tp_smapi 0.41-0.4 (linux411-extramodules)
    Modules for ThinkPads SMAPI functionality
extra/linux411-vhba-module 20161009-0.4 (linux411-extramodules)
    Kernel module that emulates SCSI devices
extra/linux411-virtualbox-guest-modules 5.1.22-0.4 (linux411-extramodules)
    Guest kernel modules for VirtualBox
extra/linux411-virtualbox-host-modules 5.1.22-0.4 (linux411-extramodules)
    Host kernel modules for VirtualBox
The only issue with latest updates is that openssl-1.0 breaks some games on steam (the “Life is strange” to me).
Workaround is to install libopenssl-1.0-compat from AUR and use
LD_LIBRARY_PATH=/usr/lib/openssl-1.0-compat/ %command%
as launch option in game properties on steam.
Awww, no regular linux411-nvidia module yet? :stuck_out_tongue:
Some more to the bunch :wink:
extra/linux411-catalyst 1:15.201.1151-0.4 (linux411-extramodules)
    AMD/ATI Catalyst drivers for linux. fglrx kernel module only.
extra/linux411-nvidia 1:375.39-0.4 (linux411-extramodules)
Still struggling with ndiswrapper and spl_zfs
… and here we go :smile:
Any idea if there’s a way to get Age of Wonders III working again? The workaround above doesn’t work with it. When starting it from a terminal, it says:
./AoW3: /usr/lib32/libssl.so.1.0.0: version `OPENSSL_1.0.0' not found (required by ./AoW3) ./AoW3: /usr/lib32/libcrypto.so.1.0.0: version `OPENSSL_1.0.0' not found (required by ./AoW3)
Everything is working ok with linux411 and the nvidia drivers :grinning:
